Go to Post There is no offseason. - Jeff Rodriguez [more]
Unread 13-12-2004, 19:57
colt527 colt527 is offline
AKA: Ken Colton
FRC #0527
colt527 is a splendid one to beholdcolt527 is a splendid one to beholdcolt527 is a splendid one to beholdcolt527 is a splendid one to beholdcolt527 is a splendid one to beholdcolt527 is a splendid one to beholdcolt527 is a splendid one to behold
Send a message via AIM to colt527
A few gearbox questions
Ok, first here is our gearbox setup. We combine the CIM's and the drill motors together in a very simple design where we matched the RPM's using gears and chains. More specifically we are using the drill motors inside their normal transmission supplied by the KOP, in low speed, with the backdrive-pins taken out and on the 15 clutch setting. Here are the questions:
1.) Are we really getting the full benefits of combining the 2 motors into one side because we are using the drill motor transmission supplied by the KOP. To me, it just doesnt make sence. As soon as the drill motor's transmission's clutch starts to click, the drill motors are not supplying any force any torque and its just like running the CIMs by themselves.
2.) Is it really hazardous to the drill motors to put the transmission in direct drive. We have burnt many a drill motor before but if the CIMs are helping it out, should this really be a concern?
3.) We are currently running all the motors through 30amp breakers because we did not have another 40 fuse box lying around. Could this cause problems?
4.) Is it possible to burn out the CIMs, if stall amperage is 50amp and its running through 30amp fuses.
Mentor, Team 527 -- Plainedge Red Dragons
FIRST Volunteer
SUNY Stony Brook Computer Science 2010
kcolton@gmail.com
47 Questions! Matt Krass Games/Trivia 52 19-04-2006 00:58
**FIRST EMAIL**/Autodesk Inventor Training and Technical Questions Information Rich Wong FIRST E-Mail Blast Archive 0 07-12-2004 17:22
Looking for KoP Drill motor gearbox parts Max Lobovsky Kit & Additional Hardware 2 09-08-2004 20:06
3 Questions!!! (2/20/04) Andy Grady General Forum 20 20-02-2004 17:31
Shift on the fly LEGO gearbox rlowerr_1 Robot Showcase 17 14-07-2003 23:33
