| View Poll Results: You Make The Call | |||
| Legal! No need to use the same drill motor. |
22 | 33.33% |
| Illegal! Swapping out the drill motor is a must. |
44 | 66.67% |
| Voters: 66. You may not vote on this poll | |||
YMTC: Redabot weighs 129.8?
You Make The Call (YMTC) is a series of situations where you can be the ref and make the call.
Redabot uses two different upper body mechanisms, Jumpy and Grabby. Jumpy is placed on Redabot when she wishes to jump on the bar and Grabby is installed when she wishes to pick up balls. Each mechanism uses one drill motor. Redabot passes inspection at 129.8 lbs with the base, Jumpy, and Grabby on the scale BUT only Grabby has a drill motor installed. Since only one mechanism is on Redabot at a time, the drill motor is swapped between Jumpy and Grabby. To save the pain of swapping out drill motors, Redabot decides to install her extra drill motor on Jumpy. Therefore, Redabot never needs to swap motors when installing Jumpy or Grabby onto the base. Based on the 2004 Robot Rules, YOU MAKE THE CALL! Last edited by Natchez : 13-12-2004 at 03:04. |
| YMTC: Is it goaltending? | Natchez | You Make The Call | 43 | 12-04-2004 18:03 |
| YMTC: Redabot grabs rail | Natchez | You Make The Call | 10 | 10-04-2004 12:16 |
| YMTC: Redabot accidentally breaks goal | Natchez | You Make The Call | 9 | 10-04-2004 12:11 |
| YMTC: Bluabot sits on Redabot | Natchez | You Make The Call | 19 | 08-04-2004 16:43 |
| YMTC: Bluabot and Redabot hanging? | Natchez | You Make The Call | 15 | 23-03-2004 01:42 |
