Go to Post I happen to know that there is a back-order status from Exide. Seems for some reason people are ordering this product - Mike Martus [more]
Go Back   Chief Delphi > Technical > Robotics Education and Curriculum
Unread 23-12-2004, 13:08
Burg's Avatar
Burg Burg is offline
I'm my own idol
AKA: Nick Burgwin
#1620
Burg is an unknown quantity at this point
Multi-Speed motor Questions
These motors, from the robovation kit, didn't come with any information and I haven't been able to find much about them. I was wondering how much power do they have? Are they capable of lifting an object, if the setup was properly designed?
Any help would be great, Thanks.
Unread 23-12-2004, 13:19
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Multi-Speed motor Questions
Peak power looks to be about 2.2-2.3 Watts. This would be the limiting factor in just how fast you can lift something if you perfectly design your motor. 2.3 Watts = 1.7 foot pound-force/second. So with a 100% efficient lifting device, you could lift a 1.7 pound weight at 1 foot per second or a 3.4 pound weight at .5 feet per second, assuming you got the gearing just right.
Generally speaking, most motors can lift a surprisingly large amount of weight, assuming you gear them down enough.
In a general sense, http://www.innovationfirst.com/FIRST...edu-motors.htm gives you a rough torque-speed curve. You can use this to figure out just how fast the motor will turn at a given torque load. Designing around peak power is just highly useful in situations where you have a well-defined load or range of loads.
Side note: Last year I designed around peak power to figure out how much to gear down the window motor to lift our robot at max speed. Or more precisely, at close to max speed with enough safety factor to lift an entire second robot at decent speed.
Unread 23-12-2004, 15:54
Burg's Avatar
I'm my own idol
AKA: Nick Burgwin
#1620
sweet, just the thing I was looking for. Thanks alot for the help. I'm averaging about 3 pounds, after more thought. Time restriction is nothing much to worry about. I was just curious if the motors could even take it.
Thanks again!
Joining 2 dif. motors K.Shaw Motors 32 14-10-2004 19:40
PID control loops - closed loop feedback KenWittlief Technical Discussion 56 26-04-2004 21:27
not quite sure...speed controller...spike. tophq Programming 8 26-03-2004 13:43
Multi Speed Dual Motor Gearbox tenfour General Forum 14 08-09-2003 13:09
Power, speed, and torque... AGH Gui Cavalcanti Technical Discussion 5 10-11-2002 19:02
