Go to Post I love the smell of burnt motors in the morning! - Mike Betts [more]
Unread 16-12-2004, 23:28
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: crate design and construction
Originally Posted by chakorules
What SIZES is everyone's crate?
I assume we don't have to build a 4 ft x 4 ft crate do we? What size have you built that seems large enough for everything that you want to put in the crate?
Im pretty sure FedEx limits you to a maximum size that they'll accept for free shipping. You should be able to find this size in last years Manual.
2001-2004: Team 100
2006-Present: Team 254
Unread 17-12-2004, 18:11
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
I seen the rules, in last years PDF. But that wasn't what I was asking. What size crate did you guys build? I assume not everyone builds the MAXIMUM size of 4ft x 4ft do they? I heard one team built a crate 32" x 36" x 60". That's under the maximum size, but is that REALLY big enough for a robot, some tools, a dolly cart? I was simply asking a question about what other teams have built.
Originally Posted by ShadowKnight
FIRST releases that information when they release the rules. (So you'll know folowing the kickoff). FedEx imposes certain rules regarding size and weight. Exceeding those rules results in fees. If you're interested in shipping information from last year to give you some concept of what it should be like this year, visit: http://www2.usfirst.org/2004comp/11-...corporated.pdf or you can access all the documents available from FIRST at: http://www.usfirst.org/robotics/doc_updt.htm
Hope that helps.
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Unread 17-12-2004, 21:20
ShadowKnight's Avatar
ShadowKnight ShadowKnight is offline
FRC #1719 (Umbrella Corporation)
ShadowKnight has a spectacular aura aboutShadowKnight has a spectacular aura about
I misunderstood your post, so thanks for correcting me. It all depends on what you're actually putting inside the crate. Since you seem to be intending to store extras like a dolly and tools, you'll probably want to go for the 4 foot wide at least, possibly 4 foot long as well. Height though is completely dependant on the height of your robot and the height of your other things. I realize that doesn't really answer your question but I don't know specifically how much stuff you are actually taking, how big those items are (dolly for example, so I can't give you specific numbers to use. It's gonna have to be a judgement call. Just try to leave some leeway to make it easier to get the robot inside the crate.
Gracious Professionalism isn't simply courtesy or tradition, it's a way of life
I met her through FIRST...
We only are where we are by God's providence and by no other...
Unread 17-12-2004, 21:40
Controls Engineer
AKA: chakorules
Yeah it's a tough call. I know what you mean, hence why I was hoping to get more people to respond to this post.
We are trying to build our crate BEFORE the kickoff, but without knowing how high the robot will be, it's hard to build a crate before the kickoff. So I was trying to get an idea for the team what other teams have done.
Have you used the same crate over and over years past?
If so, then the height you have must be big enough for all the robots that your team has built in the years past?
Favorite CD quote:
Unread 17-12-2004, 22:00
yes, we have re-used our crate, so the height is large enoguh to accomodate any robot we're going to build. I would do the same, if for no other reason than not knowing what design you will use for '05. As a generall rule, a margine of 3-5 inches arount the footprint of each item would probably serve your purposes (you'd have to build it right and be able to take off the side walls, which you'd want to do anyway). You also might want to make a fair sized spot to throw spares and other things in...That should work. Worst comes to worse though, you could transport the tools another way.
Unread 18-12-2004, 02:32
Cory's Avatar
AKA: Cory McBride
Ours was actually too large so we had to cut it down to size when Fed Ex changed what size crates they were willing to take for free, so it's at the maximum size.
It makes it easy to put the robot, cart, some tools, batteries, control system, etc into the crate.
2001-2004: Team 100
Vertical Bar Field Construction Madison Technical Discussion 0 31-01-2004 19:23
How do you design your robot? Gui Cavalcanti General Forum 23 16-11-2003 18:33
In the spirit of Gracious Professionalism, I give you: My MultiDrive. Sachiel7 Technical Discussion 6 14-11-2003 19:59
White Paper Discuss: Dual-motor, dual-speed drive transmission design CD47-Bot Extra Discussion 9 03-09-2003 10:40
