Go to Post your chain routing is cute - rachal [more]
Go Back   Chief Delphi > Competition > Rules/Strategy > You Make The Call
View Poll Results: You Make The Call
Legal! No need to use the same drill motor. 22 33.33%
Illegal! Swapping out the drill motor is a must. 44 66.67%
Voters: 66. You may not vote on this poll
Unread 13-12-2004, 09:12
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: YMTC: Redabot weighs 129.8?
Originally Posted by Tristan Lall
Not so fast. It's also a spare part, which doesn't count against the limit.
That's a symptom of the real problem--a badly conceived rule. There's no universal way of determining whether their extra drill is a spare part, mounted on the mechanism for convenience (where it is legal) or a part of the mechanism (where it is illegal, due to weight). You could take the naïve approach, and say, "well, it's attached to the mechanism, so it mustn't be legal", but that comes down to a silly semantic argument as to when something is part of something else, and when it's a separate entity. Note that they (properly) pass the weigh-in, because they know that a mechanism or part need not be attached to the robot to be part of its official weight (e.g. the two function modules--which probably can't be attached at the same time).
There is a universal way of determining whether it's a spare part or not, I think.
<R76> The costs of "spare" parts are excluded from this rule. A spare part is defined as a part that a team has obtained as a direct replacement for a failed or defective Robot part (Kit part or non-kit part)
If the team is putting it on the other assembly for convenience and not to replace a busted drill motor, then I don't think it counts. If it's not a spare part, then it has to be counted on the weight.
YMTC: Is it goaltending? Natchez You Make The Call 43 12-04-2004 18:03
YMTC: Redabot grabs rail Natchez You Make The Call 10 10-04-2004 12:16
YMTC: Redabot accidentally breaks goal Natchez You Make The Call 9 10-04-2004 12:11
YMTC: Bluabot sits on Redabot Natchez You Make The Call 19 08-04-2004 16:43
YMTC: Bluabot and Redabot hanging? Natchez You Make The Call 15 23-03-2004 01:42
