Go to Post We are different, but in our differences we help the world continue to grow, change, become inspired. Different is NOT bad. Be true to your self, be weird, be dorky, be crazy, be a geek. :) - chellyzee93 [more]
Go Back   Chief Delphi > Technical > Robotics Education and Curriculum
Unread 13-12-2004, 22:22
colt527 colt527 is offline
AKA: Ken Colton
FRC #0527
colt527 is a splendid one to beholdcolt527 is a splendid one to beholdcolt527 is a splendid one to beholdcolt527 is a splendid one to beholdcolt527 is a splendid one to beholdcolt527 is a splendid one to beholdcolt527 is a splendid one to behold
Send a message via AIM to colt527
Re: Don't Laugh - Remember I'm New ... Robovation Kit
Yes, this is actually quite easy, and no it was not a dumb question.
The best I can explain it would be through code:
unsigned long int timer = 0;//Global variable declared right under the includes
...Code ommited for posting purposes...
//This function gets called every 17ms, therefore you just use a global variable that increments everytime this function is called to keep track of the time that is going by.
void Process_Data_From_Master_uP(void)
  Getdata(&rxdata);   /* Get fresh data from the master microprocessor. */
  Default_Routine();  /* Optional.  See below. */
  /* Add your own code here. */
  if(timer <= 85)//Both pwms full forward for first 5 seconds (17 * 5= 85)
    pwm07 = 255;
    pwm08 = 255;
  else if(timer > 85 && timer <= 119)//For next 2 seconds turn
    pwm07 = 0;
    pwm08 = 255;
  else //else sit there
    pwm07 = 127;
    pwm08 = 127;
  timer++;//Increment the variable
  printf("PWM OUT 7 = %d, PWM OUT 8 = %d\n",(int)pwm07,(int)pwm08);  /* printf EXAMPLE */
  Putdata(&txdata);             /* DO NOT CHANGE! */
and there you go. You just have to edit the Process_Data_From_Master_uP function in user_routines.c. Hope I helped . Basically you just use this function to simulate autonomous, but if you need something to update faster then 17ms you need to place it in a different spot.
Mentor, Team 527 -- Plainedge Red Dragons
FIRST Volunteer
SUNY Stony Brook Computer Science 2010
kcolton@gmail.com
Unread 14-12-2004, 22:06
wmurphy wmurphy is offline
#1529 (Cyber Cardinals)
wmurphy is an unknown quantity at this point
Thanks Ken! I appreciate the help.
Murf
Robovation Robot kit cmmarkes Robotics Education and Curriculum 4 24-01-2005 17:24
Please Help: Programming the Robovation Kit wmurphy Robotics Education and Curriculum 14 08-12-2004 12:57
robovation KIT help Mirza95vx Technical Discussion 2 03-12-2004 15:08
2004 WPI EBOT Competition (using Robovation robots) ahecht Off-Season Events 3 04-11-2004 21:25
