Go to Post I guess Team 999 was like "Chute first, ask questions later". - KPSch [more]
Go Back   Chief Delphi > Technical > Robotics Education and Curriculum
Unread 13-12-2004, 21:51
wmurphy wmurphy is offline
#1529 (Cyber Cardinals)
wmurphy is an unknown quantity at this point
Don't Laugh - Remember I'm New ... Robovation Kit
Hi.
Is it possible to program the Robovation Kit such that it will run "autonomously" for a given length of time and then stop? In other words, since we don't have a RC transmitter / receiver to use right now - can we still get the thing to do what we want without it?
Thanks,
Murf
Unread 13-12-2004, 22:22
colt527 colt527 is offline
AKA: Ken Colton
FRC #0527
colt527 is a splendid one to beholdcolt527 is a splendid one to beholdcolt527 is a splendid one to beholdcolt527 is a splendid one to beholdcolt527 is a splendid one to beholdcolt527 is a splendid one to beholdcolt527 is a splendid one to behold
Send a message via AIM to colt527
Re: Don't Laugh - Remember I'm New ... Robovation Kit
Yes, this is actually quite easy, and no it was not a dumb question.
The best I can explain it would be through code:
unsigned long int timer = 0;//Global variable declared right under the includes
...Code ommited for posting purposes...
//This function gets called every 17ms, therefore you just use a global variable that increments everytime this function is called to keep track of the time that is going by.
void Process_Data_From_Master_uP(void)
  Getdata(&rxdata);   /* Get fresh data from the master microprocessor. */
  Default_Routine();  /* Optional.  See below. */
  /* Add your own code here. */
  if(timer <= 85)//Both pwms full forward for first 5 seconds (17 * 5= 85)
    pwm07 = 255;
    pwm08 = 255;
  else if(timer > 85 && timer <= 119)//For next 2 seconds turn
    pwm07 = 0;
    pwm08 = 255;
  else //else sit there
    pwm07 = 127;
    pwm08 = 127;
  timer++;//Increment the variable
  printf("PWM OUT 7 = %d, PWM OUT 8 = %d\n",(int)pwm07,(int)pwm08);  /* printf EXAMPLE */
  Putdata(&txdata);             /* DO NOT CHANGE! */
and there you go. You just have to edit the Process_Data_From_Master_uP function in user_routines.c. Hope I helped . Basically you just use this function to simulate autonomous, but if you need something to update faster then 17ms you need to place it in a different spot.
Mentor, Team 527 -- Plainedge Red Dragons
FIRST Volunteer
SUNY Stony Brook Computer Science 2010
kcolton@gmail.com
Unread 14-12-2004, 22:06
Thanks Ken! I appreciate the help.
Murf
Robovation Robot kit cmmarkes Robotics Education and Curriculum 4 24-01-2005 17:24
Please Help: Programming the Robovation Kit wmurphy Robotics Education and Curriculum 14 08-12-2004 12:57
robovation KIT help Mirza95vx Technical Discussion 2 03-12-2004 15:08
2004 WPI EBOT Competition (using Robovation robots) ahecht Off-Season Events 3 04-11-2004 21:25
