Go to Post Mmmmmmmm. Donuts! - Sean Schuff [more]
Unread 15-12-2004, 15:27
Stu Bloom's Avatar
Stu Bloom Stu Bloom is offline
I REALLY want to be Andy Baker
FRC #1018 (RoboDevils)
Stu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond repute
Send a message via AIM to Stu Bloom Send a message via Yahoo to Stu Bloom
Re: To Learn Inventor
Originally Posted by rmmlg
I've found that between reading the tutorials included with Inventor and some serious clicking around in the interface, it doesn't take much to teach Inventor to yourself. I have also found that teaching somethign to yourself helps one remember it better than reading it out of a to-do guide. That's just what worked for me and maybe it will work for some newbies this time around.
You might "remember it better" but what is it that you are remembering??
Just a word of caution from a voice of experience ... When you are learning by trial and error you learn whatever you stumble upon that works, which might end up being a very difficult way to do something that is really quite simple, not to mention how it could affect your downstream designing/modeling. There is a ton of utility and automation built in to these programs which you are likely to miss if you have no resource (teacher or book/lesson) to identify it for you.
Stuart Bloom
Mechanical Engineer
Rolls-Royce Corporation
FIRST Team 1018 - Pike HS RoboDevils
My activity for 2012:
  • Boilermaker planning committee
  • Israel Head Ref - DONE (and it was FANTASTIC!)
  • Boilermaker Regional (with 1018) - DONE
  • Midwest Head Ref - DONE
  • WORLD Championships (with 1018) - DONE
  • IRI Head Ref - DONE
  • CAGE Match Head Ref
Unread 24-12-2004, 16:26
rmmlg's Avatar
rmmlg rmmlg is offline
#0900 (Infinity)
rmmlg is on a distinguished road
That was why I read the tutorials as well. If you read the tutorials, the new features guide, and the index and such, then you shoudl be able to cover most of what you need to know. Other than that, you should have some kind of mentor to look over your drawings to make sure you are doing it correctly.
Ryan
Team 900 (Infinity)
Unread 25-12-2004, 14:58
vijay24's Avatar
vijay24 vijay24 is offline
Mechanical / CAD Lead
AKA: Vijay Umapathy
#1072 (Harker Robotics)
Team Role: Student
vijay24 is an unknown quantity at this point
Send a message via AIM to vijay24
Thanks for the ISBN on that book, looks very useful. I'm heading CAD on my team this year, and I was wondering, do we need to be using version 7 of Inventor to submit CAD files to FIRST?
Unread 25-12-2004, 16:50
telkanuru's Avatar
telkanuru telkanuru is offline
Generic Carbon Unit
#0246 (Overclocked)
telkanuru is an unknown quantity at this point
Send a message via AIM to telkanuru
If you do need to submit them to FIRST (do you?) you'll probly use Inventor 8, if that's what they're giving us this year. The difference between the editions is most likely negligable.
"He who has cares also has brandy."
-Gothe
Murphey was an optimist.
Unread 01-01-2005, 02:08
rmmlg's Avatar
#0900 (Infinity)
If you are using version x and FIRST is usign version 8, Inventor will import the files from the earlier verion x to version 8 (the version they gave us this year). (I presume you mean for the Autodesk award). Anyway, you might as well install 8 in case you decide to look at other peoples' files (if they used a later version than you are using). Inventor can import from earlier versions, but not later ones.
Ryan
Team 900 (Infinity)
Inventor to AutoCAD rmmlg Inventor 10 14-12-2004 21:26
Users Guide To Inventor R2K2D2 Inventor 5 11-01-2004 14:09
Successful Due to Affluence? indieFan Chit-Chat 4 31-05-2003 14:48
How did you learn how to use Inventor? Greg McCoy Inventor 26 24-05-2003 01:55
Inventor and Virtual Kit of Parts Torchin Inventor 1 09-01-2002 09:59
