Go to Post Remember, FIRST is about people. Robots are just what bring us all together... - Matt Attallah [more]
Unread 20-12-2004, 08:13
atmaturen atmaturen is offline
atmaturen is an unknown quantity at this point
Send a message via AIM to atmaturen
Question boolean
ello all,
i've seen to have forgotten how to declare a boolean variable...
any help would be greatly appriceated.
thanks in advanced.
(wow, my spelling is vile)
Unread 20-12-2004, 09:25
Re: boolean
There is no boolean variable type in C. Most people declare it as char (or unsigned char) and use the value 0 for false and 1 (or any value != 0) for true.
Through the use of #defines and typedefs, you can emulate it, though.
typedef unsigned char bool
#define TRUE 1
#define FALSE 0
Then just use the variable type bool and the values TRUE and FALSE.
Unread 20-12-2004, 09:26
Re: boolean
There isn't an explicit boolean type.
Typically, you use "char"
Unread 20-12-2004, 17:40
Re: boolean
do the boolean functions (and & not) work this way?
Unread 20-12-2004, 17:48
colt527 colt527 is offline
AKA: Ken Colton
FRC #0527
colt527 is a splendid one to beholdcolt527 is a splendid one to beholdcolt527 is a splendid one to beholdcolt527 is a splendid one to beholdcolt527 is a splendid one to beholdcolt527 is a splendid one to beholdcolt527 is a splendid one to behold
Send a message via AIM to colt527
Re: boolean
I'm not 100% sure if this wouldn't work, but my original thought would be it wouldn't.
char boolVar = 1;
if(boolVar)
//Do this
but for && and || and != they all work the same:
char var1 = 1;
char var2 = 0;
if(var1 == 1 && var2 != 1)
//do this
Mentor, Team 527 -- Plainedge Red Dragons
FIRST Volunteer
SUNY Stony Brook Computer Science 2010
kcolton@gmail.com
Unread 20-12-2004, 17:52
Electrical Engineer
Rookie Year: 1995
Re: boolean
Use this (http://www.lysator.liu.se/c/bwk-tutor.html) as a reference and you should be OK.
Mike Betts
As easy as 355/113...
Unread 21-12-2004, 17:56
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: boolean
In reply to previous concerns:
As long as you use the logical operators (&& || !) instead of the bitwise ones (& | ~ ^), you shold be ok.
If you need to use == and !=, I would recomend using one of this macros around the operands (the values being compared).
// CBOOL Converts to BOOLean
#define CBOOL(val) ((val) ? TRUE : FALSE)
// LOGically EQuivalent
#define LOG_EQ(val1,val2) (CBOOL(val1) == CBOOL(val2))
// LOGically Not EQuivalent
#define LOG_NEQ(val1,val2) (CBOOL(val1) != CBOOL(val2))
Unread 28-12-2004, 00:28
jude's Avatar
jude jude is offline
#0116 (Epsilon Delta)
jude is on a distinguished road
Send a message via AIM to jude
Re: boolean
You can get rid of the #defines by using an enum:
typedef enum {TRUE=1, FALSE=0} bool;
There's also a small practical benefit for this approach:
Some compilers will be able to do some extra type-checking against the enum values, and warn you if you accidentily try to do something like "bool b_Var = 5".
#define TRUE 1
#define FALSE 0
Unread 28-12-2004, 12:49
Raven_Writer's Avatar
Raven_Writer Raven_Writer is offline
2004 Detroit & Pittsburgh Winners
AKA: Eric Hansen
FRC #0005 (RoboCards)
Raven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really nice
Send a message via ICQ to Raven_Writer Send a message via AIM to Raven_Writer Send a message via MSN to Raven_Writer Send a message via Yahoo to Raven_Writer
Re: boolean
Assuming you're using MPLAB/CBOT, I think the #define method would be best. The method to use though is completely based on what makes you happy.
There's honestly countless number of ways to accomplish though. Like I said though, I think the #define method is best *not to mention, very short on the lines side*
AIM: wisprmylastbreth
EMail: nightskywriter@gmail.com
Y!: synsoflife
"ai yoru ga" -- "Love the nights"
Boolean statement blindguyinanorg Programming 2 15-02-2004 07:31
