#16
Re: sphere bot
Oh, btw, I fence foil, and I've challenged Max Lobovsky to a duel if we go to nationals... Are you strictly saber? |
#17
Re: sphere bot
Re: sphere bot
When you say Sphere bots, not only do I think of Samus, but I think of a omni-directional robot that can change position and direction at any time. Any propulsion ideas?
#19
Re: sphere bot
i apologize for the disorganization of my thoughts, they usually happen that way . I've been working on this type of idea for about a year, on and off, but my team doesn't like it much. So, good luck to anyone who wants to try it, and tell me if works!Squirrel |
#20
Re: sphere bot
i was kinda thinking maybe a folding the shpere in eight peices. cutting it into 4 from each "side" of the box. then kinda swinging it in.. if there was a good strong light easy reliable way to do this with say,,, sheet metal, and cover the outside with some treads as to fit in the rules, maybe, but then again that just might not be strong enough. well a honeycomb structure sandwiched between two sheetmetal shperes. tediously welded together or sumthing.. mebe. but theres the lexan and heatgun idea again too. and for propolsion. probably try to have a thing inside the sphere that is independant of the shpere and rolls inside an easy omnishperical robot can be like
................______ ............/....omnis...\ .........../.......[]........\ ..........|........[].........| ...........\.......[]........./ .............\....omnis.../ ................-------- comprehende? my idea is, you need easy access inside the sphere obviously, so why not just have it expand out from an open to a closed more stable structure. |
#21
Re: sphere bot
Run awaaaaaaaay! ![]() |
#22
Re: sphere bot
Sorry about bringing back an old topic. But.....
Since the build season is over with, I've been toying around with ideas to make an "off-season" bot strictly for fun. One ideas that I sorta devolped on was a sphere-bot, using 3 "wheels" which would really be custom made plastics that would fit around the frame and be powered by a CIM motor. All three of them would work off of the same motor, going in the same direction. The steering would be comprised of a pendulum sort of device that shifts the spheres center of gravity to one side or another to allow it to angle in and turn. I'm posting some sketches and Inventor models I made to help visualize this...... Any ideas or improvements would be greatly appricaiated! Another idea I had was a belt driven spherebot. Where there would be 4 belts (driven independtly by 4 CIM motors) that control the direction and speed. I made a rather detailed Inventor model here: ![]() |
#23
Re: sphere bot
Re: sphere bot
ill take you up on that idea and have one done before AZ Regionals...i'm full of ideas for this project...thanks for the idea...
#25
Re: sphere bot
Care to share?
#26
Re: sphere bot
Today I was messing around with a new frame shape.... Tell me what you think....
#27
Re: sphere bot
One problem with a sphere is that if the weight is not exactly centered, or not much weight is low, and you are nudged a bit from the side, you could get beached. I have seen little sphere-bots that you can buy in a kit (at radio shack I think). It was kind of like a tank drive, but the wheels conformed to the sphere shape and between the wheels there was a little space below. Unfortunately, while cool, they were cheep, so they didn't drive straight, but they did get I kid that I know in the 6th grade interested in robotics.
#28
Re: sphere bot
I was pondering that eariler today, and figured that if you made the center wheel flat, it would help keep it centered when upright. Also, having a "bar" stick out from the sides would help when turning to keep it from rolling over itself...... It would take a lot of precision to keep the CM in the middle.... but I think its possible. Maybe have a gyroscope help keep the weight under control? I'm not experienced in using them, but maybe if it senses it out of balence, it can adjust the weight (using a large weight on a slider) to compensate for the angle? Would require a lot of calculations though.....
This is an image I threw together in CAD showing the "flat bottom" center wheel and the bars on the side to help it when turning..... The red dots symbolize the CM..... ![]() |
#29
Re: sphere bot
The model is very complicated and while there isn't a specific weight limit, you still don't want to be too heavy. Only the outer shell needs to be sphereical, not the frame inside. If you use tread like shown, then the tread on the sides would need to slip in order to go. this could create problems with driving and wear and tear. By putting a bar outside, and by making part of the sphere flat, you almost defeate the purpose of having a sphere bot.
I worked with Squril Rock (sp?) on this idea and we think the best thing would be to have a 1/2 structure withat has like omniwheels at the bottom. you could drive in any direction and if properly ballanced, the sphere would roll and the bot inside would stay upright. |
#30
Re: sphere bot
For the sphere-bot plan that I came up with, I wasn't planning on it having a full and complete range of motion, such as being able to move left, right, forward, backwards, and still be able to roll. It would mainly be one big wheel that can tilt and turn as well...... if that makes sense?
| worst experience | mike pawlak | Chit-Chat | 15 | 06-12-2004 07:04 |
| Help! My 2003 Bot compressor won't shut off | Jack21 | Control System | 10 | 11-02-2004 12:24 |
| Team 1072 (Harker Robotics Team)'s bot: Tork | AlbertW | Robot Showcase | 8 | 19-02-2003 13:19 |
| what did people think of my teams bot this year (263) | Rob Colatutto | General Forum | 8 | 22-05-2002 19:03 |
| Multiple Regional Winners and a little jab | JamesJones | General Forum | 32 | 10-04-2002 23:38 |
