Go to Post "This is the year that everyone on CD is going to learn to spell." "This is the year that everyone on CD will make a serious effort to write grammatically correct sentences." "This is the year that everyone on CD will think BEFORE they post." ... nah. - dlavery [more]
Unread 12-12-2004, 18:01
occra 23.
AKA: ryo
None #1481
Re: Off season projects
Originally Posted by JamesCH95
I pressed (hammered) a new gear onto all the FP motors and just swapped them in, the RC motors and FP have the same mounting points. Though the one on the grasshopper took a little shimming to get to mesh right. It is impressive you recognized the trannys as the Clodbusters ;-)
anyone know how to pull off the pinion gear on the fp without a gearpull? as i dont have access to one.
Unread 12-12-2004, 18:20
tkwetzel's Avatar
tkwetzel tkwetzel is offline
Good Luck Teams!
AKA: Tyler Wetzel
FRC #0116 (Epsilon Delta)
tkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond repute
Send a message via AIM to tkwetzel
As many CDer's already know, one of my projects can be seen here.
See you in DC!
Unread 12-12-2004, 18:43
NoodleKnight's Avatar
NoodleKnight NoodleKnight is offline
24 Hours of LeMons?
FRC #0100 (WHS&CHS Robotics)
NoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud of
Send a message via AIM to NoodleKnight
Do you have access to a press? If so use that and press the motor shaft out of the gear.
Or, if you don't mind loosing the gear, just use a dremel and cut the gear (gear only, not the FP shaft), in half, then just pry apart. It's pretty time consuming but it doesn't require a gear puller or arbor press.
WHS/CHS Robotics - Team 100 (2003-2006):
2006- Delphi's Driving Tommorow's Technology @ Davis | Imagery Award @ SVR | 2004- SVR Finalists (w/ 691 and 1280)| 2003- Delphi's Driving Tommorow's Technology @ Sac
Unread 12-12-2004, 21:17
JamesCH95's Avatar
JamesCH95 JamesCH95 is online now
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
I don't have access to anything but a vice and hammer to remove/add gears. All i did was hammer on the gear (very carefully) and to take it off tighten the vice around the FP axel (but don't snug it) so that it's under the gear, and use a nail of other available metal rod to hammer out the motor shaft. This has worked well for me, but it requires patience and care, you can easily screw things up.
I will also add that I did this entire project with nothing more than my toolbox of tools and a hand drill, hehe, talk about match-drill...
Unread 12-12-2004, 21:36
Jeff_Rice's Avatar
Jeff_Rice Jeff_Rice is offline
ElementisRegamusProelium
#1359
Jeff_Rice will become famous soon enoughJeff_Rice will become famous soon enough
Talking Re: Off season projects
We are using ***** **** to ****** **** to the ******* while ******* is still ****. We call this ********* because ***** is not *********** to the ******** *******. This is nothing compared to our ******** ***** which will allow us to ******* **** ***** the *** *******.
* censored
Basically we have gone over our robot weaknesses and researched methods of improving them. We are now doing team building exercises, which are mini projects to train our new members. That is about as close to off season projects as we have gotten.
"He said my name is Private Andrew Malone
If you're reading this then I didn't make it home
But for every dream that's shattered another one comes true
This car was once a dream of mine now it belongs to you
And though you may take her and make her your own
You'll always be riding with Private Malone" David Ball, "Private Malone"
Unread 12-12-2004, 22:10
spears312's Avatar
spears312 spears312 is offline
El Capitan
AKA: Ryan
FRC #0312 (Heatwave)
spears312 is just really nicespears312 is just really nicespears312 is just really nicespears312 is just really nicespears312 is just really nice
Send a message via AIM to spears312
We have spent the better half of the last four months on planing and finally running an awesome Lego league competition. We also worked a little on a old robot we pulled out, but we ran out of time to finish it up before build season starts.
HEATWAVE 312
2004 FL Regional Chairman's Award Winners
2005 UCF & Palmetto Team Spirit Award Winners
2005 Championship Curie Division Semi - Finnalists (thx to 118 and 229)
FIRST
Under Construction
Unread 12-12-2004, 23:22
Koko Ed's Avatar
Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
Over the summer we had the site remodeled. The project was led by Ellery . The PAW room was moved out due east and the old PAW room was turned into a museam that has everything X-Cat from 1992 (no not the robot, FIRST has it) to 2004. We have a new rug (straight from Atlanta formerly known as the Newton field) and a new paint job. The site looks sharp.
ID:	2681  Click image for larger version
ID:	2682  Click image for larger version
Name:	New PAW room.jpg
ID:	2683  Click image for larger version
Name:	no food across the line studio.jpg
Unread 12-12-2004, 23:26
Koko Ed's Avatar
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
Heh.
Whaddya know. I put up my website files from school by mistake.
Ah well I guess they'll do.
Unread 13-12-2004, 00:32
RbtGal1351's Avatar
RbtGal1351 RbtGal1351 is offline
~La Reina de los Robots~
AKA: Stephanie
FRC #1351 (TKO)
RbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to behold
Send a message via AIM to RbtGal1351 Send a message via MSN to RbtGal1351
Our team split into 4 or 5 groups to work to different areas, like pneumatics, programming, autoCADing, and electronics, to gain some experience before the build period.
It has actually worked pretty well so far, and seeing as we dont have much time left, good luck to us. We also tried to get an adult mentor for each group; we got 2 alumni (last years seniors), teachers and parents to come in and work with a group once a week. It worked out really well, when we were on task. And when the two programming groups weren't fighting over the computers.
(Hey! It's not my fault the other computer wasn't set up! so WHY did they keep stealing MY computer... )
~Stephanie
2004 Founding member and Arm leader, 2005 Lead programmer, 2006 Controls leader, 2007 Project Manager/President
Thanks for making FIRST such a great experience for me. I'm no longer on 1351, and I'm not currently planning to mentor team 97, but FIRST has meant so much in getting me to where I am now, in life and at MIT, class of 2011.
I met Billfred! He recognized me!
SVR 04: 11th seed - Highest Rookie Seed - Semifinalists w/ 1120 and 568 - GM Industrial Design Award
SVR 05: Semifinalists w/ 8 and 766
SVR 06: 6th seed - Quarterfinalists w/ 368 and 1072
Davis 06: 1st seed - Quarterfinalists w/ 649 and 100 - KPCB Entrepreneurship Award
SVR 07: 36th seed
David 07: 4th seed - Semifinalists w/ 1280 and 692 - Johnson and Johnson Sportsmanship Award
Unread 13-12-2004, 22:51
occra 23.
AKA: ryo
None #1481
nope no press or even a dremel. i tried the vise and hammer way but i guess i wasnt hitting hard enough i was pretty scared id bend the shaft or something of the sort. hammer + motor just doesnt mix well for me. and i was wondering.. if i didnt care about the pinion anymore, as long as i got it off and the motor in good shape, are there any other ways? i have only limited access to a very limited tools
Unread 13-12-2004, 23:06
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Well, you could try to rig up some contraption involving clamps, though that may prove to be tricky. If you have a torch of some kind you could try heating it up and pulling the gear off, a good propane torch should only be $20-$30 with a tank. If that seems to scary you could also try taking off the gear with a grinder. If all else fails attack it with a hacksaw. If you're really worried about hurting something with the hammer/vise technique, strap a softer metal (aluminum or copper) to the hammer head so that you won't scarrify anything.
Unread 13-12-2004, 23:32
24 Hours of LeMons?
How about a drill press? You can use the drill press to try and push on the shaft to force the gear out. Not too good for the drill press though. Like what James said, hacksaw is good, it'll take some time. Maybe buy some metal lubricant at an automotive store, like the stuff you use to loosten rusted bolts (but I think that only really helps when it's rusted shut).
Worse case senario, clamp the pinion rock solid in a vice, then sit there with a file or an angle grinder and tear away at the gear until you get somewhat close to the shaft. Then just try pulling/ pounding it out. Yeah, and it will be very time consuming.
A new season, a new task Koko Ed Fantasy FIRST 18 19-12-2004 13:21
The NFL 2004-2005 Season Thread Corey Balint Chit-Chat 5 05-09-2004 17:58
After Season Projects JakeGallagher General Forum 29 02-04-2004 16:09
A report on off season competitions Ken Leung Off-Season Events 2 17-10-2003 13:30
