Go to Post Great teams derive from great mentors. - Barry Bonzack [more]
Go Back   Chief Delphi > Competition > Rules/Strategy > You Make The Call
View Poll Results: You Make The Call
Legal! No need to use the same drill motor. 22 33.33%
Illegal! Swapping out the drill motor is a must. 44 66.67%
Voters: 66. You may not vote on this poll
Unread 13-12-2004, 02:56
Natchez Natchez is offline
#0118 (Robonauts)
Natchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond repute
YMTC: Redabot weighs 129.8?
You Make The Call (YMTC) is a series of situations where you can be the ref and make the call.
Redabot uses two different upper body mechanisms, Jumpy and Grabby. Jumpy is placed on Redabot when she wishes to jump on the bar and Grabby is installed when she wishes to pick up balls. Each mechanism uses one drill motor. Redabot passes inspection at 129.8 lbs with the base, Jumpy, and Grabby on the scale BUT only Grabby has a drill motor installed. Since only one mechanism is on Redabot at a time, the drill motor is swapped between Jumpy and Grabby. To save the pain of swapping out drill motors, Redabot decides to install her extra drill motor on Jumpy. Therefore, Redabot never needs to swap motors when installing Jumpy or Grabby onto the base.
Based on the 2004 Robot Rules, YOU MAKE THE CALL!
Unread 13-12-2004, 03:17
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
Re: YMTC: Redabot weighs 129.8?
<R06> The maximum allowed weight of all robot configuration components combined is 130.0 pounds (58.97kg). At the time of weigh in, the basic robot platform and any additional items that might be used in different configurations of the robot must be weighed together. Weight limit includes (one) 12V battery,control system, decorations, bumpers, and any other attached parts.
This one is easy. For weigh in, you need to weigh it with all items that might be used. All items includes all motors.
Wetzel
Unread 13-12-2004, 03:18
Katie Reynolds Katie Reynolds is offline
no team (NEW Apple Corps)
Katie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond repute
Send a message via AIM to Katie Reynolds Send a message via Yahoo to Katie Reynolds
<R06> The maximum allowed weight of all robot configuration components combined is 130.0 pounds (58.97 kg). At the time of weigh in, the basic robot platform and any additional items that might be used in different configurations of the robot must be weighed together. Weight limit includes (one) 12V battery, control system, decorations, bumpers, and any other attached parts.
If the second drill motor weighs more than .2 lbs, it's illegal. The weight of the base plus all of the mechanisms will be more than 130.00 lbs. Redabot needs switch out the motor or figure out a way to drop the .2 lbs they need. (cheeseholes, anyone?)
Team #93 - NEW Apple Corps
Student - 2001-2004
Team #857 - Superior Roboworks
Mentor - 2006-2009
Unread 13-12-2004, 08:20
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Not so fast. It's also a spare part, which doesn't count against the limit.
That's a symptom of the real problem--a badly conceived rule. There's no universal way of determining whether their extra drill is a spare part, mounted on the mechanism for convenience (where it is legal) or a part of the mechanism (where it is illegal, due to weight). You could take the naïve approach, and say, "well, it's attached to the mechanism, so it mustn't be legal", but that comes down to a silly semantic argument as to when something is part of something else, and when it's a separate entity. Note that they (properly) pass the weigh-in, because they know that a mechanism or part need not be attached to the robot to be part of its official weight (e.g. the two function modules--which probably can't be attached at the same time).
Unread 13-12-2004, 09:12
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
There is a universal way of determining whether it's a spare part or not, I think.
<R76> The costs of "spare" parts are excluded from this rule. A spare part is defined as a part that a team has obtained as a direct replacement for a failed or defective Robot part (Kit part or non-kit part)
If the team is putting it on the other assembly for convenience and not to replace a busted drill motor, then I don't think it counts. If it's not a spare part, then it has to be counted on the weight.
Unread 13-12-2004, 09:25
Steve W Steve W is offline
Grow Up? Why?
Steve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond repute
I agree with Kevin. A spare part is for replacement only. Once you attach it to the arm or whatever it is now part of the robot. Once assembled the robot must still meet weight requirements.
We must make sure that we don't try to make the rules meet our way of thinking. Rules should state the obvious. In this case you weigh in what you are going to use. If you add to the assembly then you must reweigh with ALL parts. I see no problem if you switch motors around between assemblies as that is how you weighed in.
We do not stop playing because we grow old;
we grow old because we stop playing.
Unread 13-12-2004, 09:36
As an inspector under 2004 rules, I would have ruled this robot did not make weight. Under 2003 rules it would have. I personally feel that the maximum weight a robot will be competing at is the test weight for inspection as the 2003 rule stated. After all, the max weight and size of a robot when it is on the field is the the critical issue to a level playing field, not the parts that are left behind. You don't qualify for size with all attachments fitting in the size box, just the robot with each attachment so that no attachment is over the size limit.
Unread 13-12-2004, 10:27
aaronbr28040's Avatar
aaronbr28040 aaronbr28040 is offline
AKA: Aaron Bradshaw
#0900 (Team Infinity)
aaronbr28040 is just really niceaaronbr28040 is just really niceaaronbr28040 is just really niceaaronbr28040 is just really nice
Send a message via AIM to aaronbr28040
I would have to say it would not pass the inspection. If it had the other drill motor installed I would say it would pass if it met the weight requirements. I think this is what FIRST was trying to avoid when saying all mechanisms must be counted in the weight. When looking at these rules we must look at the purpose of the rule rather than trying to dig in the wording to find the loophole.
-Aaron
@North Carolina State University
Team 900
North Carolina School of Science and Mathematics
AIM:aaronbr28040
Unread 13-12-2004, 11:43
That only addresses the reason for which it was obtained, rather than the reason for which it was installed. It is legitimate to buy it in order to cover a possible malfunction, then preemptively install it in one module or the other. That is only tantamount to changing a motor in an integral mechanism for the heck of it, rather than when broken (which isn't a bad idea in some cases, and which is perfectly legal). The issue seems to be with the time saved, which seems like one hell of a worthless thing to be concerned about!
Just out of curiosity, Aaron, since only one drill motor is installed at inspection-time, and it meets weight limits at that time, why wouldn't it pass the inspection? You state "I would have to say it would not pass the inspection", but there is nothing at inspection-time that would constitute an illegal part or mechanism.
As for why I think that the rule is ill-conceived, look at it this way: if you had a quick-change collar on the Globe motor, it would make sense to make two--one for the robot and one for the spare motor. Is it being implied that such a collar is inherently illegal, unless you defeat its purpose by only waiting until you need it in order to install the collar on the motor? Also, I agree with Al's reasoning regarding the comparable example of robot sizing.
I can definitely attest that I liked the 2003 rule better, but I don't think that the 2004 rule even covers the situation in question.
Unread 13-12-2004, 12:04
Sure, you can install the second motor on the second module as long as both modules and the base weigh a total of less than 130 lbs. In this situation, Redabot would weigh more than 130 lbs, if reweighed after adding the second motor.
With what you're saying, teams could easy add another 20 lbs to their robot by added backups for when something fails.
"Well, we're at 128 lbs but ... that battery'll die sometime - we'd better make room for two, just in case!"
"Alright, we're at 130 exactly. But I was thinking - that chip motor could give out. Instead of swapping the whole motor if it fails, let's just throw another on there now so we can move the wires and save ourselves some trouble!"
No one is saying you can't install a spare part for when something breaks -- the general concensus seems to be, if you've already "passed inspection" and weighed in, and are adding a part that could put you over the 130 lb limit, you should be reweighed. If the robot is over 130 lbs, the spare part needs to be removed or provisions should be made so the robot is within the 130 lb limit with the spare.
Bottomr line: If a team is going to add something of considerable weight (not a ziptie or an extra velcro tie), they should reweigh to make sure that they will pass inspection with the new part(s) on the robot. If the robot and all of its assemblies weigh more than 130 lbs at any time, it is in violiation of rule <R06>.
Student - 2001-2004
Mentor - 2006-2009
Unread 13-12-2004, 12:17
Andy Brockway Andy Brockway is offline
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
I also agree that the motor cannot be installed. Let us keep separate what are spare parts and what is part of the robot during inspection. Spare parts replace whatever was on the robot during inspection, adding parts is just that - adding parts.
While there is some controversy over this rule, I think it came out of similiar threads about teams that built complete arms for their robots in the past. I remember in 2001, while in que, seeing our alliance partner take off half their robot. I went over to see if they needed help with repairs but they were just changing the arm because of our strategy.
Andy Brockway
Team 716, The Who'sCTEKS
Unread 13-12-2004, 12:21
Grow Up? Why?
Tristan, like for like is OK. You are changing 2 parts on the robot for identical parts AND function. When changing for two different functions then everything used for the snap on must be weighed. If you don't weigh in both motors then you are not only violating the rule but the spirit of the rule as well. You can build 2 identical arms and ship with your robot. One is used as a spare. That whole assembly does not have to be weighed in, just the one to be used on the robot. The reason is like for like spares. Only when there are unlike replacements must they be added to the robot at weigh in time. If you weigh in one motor then that motor must be taken off your robot and put on the new function.
Now if you want to get away from gracious professionalism then you could say that you were having a problem with the old motor so you replaced with a new. Then when changing back to the out function say that you fixed the problem and that it is now OK. That is were gracious professionalism comes in. Not everything can be monitored and/or enforced. We must rely somewhat on the honesty of the teams. By the look of it when looking at the poll there are about 30% the are willing to be dishonest.
Unread 13-12-2004, 12:32
Wetzel's Avatar
DC Robotics
Installing the spare collar on the spare motor makes a spare assembly. This is a one-for-one exchange for the same function.
I agree with Al, the weight you play at is the weight you should weigh at. If you can play in more than one configuration, you must weight less than 130lbs in all configurations.
Wetzel
Unread 13-12-2004, 12:54
Like Katie said, I think a part stops being a "spare" as soon as it's attached to your robot in some fashion. If that's not the case, I know I would love to have 50 lbs of ballast on our bot to increase traction in some games.
Also, I think the rule as it currently stands is intended to prevent teams from having a giant number of configurations. This emphasizes strategizing and engineering decisions anyways, so I can't see how it's a bad thing, but I think that's a discussion for an entirely different thread.
Unread 13-12-2004, 13:01
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
By the word of the rules, it's illegal. My personal opinion? I don't really care. It would save them a few minutes by not having to switch the motors if it was legal, but if the team planned a strategy that required something as major as removing and replacing an arm, I'm sure they could move the motor as well.
2001-2004: Team 100
2006-Present: Team 254
YMTC: Is it goaltending? Natchez You Make The Call 43 12-04-2004 18:03
YMTC: Redabot grabs rail Natchez You Make The Call 10 10-04-2004 12:16
YMTC: Redabot accidentally breaks goal Natchez You Make The Call 9 10-04-2004 12:11
YMTC: Bluabot sits on Redabot Natchez You Make The Call 19 08-04-2004 16:43
YMTC: Bluabot and Redabot hanging? Natchez You Make The Call 15 23-03-2004 01:42
