Go to Post I live for the offseason...that is, when i'm not living for the actual season. - Libby K [more]
Unread 13-12-2004, 22:51
occra 23.
AKA: ryo
None #1481
Re: Off season projects
nope no press or even a dremel. i tried the vise and hammer way but i guess i wasnt hitting hard enough i was pretty scared id bend the shaft or something of the sort. hammer + motor just doesnt mix well for me. and i was wondering.. if i didnt care about the pinion anymore, as long as i got it off and the motor in good shape, are there any other ways? i have only limited access to a very limited tools
Unread 13-12-2004, 23:06
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Well, you could try to rig up some contraption involving clamps, though that may prove to be tricky. If you have a torch of some kind you could try heating it up and pulling the gear off, a good propane torch should only be $20-$30 with a tank. If that seems to scary you could also try taking off the gear with a grinder. If all else fails attack it with a hacksaw. If you're really worried about hurting something with the hammer/vise technique, strap a softer metal (aluminum or copper) to the hammer head so that you won't scarrify anything.
Unread 13-12-2004, 23:32
NoodleKnight's Avatar
NoodleKnight NoodleKnight is offline
24 Hours of LeMons?
FRC #0100 (WHS&CHS Robotics)
NoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud of
Send a message via AIM to NoodleKnight
How about a drill press? You can use the drill press to try and push on the shaft to force the gear out. Not too good for the drill press though. Like what James said, hacksaw is good, it'll take some time. Maybe buy some metal lubricant at an automotive store, like the stuff you use to loosten rusted bolts (but I think that only really helps when it's rusted shut).
Worse case senario, clamp the pinion rock solid in a vice, then sit there with a file or an angle grinder and tear away at the gear until you get somewhat close to the shaft. Then just try pulling/ pounding it out. Yeah, and it will be very time consuming.
WHS/CHS Robotics - Team 100 (2003-2006):
2006- Delphi's Driving Tommorow's Technology @ Davis | Imagery Award @ SVR | 2004- SVR Finalists (w/ 691 and 1280)| 2003- Delphi's Driving Tommorow's Technology @ Sac
A new season, a new task Koko Ed Fantasy FIRST 18 19-12-2004 13:21
The NFL 2004-2005 Season Thread Corey Balint Chit-Chat 5 05-09-2004 17:58
After Season Projects JakeGallagher General Forum 29 02-04-2004 16:09
A report on off season competitions Ken Leung Off-Season Events 2 17-10-2003 13:30
