Go to Post "What connection is the most vital to the success of your robot?" The one between the drivers brain and hands, and the one between the coaches brain and mouth. None of the other ones matter if those two don't work. - dlavery [more]
Unread 14-12-2004, 22:52
phrontist's Avatar
phrontist phrontist is offline
Proto-Engineer
AKA: Bjorn Westergard
FRC #1418 (Vae Victus)
phrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond repute
Send a message via AIM to phrontist
Re: sphere bot
Originally Posted by Levin571
Another idea commonly passed around before was the idea of the hoverbot which would be cool to see but i haven't looked in the rule book for a while to see if it would be allowed
It's perfectly legal, but even if you made it work you'd drain almost all of your resources (weight, power, fabrication time) doing it and in the end have a pretty useless bot.
Oh, btw, I fence foil, and I've challenged Max Lobovsky to a duel if we go to nationals...
Are you strictly saber?
University of Kentucky - Radio Free Lexington
"I would rather have a really big success or a really spectacular crash and failure then live out the warm eventual death of mediocrity" - Dean Kamen
Unread 14-12-2004, 23:09
tkwetzel's Avatar
tkwetzel tkwetzel is offline
Good Luck Teams!
AKA: Tyler Wetzel
FRC #0116 (Epsilon Delta)
tkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond repute
Send a message via AIM to tkwetzel
Re: sphere bot
Originally Posted by greencactus3
i just noticed. if you can have the spherical robot folded at the start and it folds out so the starting height limit is a little below the centerline of the sphere, then as much as other teams push you (assuming other teams robots only push from below the height limit), then they will not be able to push you (well they would, but) if you have a high traction, you can roll right over them no problem. anyone understand what im trying to say? please rephrase this then.
If it is a sphere bot, then it is as wide as it is tall....and the width and length starting dimensions are much smaller, so it would have to be folded a lot or inflateable which probably wouldn't be to efficient because it would take a while to inflate anything strong enough to be on a FIRST field.
See you in DC!
Unread 15-12-2004, 09:06
Joe Matt's Avatar
Joe Matt Joe Matt is offline
Wake Up Get Up Get Out There
Joe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond repute
Re: sphere bot
When you say Sphere bots, not only do I think of Samus, but I think of a omni-directional robot that can change position and direction at any time. Any propulsion ideas?
Unread 15-12-2004, 10:41
Squirrelrock's Avatar
Squirrelrock Squirrelrock is offline
I may be teh programmer?
AKA: Keegan
FRC #0414
Squirrelrock will become famous soon enoughSquirrelrock will become famous soon enough
Send a message via AIM to Squirrelrock
Re: sphere bot
Omni wheels. Set them at 45? to the sides of a square bot, and by changing the power to each wheel, you could theoretically control how fast and which direction the bot moved. If you wished to add an arm, then you could build a platform around the sphere at about 'waist' height. You could put the controls on the outside and have a pole sticking up and in to the exact center of the sphere above it. If you make the cord from this tower to the motors on the inside just a little bit longer than the shortest path around the sphere from the bottom to the tower, then the cord would roll itself around to the top side when needed. you may find a need to have a retractable cord (ie some sort of spring loaded winch) so that the length of the cord is not too long. the outer platform could be supported by teflon skids, or casters. Or, if you want to control the direction that the arm is pointing, then put omni wheels on the outside and power them, too. That would enable the outside to turn as well, but sort of ruins the idea of sphere propulsion.
i apologize for the disorganization of my thoughts, they usually happen that way . I've been working on this type of idea for about a year, on and off, but my team doesn't like it much. So, good luck to anyone who wants to try it, and tell me if works!
Squirrel
Look what I did to Dave:
Aaacckkk! Guurrkkk! Sssnorrrrkkkkk! Brain ... explode ... will. AAAArrrrggghhh!! Must ... not ... think ... about ... 2007 ... yet. Uuurrgghh!!! Still ... have .... to ... resolve ... how ... to ... pack ... parachutes ... for ... 2006 ... Ooorrrkkggnn!!
Sweet!
The scientists of today think deeply instead of clearly. One must be sane to think clearly, but one can think deeply and be quite insane.
- Nikola Tesla
Genius might be described as a supreme capacity for getting its possessors into trouble of all kinds.
- Samuel Butler
Unread 15-12-2004, 16:10
occra 23.
AKA: ryo
None #1481
Re: sphere bot
i was kinda thinking maybe a folding the shpere in eight peices. cutting it into 4 from each "side" of the box. then kinda swinging it in.. if there was a good strong light easy reliable way to do this with say,,, sheet metal, and cover the outside with some treads as to fit in the rules, maybe, but then again that just might not be strong enough. well a honeycomb structure sandwiched between two sheetmetal shperes. tediously welded together or sumthing.. mebe. but theres the lexan and heatgun idea again too. and for propolsion. probably try to have a thing inside the sphere that is independant of the shpere and rolls inside an easy omnishperical robot can be like
................______
............/....omnis...\
.............\....omnis.../
comprehende?
my idea is, you need easy access inside the sphere obviously, so why not just have it expand out from an open to a closed more stable structure.
Unread 15-12-2004, 20:51
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
Re: sphere bot
Originally Posted by Elgin Clock
Yeah.. We talked about making/buying one of our freshman a hamster ball to run around Atlanta in when we were looking for covers for our dome and I stumbled upon this site.
Run awaaaaaaaay!
http://www.mikesorrenti.com/
Unread 28-02-2005, 23:52
MConte05's Avatar
MConte05 MConte05 is offline
"Operation FIRST"
AKA: Matt Conte
#1098 (G.I.'s)
Team Role: Driver
MConte05 is on a distinguished road
Send a message via AIM to MConte05
Re: sphere bot
Sorry about bringing back an old topic. But.....
Since the build season is over with, I've been toying around with ideas to make an "off-season" bot strictly for fun. One ideas that I sorta devolped on was a sphere-bot, using 3 "wheels" which would really be custom made plastics that would fit around the frame and be powered by a CIM motor. All three of them would work off of the same motor, going in the same direction. The steering would be comprised of a pendulum sort of device that shifts the spheres center of gravity to one side or another to allow it to angle in and turn. I'm posting some sketches and Inventor models I made to help visualize this...... Any ideas or improvements would be greatly appricaiated!
Another idea I had was a belt driven spherebot. Where there would be 4 belts (driven independtly by 4 CIM motors) that control the direction and speed. I made a rather detailed Inventor model here:
Unread 01-03-2005, 00:14
scitobor 617's Avatar
scitobor 617 scitobor 617 is offline
More nerd than you can handle!
AKA: Alan Meekins
FRC #0617 (HSHS 617 "DUKE")
scitobor 617 will become famous soon enoughscitobor 617 will become famous soon enough
Send a message via AIM to scitobor 617
Re: sphere bot
Originally Posted by phrontist
How would you change the size of the sphere? If it were somehow inflateable, it seems too easy to pop. I can't see any other expansion method being robust enough to work consistently.
Looking at lbridgwater's robot it may be possible to place a blower inside that central pole and have the pole open on one end and drill venting holes below where you place the blower, such that when the blower was run it would pull air into the pole and exhaust it out into the robot thru the venting holes. Now all you have to do is figure out how to wire that motor. Not to sure if that could easily be done but thats an idea.
Beta testers needed!
http://www.nullagent.no-ip.com
Your kidding, there are other operating systems besides Linux?!
Unread 01-03-2005, 00:16
Herbie698 Herbie698 is offline
AKA: Lunchbox
Herbie698 is an unknown quantity at this point
Re: sphere bot
ill take you up on that idea and have one done before AZ Regionals...i'm full of ideas for this project...thanks for the idea...
Unread 01-03-2005, 08:33
MConte05's Avatar
"Operation FIRST"
AKA: Matt Conte
#1098 (G.I.'s)
Team Role: Driver
Re: sphere bot
Care to share?
Unread 01-03-2005, 17:33
MConte05's Avatar
"Operation FIRST"
AKA: Matt Conte
#1098 (G.I.'s)
Team Role: Driver
Re: sphere bot
Today I was messing around with a new frame shape.... Tell me what you think....
Unread 01-03-2005, 23:18
Daniel Brim's Avatar
Daniel Brim Daniel Brim is offline
It's hard hat time here in Boston
AKA: DFB
FRC #0125 (NUTRONS)
Daniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond repute
Send a message via AIM to Daniel Brim
Re: sphere bot
One problem with a sphere is that if the weight is not exactly centered, or not much weight is low, and you are nudged a bit from the side, you could get beached. I have seen little sphere-bots that you can buy in a kit (at radio shack I think). It was kind of like a tank drive, but the wheels conformed to the sphere shape and between the wheels there was a little space below. Unfortunately, while cool, they were cheep, so they didn't drive straight, but they did get I kid that I know in the 6th grade interested in robotics.
2003 (2002) - 2006 -- Team 294, Beach Cities Robotics
2007 (2006) - Present -- Team 125, NUTRONS
Unread 01-03-2005, 23:36
MConte05's Avatar
"Operation FIRST"
AKA: Matt Conte
#1098 (G.I.'s)
Team Role: Driver
Re: sphere bot
I was pondering that eariler today, and figured that if you made the center wheel flat, it would help keep it centered when upright. Also, having a "bar" stick out from the sides would help when turning to keep it from rolling over itself...... It would take a lot of precision to keep the CM in the middle.... but I think its possible. Maybe have a gyroscope help keep the weight under control? I'm not experienced in using them, but maybe if it senses it out of balence, it can adjust the weight (using a large weight on a slider) to compensate for the angle? Would require a lot of calculations though.....
This is an image I threw together in CAD showing the "flat bottom" center wheel and the bars on the side to help it when turning..... The red dots symbolize the CM.....
Unread 02-03-2005, 11:32
jdiwnab's Avatar
jdiwnab jdiwnab is offline
Really the Inventor Guy
AKA: Bryan Hartley
FRC #0617
jdiwnab is a jewel in the roughjdiwnab is a jewel in the roughjdiwnab is a jewel in the rough
Re: sphere bot
The model is very complicated and while there isn't a specific weight limit, you still don't want to be too heavy. Only the outer shell needs to be sphereical, not the frame inside. If you use tread like shown, then the tread on the sides would need to slip in order to go. this could create problems with driving and wear and tear. By putting a bar outside, and by making part of the sphere flat, you almost defeate the purpose of having a sphere bot.
I worked with Squril Rock (sp?) on this idea and we think the best thing would be to have a 1/2 structure withat has like omniwheels at the bottom. you could drive in any direction and if properly ballanced, the sphere would roll and the bot inside would stay upright.
Proof that Macs will win the platform war: How did Scotty know how to use MacDraft in Star Trek IV?
// random()
I have 100 gmail invites. PM me if you want one.
If they want us to think outside of the box, why do they make us fit in a 38x28x60 inch box?
Beware of Geeks bearing GIFs
Help me test my server software
Unread 02-03-2005, 12:50
MConte05's Avatar
"Operation FIRST"
AKA: Matt Conte
#1098 (G.I.'s)
Team Role: Driver
Re: sphere bot
For the sphere-bot plan that I came up with, I wasn't planning on it having a full and complete range of motion, such as being able to move left, right, forward, backwards, and still be able to roll. It would mainly be one big wheel that can tilt and turn as well...... if that makes sense?
worst experience mike pawlak Chit-Chat 15 06-12-2004 07:04
Help! My 2003 Bot compressor won't shut off Jack21 Control System 10 11-02-2004 12:24
Team 1072 (Harker Robotics Team)'s bot: Tork AlbertW Robot Showcase 8 19-02-2003 13:19
what did people think of my teams bot this year (263) Rob Colatutto General Forum 8 22-05-2002 19:03
Multiple Regional Winners and a little jab JamesJones General Forum 32 10-04-2002 23:38
