Go to Post Off season is a good way to go outside the district. - 346CADmen [more]
Unread 23-12-2004, 12:20
Karthik1's Avatar
Karthik1 Karthik1 is offline
830 Alumni
AKA: Karthik Chokkaram
FRC #1504 (Desperate Penguins)
Karthik1 is a name known to allKarthik1 is a name known to allKarthik1 is a name known to allKarthik1 is a name known to allKarthik1 is a name known to allKarthik1 is a name known to all
Help with inventor!
OK I have been using inventor for a while now like a few months, and I haven't had much trouble until yesterday. I caught on pretty quickly because I took a course on auto-cad.
Well any way I was working on some drive train stuff. I started with this picture of a frame then I dimensioned it, thats when it started acting weird. A wall appeared where I left the dimension and I couldn't get rid of it. I tried looking at it from different views and tried different sketch modes. I even tried closing it and opening it. Then I turned of my computer and today I tryed to make something and This wall still appears. I can't get rid of it. The thing is I use dimensions all the time and this is the first time i ran into something like this.
Here are some pictures of the wall, sorry they are so small.
http://solisstyle.com/ims/pic.php?u=767j25F4&i=2886
http://img.photobucket.com/albums/v3...nsionwall2.bmp
"freedom is voluntary self control” Mahatma Gandhi
Unread 23-12-2004, 12:32
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Help with inventor!
Whoa. That's quite obviously not an issue with your using dimensions. It looks like some bug in inventor, actually. Half the screen just isn't getting rendered. Is this happening just with this file or all files?
Either way it seems to be a bug of some sort and you should try calling AutoDesk or updating Inventor if there's a patch out.
Unread 23-12-2004, 12:45
Karthik1's Avatar
830 Alumni
It happens only when I start a new dimension. All my old drawings are fine, but if I go back and add a new dimension this wall appears.
Unread 23-12-2004, 12:49
Stu Bloom's Avatar
Stu Bloom Stu Bloom is offline
I REALLY want to be Andy Baker
FRC #1018 (RoboDevils)
Stu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond repute
Send a message via AIM to Stu Bloom Send a message via Yahoo to Stu Bloom
I sent you a PM. Send me the file and I will take a look at it for you. What version of Inventor are you using? It could also be a problem with compatibility with your graphics card/driver.
Stuart Bloom
Mechanical Engineer
Rolls-Royce Corporation
FIRST Team 1018 - Pike HS RoboDevils
My activity for 2012:
  • Boilermaker planning committee
  • Israel Head Ref - DONE (and it was FANTASTIC!)
  • Boilermaker Regional (with 1018) - DONE
  • Midwest Head Ref - DONE
  • WORLD Championships (with 1018) - DONE
  • IRI Head Ref - DONE
  • CAGE Match Head Ref
Unread 23-12-2004, 13:20
Karthik1's Avatar
830 Alumni
I use inventor 5
I know it's really old but it gets the job done.
Unread 24-12-2004, 16:23
rmmlg's Avatar
rmmlg rmmlg is offline
#0900 (Infinity)
rmmlg is on a distinguished road
FIRST gave each team 25 licenses of Inventor 8. Why don't you stick that on your computer. There's not that much difference between 5 and 8, but it is less likely to have bugs and it will automatically update all your files from version 5 to version 8.
Ryan
Team 900 (Infinity)
Unread 24-12-2004, 19:34
Karthik1's Avatar
830 Alumni
All our Inventor 8 licenses are used for our cad lab. Inventor 5 is the only thing we have left.
Unread 01-01-2005, 02:11
rmmlg's Avatar
#0900 (Infinity)
Have you e-mailed or called Autodesk technical support. In the past, I have found them to be very willing and helpful.
Ryan
Team 900 (Infinity)
Unread 04-01-2005, 00:21
JasJ002's Avatar
JasJ002 JasJ002 is offline
Inventor Freak
AKA: Jay
FRC #0662 (Cybersonics)
JasJ002 is a jewel in the roughJasJ002 is a jewel in the roughJasJ002 is a jewel in the roughJasJ002 is a jewel in the rough
Send a message via AIM to JasJ002
Talking Re: Help with inventor!
Ok people before you all go blaming inventor on this one I think i know what the problem is. If you all look at the picture more closely you'll see that the xy, yz, and xz planes are highlited in a special way. What you are see are those planes. There is probably some setting that you changed to where those planes are always visible. I would ask autodesk about that before you go searching for some type of bug. This is just me talking though. Actually now that I look at it closer I think that there might be a button that you simply have to push. If you look at your toolbar you'll see two sets of yellow boxes. I think if you click the right one it might go back to normal. I'm not that familiar with inv 3 I've only used 7, 8, & 9. Good luck and if you have any questions feel free to ask me.
Unread 10-01-2005, 09:44
SirLancelot SirLancelot is offline
AKA: Anna
FRC #1502 (Technical Diffaculties)
SirLancelot is on a distinguished road
Question Re: Help with inventor!
So, did we all get Inventor or autoCAD? Because it seems that our team only got AutoCAD and no inventor programs.
Inventor to AutoCAD rmmlg Inventor 10 14-12-2004 21:26
**FIRST EMAIL**/Autodesk Inventor Training and Technical Questions Information Rich Wong FIRST E-Mail Blast Archive 0 07-12-2004 17:22
12 in. Wheel in Inventor 7 petek Inventor 1 17-01-2004 17:53
Autodesk Inventor Award 2002 Digo Inventor 1 24-03-2002 12:07
Inventor and Virtual Kit of Parts Torchin Inventor 1 09-01-2002 09:59
