Go to Post No one would climb Mount Everest before climbing the hill in the park down the street. - RbtGal1351 [more]
Unread 12-12-2004, 00:56
Gdeaver Gdeaver is offline
FRC #1640
Re: Has any team or anybody made a 80% - 100% lexan bot?
Team 104 has used polycarbonate for a frame covering the last 3 years. We use 1/8" and 3/16" 6061-T6011 aluminum 1" angle for the frame joined with steel pop-rivets and backup washers. The polycarbonate is held on with 1" velcro. Mcmaster Carr sells velcro with a very strong contact adhesive. We have a sign shop make our decals to be applied on the inside. The inside of each panel is then painted. Our decals and paint can't scrape off. Note- make sure the paint is for lex an. Most paints do not stick. We have not experienced any frame damage or panel damage.
Polycarbonate is expensive. As was noted in another post, birch furniture grade plywood is very strong and light. To take it up another notch in rigidity and strength, Try laminating 5mm, 3/16 or 1/4" plywood with 1 or 2 layers of 4 oz. s2 fiberglass and epoxy. It's an excellent structural material and is fairly cheap. With our budget constraints this year we may have to use it.
Unread 12-12-2004, 01:43
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
Originally Posted by Max Lobovsky
GE Lexan (clear, no glass)
---72 MPa -----1.2 g/cm3----- ratio 60
Aluminum 6061-T6 ---------310 MPa -----2.7 g/cm3 ---ratio 114
Yes, but other aluminums don't fare as well. 5052 aluminum, for example, has ratios between 70 and 100. Other aluminums range from a ratio of 17 to a ratio of 237.
Zan Hecht
Unread 12-12-2004, 02:49
MrToast's Avatar
MrToast MrToast is offline
I named Greg Needel's cat!
AKA: Dave DeLong
no team (Rhode Warriors)
MrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud of
Send a message via AIM to MrToast
Originally Posted by Thread Title
Has any team or anybody made a ...100% lexan bot?
Yes, but the lexan motors kept on melting....
MrToast
(#121, 2004) Archimedes semi-finalists with 237 and 386! I had an awesome time guys, and thanks for the hat!
(#121, 2004) BC5 semi-finalists with 190 and 1027! Awesome time! We went further than I thought we could! Thanks for all your help w/ our transmission!
(#121, 2005) Galileo quarter-finalists with 47 and 203! Thanks for all your support through the stress!
If it moves and it shouldn't, use duct tape.
If it doesn't move and it should, use WD-40
"It'll all work out in the end, and if it doesn't, it's not the end." - Jeff Bullock
Unread 12-12-2004, 10:03
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
6061 is definitley the most commonly available (and probably one of the cheapest) types of aluminum used structurally. Most of the aluminum extrusion kits, and most of the tubing/angle/channel found on FIRST robots is 6061.
Additionally, Polycarbonate varies (you'd have to go to some other brand than Lexan) and glass filled PCs have ratios around about 80. I'm pretty sure glass filled PC is too hard and brittle for most framing use.
Team 1257
Unread 12-12-2004, 10:24
Fold em oval!
And just because the use of this by teams that have plenty of metal machining capabilities annoys me:
pipe type PVC ------ ratio 31
Team 1257
Unread 12-12-2004, 13:43
Dick Linn's Avatar
no team (Synergy)
Team 346 (Richmond) made one in 2001, I believe it was. There were a couple of pieces of aluminum angle connecting the Hyzod platform to the side panels. Each side was doubled up and contained a chain driving 3 wheels. It looked very much like one of those WWI tanks, as the front was intended to crawl over the 4x4 in the middle of the playing field. The polycarb was appx. 3/8" if I recall. I don't have pictures, but perhaps someone from 346 does. The frame held up well, although the bot was pretty light.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 12-12-2004, 14:11
Alex Cormier's Avatar
Alex Cormier Alex Cormier is offline
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
does anyone from 401 or any team know anything about this bot?
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
Unread 12-12-2004, 17:58
what exactly annoys you?
Unread 12-12-2004, 18:57
Fold em oval!
Heh. Perhaps that was a bad choice of words, but, in general, it is annoying when a simple design choice could have significantly improved the end product.
Team 1257
Unread 12-12-2004, 19:03
RogerR's Avatar
RogerR RogerR is offline
its spelled *ya'll*, not *y'all*
AKA: Roger Riquelme
FRC #3844 (Wildbots)
RogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond repute
Send a message via AIM to RogerR Send a message via MSN to RogerR
personally, i believe that using ENC (the grey PVC) is good design choice. its light, flexible, strong (enough), cheap, and above all, easy to work with.
"But to say that the race is a metaphor for life is to miss the point. The race is everything. It obliterates whatever isn't racing. Life is a metaphor for the race." -- Donald Antrim
Unread 12-12-2004, 19:20
Fold em oval!
empahses added
Team 1257
Unread 12-12-2004, 19:37
Michael R. Lee's Avatar
Michael R. Lee Michael R. Lee is offline
BLT= Brave Little Toaster
Michael R. Lee will become famous soon enoughMichael R. Lee will become famous soon enough
Send a message via AIM to Michael R. Lee Send a message via Yahoo to Michael R. Lee
Re: Has any team or anybody made a 80% - 100% lexan bot? Yes, I have!
Originally Posted by Andrew Rudolph
SPAM team 180 has mad robots, even the gear boxes were out of lexan i believe. I belive this one below was called lexy.
MY ROOKIE YEAR ROBOT!
Yes that is Sexy Lexy in her KSC glory. At Epcot we added a turtle shell to her chassis for additional protection and were attempting to install a hanging mechanism. Her gearboxes were lexan as well as the following years robot 3-bits (3-bits bad grrrr).
As many has stated it is expensive. Polycarbonate sheet is used as bulletproof glass. We got some donations from a local hurricane shutter manufacturer that year. However, an all lexan bot also sets you apart from the rest as some of us were remembered as the dudes with the clear robot. Before I digress any further, lexan is easy to work with basic machine tools you could get at home depot, loews or any equivalent respectable hardware store. That year if you looked at our pit, that's pretty much what we had at our shop. Belt sander, band saw, couple drill presses...... we've come along way.
When designing, you should also consider not only how will you manufacture it, ease of repair, but what materials. Obviously you don't want a large force extended out on let's say an arm that's just from what you made it out of not to mention whatever you intend to manipulate like this past year a ball.
Oh paint sticking... somehow we managed to get some neon green on lexy when we climbed on top of Swamp Thing somehow (ask Ares.. he was driving ;-)) almost 10 points but we were touching the ramp so only 5.
Thanks for the trip down amnesia lane.
“Ad Astra Per Aspera”
(A Rough Road Leads to the Stars)
Northeastern University College of Engineering
Class of 2008, Mechanical Engineering
Go HUSKIES!
Unread 12-12-2004, 19:38
RogerR's Avatar
AKA: Roger Riquelme
i look at it like this: i would much rather repair/replace an arm thats made from lengths of PVC tubing than an arm that is made from custom machined alum. at a competition. plus all the weight and/or money saved by using PVC can be put somewhere else, such as a drive train or electronic components.
Unread 12-12-2004, 19:51
another good part about pvc arms is that they wont dent or bend out of shape like some aluminum arms. And if you are worried about it shattering.. how easy is it to cut out the broken part, cut a new piece to size, and put it in with 2 couplers and some glue! woohoo go pvc!
Unread 12-12-2004, 20:18
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Tom beat me to it, but this fact was a driving force behind our decision to use PVC for a telescoping arm to reach the bar last year. We knew we'd be subject to punishment from teams cause we were reaching from the ground, and we knew there was a chance for the arm to get bent, so we chose PVC for it flexibility. We had our arm literally wrapped around a pole a couple of times, and it was fine. I saw a team at Lone Star have a metal arm wrapped around a pole, and it was ugly.
So, in summary, PVC definitely has its uses, and you just need to consider what you're designing for, like any other engineering choice.
The Death of FIRST Anton Abaya General Forum 23 03-05-2006 17:18
How do you organize your team? NoodleKnight Team Organization 18 03-11-2005 22:57
Thank a Team with an i-Pod !!! OZ_341 General Forum 8 20-04-2004 23:57
Team 524's bot Amadkow Robot Showcase 2 27-02-2002 20:36
Novi Kickoff Seminar List (Tentative) Joe Johnson General Forum 1 05-12-2001 13:47
