Go to Post Short answer, the GDC has ruled it legal explicitly through Q&A, implicitly through Q&A, and implicitly through the Manual. - EricH [more]
Unread 13-12-2004, 23:46
Hunter's Avatar
Hunter Hunter is offline
Wood is Good
AKA: Todd Willick
FRC #5184 (Titanics)
Hunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond repute
Re: A few gearbox questions
Originally Posted by Cory
Actually, if you remove the clutch, they WON'T work right with the standard drill mounts. There's two little metal tabs in the front of the transmission, on the face of the casing. They'll fall out if you dont cover the face of the transmission, and the drill motor doesn't seem to run as well.
Actually, once you braze the clutch ring to the ratchet, you don't need those metal tabs, and you just take them out since they are just part of the clutch. It fits perfectly in the mounts then, and there is absolutely no worries about it slipping.
47 Questions! Matt Krass Games/Trivia 52 19-04-2006 00:58
**FIRST EMAIL**/Autodesk Inventor Training and Technical Questions Information Rich Wong FIRST E-Mail Blast Archive 0 07-12-2004 17:22
Looking for KoP Drill motor gearbox parts Max Lobovsky Kit & Additional Hardware 2 09-08-2004 20:06
3 Questions!!! (2/20/04) Andy Grady General Forum 20 20-02-2004 17:31
Shift on the fly LEGO gearbox rlowerr_1 Robot Showcase 17 14-07-2003 23:33
