Go to Post How many of the team's current students were even alive when those awards were earned? :) - Alan Anderson [more]
Thread Tools Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Unread 16-12-2004, 20:08
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
Booting Linux off iPod
Well I'm bored, so I'm gonna try to do random stuff that will have absolutely no point whatsoever. Is there any way that I can boot linux (preferably knoppix) off of my iPod?
http://www.mikesorrenti.com/
Unread 16-12-2004, 20:34
nathanielreindl's Avatar
nathanielreindl nathanielreindl is offline
Triumphant Return from the Depths
AKA: Fiction
FRC #1451
nathanielreindl is an unknown quantity at this point
Send a message via ICQ to nathanielreindl Send a message via AIM to nathanielreindl Send a message via Yahoo to nathanielreindl
Re: Booting Linux off iPod
The iPod, from what I understand, acts just like a Firewire disk, so theoretically, if you're able to boot off of Firewire, you should be able to boot from it.
Um, the catch is whether or not you're able to retain use of the iPod as, well, an iPod. Chances are that putting something boot-related on that disk will cause the iPod's software to barf or something similar.
Unread 16-12-2004, 20:36
Mike's Avatar
AKA: Mike Sorrenti
I'd boot it through my USB, I think I would have to somehow partition the iPod drive to let it do what I want it to do... maybe I'll just buy a cheap 3rd Generation 'pod off ebay and not risk losing all my music files
Unread 16-12-2004, 20:43
AKA: Fiction
FRC #1451
You know, if you're willing to go that route, a bus-powered USB hard drive might do you just enough justice as an iPod would. You should be able to pick up a 20GB 2.5-inch 4200RPM Samsung drive (read: a drive with a warranty of at least 3 years) somewhere for relatively cheap, and the enclosure is something like $20-30 on top of that. Just an idea. Might even be cheaper and/or worth the little bit of extra cash even.
Unread 16-12-2004, 20:48
Mike's Avatar
AKA: Mike Sorrenti
Heh, I just wanted the bragging rights of saying "I booted Linux off an iPod" Figuring out how to do something is half of the fun.
Here's a tutorial I found on partitioning the iPod, unfortanetly he does it via linux. So maybe I'll boot knoppix off a CD, partition my iPod, load the knoppix image on my iPod, set BIOS to go to my USB drive, and try to boot from the iPod... who knows, it might be crazy enough to work.
Tutorial (From googles cache):
http://64.233.161.104/search?q=cache:Tt8t2giTHiUJ:www.codepoetry.net/archives/2004/08/27/partitioning_the_ipod.php
Unread 16-12-2004, 21:00
AKA: Fiction
FRC #1451
Aha. Just like I liked having bragging rights about booting my old ThinkPad 560Z off CompactFlash. I thought that's what you were going for, but I thought I'd prod some and make sure.
Actually, that's OS X (or Darwin) from the looks of it. Linux doesn't have device names like /dev/disk2s2; they're usually something along the lines of /dev/sdtX or /dev/hdtX, where t is [az] and X is any unsigned integer [1,255]. And pdisk is PowerPC-specific.
Mind you, this is all true unless you're running udev on top of Linux; then, you're dealing with an altogether different beast...
You're going to have to install an MBR on that hard drive in order really to boot from it, I think. Or set a partition under 1024 cylinders bootable.
Unread 16-12-2004, 21:03
Mike's Avatar
AKA: Mike Sorrenti
Hmm, 7 pages into the Google search results and I still haven't found anything. I'll post at a few linux forums and see what they say.
Unread 16-12-2004, 22:27
Kyle Fenton Kyle Fenton is offline
GET IT ON!!
FRC #0121 (Rhode Warrior)
Kyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud of
Send a message via AIM to Kyle Fenton
While it is possible to boot an OS off it is highly not recommended. The iPods use the 1.8 in drives. These hard drives were not meant to be continuously access say to other laptop hard drives. These hard drives will build up a lot of heat in a relatively little amount of time. The reason why the iPod has a 32 mb buffer is so that the hard drive can be accessed at low speed to gently build the playlist you have on there.
I remember when I was erasing the data off my iPod it became so hot that I couldn't hold it for long. I thought it was going to melt.
People have booted almost every system off the iPod, so there isn't much bragging rights to be had. A normal USB or Firewire hard drive will serve you much better.
Rhode Warriors
NAVSEA/Raytheon/URI/Middletown, Portsmouth, Tiverton, Mt. Hope HS
Quality Robots Since 1996
Unread 16-12-2004, 22:41
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
There is a version of Debian Linux that will run on a machine with the Motorola 68030 16Mhz processor (Such as the Macintosh SE/30) and probably 16Mb of RAM. I think that is pretty cool. And then once you have linux, you can run Apache. Let me know if you want some info.
Unread 17-12-2004, 15:21
Mike's Avatar
AKA: Mike Sorrenti
Most distros of linux come with apache, mysql, php, phpmyadmin, cgi, python, ftp, etc.
Unread 22-12-2004, 11:44
GET IT ON!!
I just found this interesting piece of software where you can use Linux on your iPod. Looks cool, maybe I will try it one day.
http://ipodlinuxinstl.sourceforge.net/
Rhode Warriors
Unread 22-12-2004, 12:26
MikeDubreuil's Avatar
Carpe diem
FRC #0125 (Nu-Trons)
I think an important disctinction must be made. Do you want to boot your personal computer from a linux install on the iPod (iPod acts as a disk drive) or do you want your iPod to boot into Linux (the iPod is the computer)?
Most sites everyone is referring to are about the iPod running Linux.
Trouble booting Linux from hard drive after CD install edomus Technical Discussion 2 01-11-2004 08:03
Using Linux? Raven_Writer IT / Communications 41 05-07-2004 16:53
Linux SteveC116 3D Animation and Competition 22 25-03-2004 15:07
