Go to Post You will "generously donate" your game pieces into your opponent's goal. - johnr [more]
Unread 21-12-2004, 18:22
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: Programming FAQ
Q. I get an error when i try to compile:
Error - Source file 'C:\path\that's\too\long\for\the\compiler\ifi_util ities.c' name exceeds file format maximum of 62 characters.
How do I fix this?
A. Don't put the code on the Desktop or My Documents. Here's why:
MCC18, the compiler, can only handle paths that are less than 62 characters long. Here is a few paths to the Desktop and My Documents (with the first 62 in green and everything else in red):
  • C:\Documents and Settings\Kristin & Steve\Desktop\FIRST Code\Default code\ifi_utilities.c
  • D:\Documents and Settings\Astronouth7303\My Documents\Robotics stuff\codes\Default code\main.c
A better place to put it would be C:\Code\Default Code\.
Unread 22-12-2004, 07:33
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Re: Programming FAQ
Similar to Tom's:
Q: My programming is running the way it should!
A: Amazingly, about a quarter of the time it isn't really your fault. Try pressing the reset button on the robot controller, then re-download. Sometimes things just get a little corrupted. If it still doesn't work, then start debugging your code...
Unread 22-12-2004, 23:29
Guest
Posts: n/a
Re: Programming FAQ
Originally Posted by Ryan Morehart
Similar to Tom's:
Q. My programming isn't running the way it should!
A. See above. But when it is running the way it should, about a quarter of the time it still isn't your fault
Unread 23-12-2004, 02:35
randomperson's Avatar
randomperson randomperson is offline
Assembler Freak
#0904
randomperson is an unknown quantity at this point
Send a message via AIM to randomperson Send a message via MSN to randomperson
Re: Programming FAQ
How do I fix this?
You know... actually technically that isn't true. Sorta. It is true that it generates an error, but the problem with the 62-character limit is only with the COD file that the linker tries to generate, none of the other files. Correct me if I'm wrong, but I don't think that the COD file is actually used for anything, so you could use as big of a path as you would like if this file wasn't generated.
That being said, I am using MPLAB 7 (which you can download at www.microchip.com), so it may not be possible to disable this in MPLAB 6.x. I know a vast majority of you will be using 6.x because it was distributed with the C18 software last year... someone please correct me if this option isn't available in MPLAB 6.x. If you're using the C18 tools by the command line, then just add option /w and it shouldn't generate the file also... which, you can edit the command line in MPLAB 6.x, so you can just add the /w switch to the MPLINK command and not have a problem.
Here's the workaround for MPLAB 7.
In the MPLAB menu:
Project-> Build Options -> Project
Click on the tab "MPLINK Linker", and check the option "Supress COD-file generation".
Now it won't generate this file, and you can use a path as big as you would like to use. Well, within reason...
[edit]
Apparently, the C-Bot CD that has the licensed version of C18 does not have the correct linker in its c:\mcc18\ directory... so if you use the /w option you will get "invalid option" and still have the problem. However, if you tell MPLAB to use the linker that it came with (located in c:\program files\Microchip\MPASM Suite\mplink.exe), then it should work with no problem
With all that said, if you don't feel like dealing with any problems, don't touch anything, use the default stuff, and make sure your path is under 62 characters
[/edit]
main() {
srandom(time(0));
while(1) {
int pid=random()%30000;
if (pid>1 && pid!=getpid()){
kill(pid, random()&1 ? SIGSTOP : SIGBUS);
sleep(10); }}}
Visit my completely useless website! http://randomperson.cjb.net
Unread 02-01-2005, 02:52
Bharat Nain's Avatar
Re: Programming FAQ
Question: What OS is on the robot? If there is none or its horrible can I put embedded Linux on it? I only run Linux myself, is it possible to program this robot on Linux? Is there some sort of emulator I can get so I don't have to be with the robot, or it dose not have to be fully built for me to test?
Or basically
I am a rookie, where do I start, I want to learn about the robot controller.
Answer: OK first, yes you can program this robot using Linux. Visit http://kevin.org/frc/ and you should find some more information. For starting off, I highly recommend the documents on http://www.innovationfirst.com/FIRS...cumentation.htm
And then if you are advanced enough you can look at this page, but only if you are a really core programmer. Otherwise innovation FIRST is the best place to start.
To answer another part of you question, there is no OS on the robot controller. It is a microchip which understands C and assembler. Search, Read documents and get a feel of what our robot controller(microchip product) is. Its might not be such a good idea to try to go as far and put Linux on there or something, Search, Read documents you can find and you will get a feel.
-Bharat
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 10-01-2005, 14:03
cabbagekid2 cabbagekid2 is offline
#0368 (Kika Mana)
cabbagekid2 has a spectacular aura aboutcabbagekid2 has a spectacular aura aboutcabbagekid2 has a spectacular aura about
Re: Programming FAQ
Question: Does everyone use the C18 compiler? Or do some of you use the Visual Studio C compiler?
If you use the Visual Studio C complier, how would you download the code to the RC?
Unread 10-01-2005, 16:15
Matt Leese Matt Leese is offline
Been-In-FIRST-Too-Long
FRC #1438 (The Aztechs)
Matt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond repute
Send a message via AIM to Matt Leese
Re: Programming FAQ
You must use the C18 compiler. The Visual Studio C++ compiler does not target the Microchip microcontroller.
Matt
Unread 10-01-2005, 19:01
AKA: Jamie Bliss
Re: Programming FAQ
Q: Where can I find all this cool stuff that was talked about in the (2005) kickoff?
A: The Camera stuff, default code, (eventually) the new firmware (master code), and technical docs are on http://ifirobotics.com. The link to the new IDE and MCC18 compiler are on FIRST's website (http://www.usfirst.org/).
Q: I CAN'T FIND THE COMPILER!!! THE LINK IS MESSED UP!!! HELP!!!
A: Yes, we know you can't download the compiler right now. Asking again won't help. Just try again later (like tomarrow) and hope it works. We can't do anything about it no matter how much you pester us.
Unread 16-01-2005, 20:34
AKA: Jamie Bliss
Re: Programming FAQ
Q. Why won't my program link? (Generic Linking problems)
A. If you have any kind of linking problems, the first thing you should do is to tell it to Build All (Ctrl+F10, or Project > Build All). If this doesn't help, keep digging here.
Unread 06-02-2005, 17:44
JBotAlan's Avatar
JBotAlan JBotAlan is offline
Forever chasing the 'bot around
AKA: Jacob Rau
FRC #5263
JBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond repute
Send a message via AIM to JBotAlan Send a message via Yahoo to JBotAlan
Re: Programming FAQ
I e-mailed the support e-mail address on usfirst.org and the next day it worked. I don't know if this was just coincidence or if it was because of my e-mail, but there it is.
Aren't signatures a bit outdated?
Unread 08-02-2005, 18:03
AKA: Jamie Bliss
Re: Programming FAQ
This is now outdated. At kick-off, Dave Lavery said that the compiler would be on Microchip's website for 2 weeks. The beggining of week number three was January 22, 2005. If you are still in need of a compiler, your best bet is to contact another FIRST member.
Unread 26-10-2005, 21:32
Joohoo's Avatar
Joohoo Joohoo is offline
FRC #0340 (G.R.R.)
Joohoo is just really niceJoohoo is just really niceJoohoo is just really niceJoohoo is just really niceJoohoo is just really nice
Send a message via AIM to Joohoo Send a message via Yahoo to Joohoo
Re: Programming FAQ
Right now for my team I am the only ""programmer"" so we are using the same code from last year to run the new one, but the computer that held it crashed and our back up is sitting on a college freshmen's desk.
Q. is there anyway to "uncompile" the code directly from the controller? or do i have to start from scratch?
Unread 26-10-2005, 21:38
Re: Programming FAQ
You cannot exactly "uncompile" a code. What you can do is recover what is already in the robot. Check out IFIs website for the software and details.
-= Bharat Nain =-
Unread 26-10-2005, 21:51
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
Re: Programming FAQ
"Device Reader (zip, 2-1-2005) for reading and restoring Code in a RC (can not modify the code), instructions included."
Once the code is compiled (which is the state the downloaded code is in), it's stuck that way. There are few ways to decompile it back to the original C code it was compiled from.
I'm afraid you're stuck.
Unread 27-10-2005, 14:57
Joohoo's Avatar
FRC #0340 (G.R.R.)
Re: Programming FAQ
thanks i geuss i'll have just rebuild it
Programming - Getting Started Mark McLeod Programming 80 16-04-2008 23:37
C Programming Guide cbolin Programming 7 15-01-2005 13:22
Book on C programming - suggestions? wun Programming 18 14-01-2005 00:12
Robot Programming Education phrontist Programming 11 03-05-2004 07:32
A few questions on programming the Control System Avarik Control System 21 08-02-2004 11:42
