Go to Post FIRST describes this program as students working "side by side" with professional mentors. We describe our team as working "shoulder to shoulder." Maximum learning happens with maximum interaction between students and mentors, whenever and wherever that may be. - jspatz1 [more]
Go Back   Chief Delphi > Other > Televised Robotics
Unread 16-12-2004, 01:16
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
Re: NASA TV Satellite Feed
Originally Posted by LBK Rules
Thanks Mr. Lavery!!!
Thanks to you, I now use NetTransport to DL almost everything now. It's a good program and I will probably use it to dl both streams as a backup, as will I try to do the same with a VHS recording.
The reason I want to do this is because (1) I would hope that someone who has the means would do this if I was incapable (2) a HQ recording would be awesome.
I recorded the 2004 kickoff on VHS, and now I want to record it on a PC. I have an AiW 128, and my dad has an AiW 9000. I should be able to use one of them.
EDIT:
Would any of these guides be good? Every time I try to re-encode an MPEG2 using VirtualDubMP2, I can never get the video to match to the audio. I think it's because it's Variable Bit-Rate, but I might be wrong.
http://www.doom9.org/index.html?/xvid-guides.htm
http://www.doom9.org/index.html?/gknot-main3.htm
What is an "AiW 128" and "AiW 9000"? I personally use a DV100 ( by dazzle ) and have used it to record video off my satellite. 99% of the time its synchronized and its good quality and as good or poor as I set it up to be.
Looks like NASA will be hiring soon... IMDWalrus NASA Discussion 3 08-03-2004 00:02
NASA Feed on Charter Cable TV dhendrix General Forum 9 24-03-2003 09:12
KSC Results archiver 2000 2 23-06-2002 22:19
Need help with satellite feed Adrian Wong Technical Discussion 13 05-01-2002 07:27
