Go to Post HOLY MOLY CANOLI THIS LOOKS LEGIT - MasterEric [more]
Unread 12-12-2004, 19:26
PCole's Avatar
PCole PCole is offline
Media / Website Mentor
AKA: Patrick
FRC #0384 (Sparky384)
PCole will become famous soon enough
Send a message via AIM to PCole
Animation w/ Radiosity
I've got a question..
I'm trying to animate a scene while using the Advanced Lighting feature - Radiosity. But it will only calculate one frame at a time.. how do I calculate the entire sequence while using Radiosity?
I imagine it will take it a long time but i'm just stuck on how to do it.. Thanks
Unread 12-12-2004, 21:24
rowe rowe is offline
Eric Rowe
FRC #1097 (Site 3 Engineering)
rowe has a spectacular aura aboutrowe has a spectacular aura about
Send a message via AIM to rowe Send a message via MSN to rowe Send a message via Yahoo to rowe
Re: Animation w/ Radiosity
Theres been a couple threads that have already addressed the issue of Radiosity in videos.
I would suggest you not use Radiosity in animation because you tend to lose the quality in compression that you get from the extra processing time. Radiosity also calculates for each individual frame, not for the entire sequence, so you tend to get flickering in the animation unless you have the quality turned up significantly (and because it is exponential, turning it up to those levels could leave you at a couple hours, if not more per frame). Instead of using Radiosity, I would experiment with placing different lights to mimic the effects of Radiosity.
Eric Rowe | Alumn
Team 1097 | Site 3 Engineering
2005 Silicon Valley Regional Finalists
2005 Silicon Valley Regional Sportsmanship Award
2005 Sacramento Regional Finalists
2005 Sacramento Regional Sportsmanship Award
2004 Silicon Valley Regional Sportsmanship Award
2004 Sacramento Regional Visualization Award
2004 Sacramento Regional Engineering Inspiration Award
Unread 13-12-2004, 15:40
kcy88's Avatar
kcy88 kcy88 is offline
Animator
AKA: Kevin
FRC #0075 (Roboraiders)
kcy88 is a jewel in the roughkcy88 is a jewel in the roughkcy88 is a jewel in the rough
Send a message via ICQ to kcy88 Send a message via AIM to kcy88
ahh yes. a reoccurring topic in these forums.
From my own experience, radiosity is not the way to go.
There are various rendering solutions you can use.
For example, for the Safety animation my team did, we used a Mental Ray shader called Ambient/Reflection Occlusion shader to generate Global Illumination(GI).
Here's a good link that explains more about the shader:
http://www.christopher-thomas.net/pa...ion_shader.htm
Or
you could always use skylight + an HDRI image.
These two are what I'm used to. I would recommend Final Gather, but I can't stand waiting for the looong calculations...
Good Luck!
Team 75 - Roboraiders
Hillsborough High School Robotics
2006 Boston Regional Autodesk Visualization Award
2006 Boston Regional Engineering Inspiration Award
2006 New Jersey Regional Engineering Inspiration Award
2005 New Jersey Regional Autodesk Visualization Award
2005 Duel on the Delware champions
2005 Brunswick Eruption 4 champions
Unread 13-12-2004, 16:13
Felipe Reis's Avatar
Felipe Reis Felipe Reis is offline
Wolfgang
AKA: Felipe
#1382 (Tribotec Team)
Team Role: Animator
Felipe Reis is on a distinguished road
The solution that 3ds max 6 offers is to calculate radiosity for one frame only, when you try to render a sequence they will loose all the data...
-One way to do it is to simulate the radiosity by placing lights targeted in a object....
"One Bone to Rigg Them All!"
1382 Animation Team
"TUPY or not TUPY?"
Unread 20-12-2004, 14:40
PCole's Avatar
AKA: Patrick
Thanks for the wonderful responses.. I wasn't to begin with but now I can see what you are saying..
A few more questions though..
What type of computer did you use to render out your safety animation, did you network render? and how long did it take for each frame or series of frames to render?
Thanks again
Unread 20-12-2004, 15:14
kcy88's Avatar
Animator
AKA: Kevin
Thanks again
For us, rendering was pretty quick. We were able to render 1000+ frames in two 1/2 days. It all depends on how you set up your scenes. On some of our scenes, I first rendered the background and then used that as the Environment Background. Bascially, only the objects that need to be rerendered are rendered and not the background. I'm not sure if i'm clear enough. For example, in my team's animation, I first rendered the wall and table with nothing on it, I saved that as an image file and then used that as the background. I then unhid everything and rendered that. This way, rendering is much faster; we averaged about 1min per frame.
Because Mental Ray does not allow net rendering with the demo, we had multiple computers render certain portions (ranges) of the same scene. This is possible since we output format is in targas.
Lol, One mistake I made was watching 30-1hour renders... for some of the scenes, I had the Sampling at 4min;16max. It would've taken us a week to finish rendering... But I saved time by lowering the sampling.
Overall, the average time it took to render a frame was about 10-15mins.
We had 4 main PCs that rendered the majority of the animation. A 3.0ghz (HT), 2.6, 2, and 1.8ghz.
I hope I've helped
Happy Animating
Unread 16-01-2005, 18:46
PCole's Avatar
AKA: Patrick
I'm still having some trouble with this shader.. is there any sort of instructions you know of that would be able to help me out getting this shader setup.. I checked out the link you gave me but that just gives me sample 3ds files it doesn't let you know how to set it up.
Thanks
FANATIC - Offseason Animation Competition opnickc 3D Animation and Competition 15 10-06-2004 20:54
A solution for Animation Judging for 2005 TKatsAniMentor 3D Animation and Competition 26 04-04-2004 15:29
A joke they called Regional Animation Competitions Lev 3D Animation and Competition 50 18-03-2003 21:18
How to develop your animation idea and keep your sanity too! Robby O 3D Animation and Competition 0 25-01-2002 01:25
the animation teams of F.I.R.S.T. animation teams are under appreiciated! Zeinin 3D Animation and Competition 11 14-01-2002 10:36
