Go to Post I bet if anyone took a look at the 118's Bill of Materials the only thing that would be on there is hard work and that's priceless. - rcmolloy [more]
Unread 23-12-2004, 02:29
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
pic: Shifting Mechanism 222
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Unread 23-12-2004, 02:30
tkwetzel's Avatar
tkwetzel tkwetzel is offline
Good Luck Teams!
AKA: Tyler Wetzel
FRC #0116 (Epsilon Delta)
tkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond repute
Send a message via AIM to tkwetzel
Re: pic: Shifting Mechanism 222
How much of that shaft did you manufacture yourself? I am especially interested in the internal shaft.
See you in DC!
Unread 23-12-2004, 09:41
Andrew Schuetze's Avatar
Andrew Schuetze Andrew Schuetze is offline
499 Founder / Alamo FTC & FLL AP
Andrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond repute
Thumbs up Shifter mech.
Kudos to your design team ,
My question for you, "What device do you use to engage the three detent positions on your shifting shaft?" I've seen small pnuematics on two speed trannies and even built a CD two speed using the drill planetary set using a servo. I have some doubts about a servo having enough torque for this applicatin
APS
APS
Founder FRC 499
Parent alumni FRC 2745 & 4219
Co-Coach FTC 4549 & 6407
Alamo FTC Affiliate Partner
Alamo FLL Affiliate Partner
Unread 23-12-2004, 11:06
AKA: Bradley Rigdon
I didn't machine the shafts because of the level of accuracy that they needed to be; I was busy making other components of the robot/transmision.
Everything on our robot is built in Tunkhannock High School by students with the help of mentors.
The only thing we had to "outsource" for these transmissions from the school was the shafts and gears to get heat-treated, since our school does not have this capability.
They were made in the school and then taken to some company for the heat treating.
Shifting Question:
Our transmission really does not take that much strength to change gears. The main thing they need to shift is accuracy. We used two small pneumatic cylinders to shift.
On cylinder moved the transmissions to either first gear or third gear; the other cylinder was used to wedge the shifting forks into second gear. This required the cylinder that shifts the gears from first to third to become pressureless.
Here is the best pic I can find at the moment:
http://www.tigertrons.com/2004/2004bot3.JPG
Also more pictures can be found here:
http://www.tigertrons.com/pictures.htm
Unread 23-12-2004, 11:53
Stu Bloom's Avatar
Stu Bloom Stu Bloom is offline
I REALLY want to be Andy Baker
FRC #1018 (RoboDevils)
Stu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond repute
Send a message via AIM to Stu Bloom Send a message via Yahoo to Stu Bloom
Very, very nice ... do you have any drawings and/or CAD files you wish to share??
Stuart Bloom
Mechanical Engineer
Rolls-Royce Corporation
FIRST Team 1018 - Pike HS RoboDevils
My activity for 2012:
  • Boilermaker planning committee
  • Israel Head Ref - DONE (and it was FANTASTIC!)
  • Boilermaker Regional (with 1018) - DONE
  • Midwest Head Ref - DONE
  • WORLD Championships (with 1018) - DONE
  • IRI Head Ref - DONE
  • CAGE Match Head Ref
Unread 23-12-2004, 13:50
AKA: Bradley Rigdon
No drawings that we wish to share with other teams on the shafts sorry...
We have drawings, but I and I think WE (THE TIGERTRONS) feel that you should do some designing/calculating on your own.
I feel that building/designing a transmission should not be something that you can just build from a piece of paper.
Our team went out on the branch in the 2004 season and built this transmission from scratch with little help from outside sources. This was the first transmission we have ever built; we always used the drill motors and transmissions on our robot since 1996, up until the 2004 season.
None the less they worked!
I will give you these important dimensions though:
The biggest part diameter of this shaft is 1''
The smallest is 3/4'' to allow for output gearing/smaller bearings
The ball bearings we used were 5/16''
The inside hole for the shaft is 33/64''
The plunger that pushes the ball bearings into the gears is approximately 1/2''
The smaller hole that keeps the 5/16'' ball bearings from fall through the shaft is 9/32''
Unread 04-01-2005, 17:10
[527]phil's Avatar
[527]phil [527]phil is offline
Alumni
AKA: Phil
FRC #0527 (red dragons)
[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light
Send a message via AIM to [527]phil
I'm assuming that whoever machined that part either used a horizontal swiss type cnc lathe, or a 3 axis vertical milling machine with an A axis mounted table. also a part like that doesn't have an extremely hight tolerance space, I'm used to alot more, where the part has to be within 300 thousands of the original, but nonetheless it is a precision part. I'm curious of whether the main part of the internal shaft, is that created of a single piece of material?, or is a couple threaded together?
Whats the difference between mechanical engineers and civil engineers?
Mechanical engineers build weapons, civil engineers build targets
Unread 04-01-2005, 17:18
AKA: Bradley Rigdon
Nope, we used regular lathe and a 3 axis mill with a digital readout!
All we have at the school to used that is computer controlled mill. The thing is that we do not really know much about how to use it. We did make some simple gears and plates on it last year though.
I can make parts, but I would hate to mess something up that we or I spent hours machining, therefore I let the more experienced machinest make it!
The shaft pictured above is all one piece. It is A2 tool steel.
The main problem was that after machining it the dimensions changed after being hardened.
Unread 04-01-2005, 17:24
[527]phil's Avatar
Alumni
AKA: Phil
The dimension change is inevitable with a hardening process. And don't worry about messing up part, last year i made axles out of aluminum bars by milling the key slot with my max NC cnc milling machine and when i was setting it up i adjusted for the width of the material, but forgot to adjust for the width of the endmill so they didn't fit into the sprockets .
Unread 04-01-2005, 17:50
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Did you find it was really neccesary to use tool steel (that must have been fun to machine...) and harden it? Was there enough wear to warrant it?
Team 1257
Unread 05-01-2005, 18:01
AKA: Bradley Rigdon
You could probably get by a season without hardening the shaft, but since we have not tested doing so I could not tell you what the results would be.
Here are the measurements I got from the gears; I do not have the shaft measurements for between each gear.
Third Gear:
1.014''
Second Gear:
1.001''
First Gear:
1.001''
Being that we used second gear the most it had the least amount of wear because it was not able to "freewheel'' on the shaft.
Overall the shaft was at 1.008'' in diameter, I am not sure of what it was when it was after being machined.
pic: Tigertrons 222 Memorial Day Parade CD47-Bot Extra Discussion 11 17-06-2004 14:51
pic: 222 2001-2004 robots CD47-Bot Extra Discussion 16 20-05-2004 21:09
pic: 222 3 speed closeup/cutaway CD47-Bot Robot Showcase 64 25-04-2004 15:25
pic: 222 3 speed on the robot CD47-Bot Robot Showcase 6 11-03-2004 21:39
pic: Team 60 Mechanism CD47-Bot Robot Showcase 2 11-02-2004 21:47
