Go to Post (OK, now that I have said this, just watch someone like Kevin Watson have a working solution by this Friday... :yikes: ) - dlavery [more]
Go Back   Chief Delphi > Other > Televised Robotics
Unread 15-11-2004, 00:34
LBK Rules's Avatar
LBK Rules LBK Rules is offline
1467 '06 Alumni
AKA: Anthony Rinaldi
no team (HSRO)
LBK Rules will become famous soon enoughLBK Rules will become famous soon enough
NASA TV Satellite Feed
We have one of those big satellite dishes in our back yard, and last year I recorded the Kickoff using it, but it took forever to set-up. Sometime in the past 7 months, the settings got messed-up, and now I can't find NTV anymore.
Does anyone know how to get this working?
The receiver is a Toshiba TRX-2220.
Anthony Rinaldi
Team 1132: 2003
Team 1467: 2004 - 2006
Unread 15-11-2004, 00:48
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Re: NASA TV Satellite Feed
What service do you have?
I'm assuming it is not Dish Network, because channel 213 (If I recall correctly) is NASA TV.
I'm assuming you had to manually dial in the transponder and adjust the azimuth?? All that happy stuff.
http://www.usfirst.org/robotics/2005/kickoff.htm
And here's the info about the webcast, and the Satellite broadcast.
NASA Webcast
The Webcast will be from 10AM est - 12PM est.
http://robotics.nasa.gov/first/2005/kickoff.htm is the NASA webcast site. Please check out the link early to be sure you have the latest technology needed to view the webcast.
NASA Broadcast
The NASA broadcast is scheduled from 10AM–12PM EST.
For Channel/Cable Channel/Dish/Satellite Broadcasts: NASA Television can be found on the satellite AMC 9, Transponder 9C, 85 degrees west longitude, vertical polarization downlink frequency - 3880 MHz, Audio is at 6.8 MHz.
Unread 15-11-2004, 07:33
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
It just so happens that if you live in the Boston area and have cable you should be able to also watch the kickoff or at least part of it. I know NASA television runs from 9am to some unknown time on one of these stations.
Unread 16-11-2004, 14:17
LBK Rules's Avatar
1467 '06 Alumni
no team (HSRO)
Same down here. I guess I'll just have to play around with the settings.
Anthony Rinaldi
Team 1132: 2003
Unread 15-12-2004, 15:36
LBK Rules's Avatar
1467 '06 Alumni
no team (HSRO)
Yippie!!!!!!!!!!
It's working now.
Would it be OK to BitTorrent the kickoff so that way teams won't have to rely on the low-quality webcast recording?
I just want to help, since my team isn't competing this year.
EDIT:
Does anyone have any experience encoding XviD or DivX from VBR-MPEG2?
Anthony Rinaldi
Team 1132: 2003
Unread 15-12-2004, 15:42
I'm guessing no since the webcast is sole property of FIRST and NASA, but don't quote me. Dave Lavery may know a good answer to that.
You don't want to infringe on any kind of copyright stuff.
But, I see where you are coming from and feel your pain.
Streaming video really sux, no matter what kind of connection you have.
It would be a lot easier if NASA allowed the Kickoff to be downloaded after the live stream was over, but as of now, I don't think that they do.
Unread 15-12-2004, 15:46
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
For this particular broadcast, for this particular purpose, Yes.
-dave
Unread 15-12-2004, 17:11
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
Hey Elgin check http://robotics.nasa.gov/first/2004/kickoff.htm they [NASA] always archives the webcasts and has them available for download after the event.
-Michael Dessingue
Unread 15-12-2004, 17:28
Again... Streaming Downloads.. Urghhh.. You can't save them bad boys.
-dave
Oh man.. I was shot down.. Gee thanks Dave..
Just kidding. That's cool. w00t! to the freedom to share information!
Unread 15-12-2004, 17:52
Shot Down again...
http://all-streaming-media.com/recor...dows-media.htm
Unread 15-12-2004, 19:27
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
More streaming recorders
For reference, I had the best luck with Net Transport for recording some regional streams last year.
Unread 16-12-2004, 01:03
LBK Rules's Avatar
1467 '06 Alumni
no team (HSRO)
Thanks Mr. Lavery!!!
Thanks to you, I now use NetTransport to DL almost everything now. It's a good program and I will probably use it to dl both streams as a backup, as will I try to do the same with a VHS recording.
The reason I want to do this is because (1) I would hope that someone who has the means would do this if I was incapable (2) a HQ recording would be awesome.
I recorded the 2004 kickoff on VHS, and now I want to record it on a PC. I have an AiW 128, and my dad has an AiW 9000. I should be able to use one of them.
EDIT:
Would any of these guides be good? Every time I try to re-encode an MPEG2 using VirtualDubMP2, I can never get the video to match to the audio. I think it's because it's Variable Bit-Rate, but I might be wrong.
http://www.doom9.org/index.html?/xvid-guides.htm
http://www.doom9.org/index.html?/gknot-main3.htm
Anthony Rinaldi
Team 1132: 2003
Unread 16-12-2004, 01:16
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
EDIT:
What is an "AiW 128" and "AiW 9000"? I personally use a DV100 ( by dazzle ) and have used it to record video off my satellite. 99% of the time its synchronized and its good quality and as good or poor as I set it up to be.
Unread 16-12-2004, 06:57
If anyone is interested in capturing these videos, please make a high quality XviD and a low quality video of a different file type (so people without the codec can still watch... ie. wmv, mpg1)
I will be able to host these of my team site, so long as everything is cleared to be legal. If not i guess we could do the bit torrent thing. Not saying that isnt illegal, but as Dave said for the purpose of sharing it with a few FIRSTers, I think it would be fine.
Unread 16-12-2004, 08:17
Noah Melamed's Avatar
Noah Melamed Noah Melamed is offline
FRC #0637 (Mr. T)
FTC #0030 (Mr. T)
Noah Melamed has a spectacular aura aboutNoah Melamed has a spectacular aura aboutNoah Melamed has a spectacular aura about
Send a message via AIM to Noah Melamed
The way to go is definitely Bit Torrent because there is less strain when more people want the video at any given time. No single host has to bear the bandwidth needs and because its a P2P network there is usually more bandwidth.
Any ideas on which Tracker you will use to host the Torrent?
Please keep us updated.
Thanks
Looks like NASA will be hiring soon... IMDWalrus NASA Discussion 3 08-03-2004 00:02
NASA Feed on Charter Cable TV dhendrix General Forum 9 24-03-2003 09:12
KSC Results archiver 2000 2 23-06-2002 22:19
Need help with satellite feed Adrian Wong Technical Discussion 13 05-01-2002 07:27
