Go to Post To change culture, you're going to have to get people to listen. - Yipyapper [more]
Unread 15-12-2004, 12:08
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Re: A Centralized Code Dump?
It's pretty easy to group files together. You can organize pages by adding them to categories that generate automatic listings of all elements in the categories (and can have subcategories) and you can mimic a file structure by just making the name of the page the name of the file ("/Kevin's Code/sensor stuff/sensor.c").
I know its not ideal, but its up and running now, and stuff can always be moved to a more useful storage later.
My main concern with some custom software is that it will fall into disrepair if it is something that only the FIRST community is using and that it will be too difficult to migrate to a different software (witness the old NRG repository). If MediaWiki software isn't the best, at least try to use some established piece of software so we can be assured of its longevity.
Team 1257
Unread 15-12-2004, 14:27
Bharat Nain's Avatar
SoundForge is better suited for this purpose as it is designed for such things. Wiki is good for overall data storage. Maybe we could use it as backup. As Dave said, lets wait till Jan.8 and see what happens. Or we could form something like FIRST Scouting Network and work our way from there. But I know that we definitely need some kind of place to store useful code and such.
-Bharat
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 15-12-2004, 14:38
Fold em oval!
The way SilverStar set up the SourceForge repository, it definitley is not an ideal solution. All submitions had to be posted in a sort of comment and reviewed by him. There was no easy CVS access (well, CVS would probably be too difficult for this, too. The majority of teams are not familiar with it).
The best dedicated solution that I know of is GraalForge, but again, I think that it is kind over complicated considering that the majority of code pieces being submitted will be in the <50 line range.
Team 1257
Unread 15-12-2004, 15:56
colt527 colt527 is offline
AKA: Ken Colton
FRC #0527
colt527 is a splendid one to beholdcolt527 is a splendid one to beholdcolt527 is a splendid one to beholdcolt527 is a splendid one to beholdcolt527 is a splendid one to beholdcolt527 is a splendid one to beholdcolt527 is a splendid one to behold
Send a message via AIM to colt527
Well, i was going to make a code dump for my teams website anyway. So if FIRST does release one I can use this for my teams site. I like making things from scratch (I just have urges to re-invent the wheel). I have pretty much everything already made, such as a user system and a file system, so with some merging its really not to much of a drudgery task to create one from scratch for me. So, we'll see what happens.
Mentor, Team 527 -- Plainedge Red Dragons
FIRST Volunteer
SUNY Stony Brook Computer Science 2010
kcolton@gmail.com
Unread 15-12-2004, 18:12
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
So i'm not the only one!
http://www.mikesorrenti.com/
Unread 15-12-2004, 20:51
doyler doyler is offline
Rookie / Programmer
#0900 (Infinity)
doyler is an unknown quantity at this point
That sounds like a great idea (the original code dump idea)
It would make things easier for up and coming programmers such as myself to find things and learn them
What is your most prefered programming language? Hailfire Programming 156 19-01-2005 21:42
Sourceforge for Code Repository and other stuff SilverStar Programming 9 15-01-2005 21:16
Does your team use the Default code. Jeff McCune General Forum 2 09-01-2003 14:46
