Re: 2005 Pneumatic Kit
The pnuematics info on this 2005 site looks like last years stuff. |
EDIT: Doug G beat me to it. |
I use the TI pressure transducers regularly. They work well unless at high temp when the temp induced error is rather high. I don't think that part number is correct though because I can't find the cut sheet at the TI sensors web site. The 2CP5 (custom dash #) is what I use for refrigerant applications. I will link to that cut sheet because I believe this is a similar part. I don't usually work with the controller but what do we have for inputs? 0-5V? 4-20 mA?
http://www.ti.com/snc/pdf/2cp.pdf |
If you look closely, the picture of all the pneumatic parts are different. In the new...2005 one, it shows the rotary actuator in the actual picture. Last year it was available, but wasn't on the picture diagram.
#7
When I was making sure we had received everything in our kit, I noticed the pre-2004 pressure switch sensor is back this year. The TI analog pressure sensor is gone.
#8
It's too bad if the TI sensor is missing though (it was an optional sensor last year but has a lot of interesting applications). I hope it was just from your kit and not gone gone. We didn't get ours with our kit last year. Well I guess we can still use last year's TI this year since we didn't use it on our previous robot. |
#9
The TI sensor is no longer part of the kit. Quote:
![]() Last edited by Greg McCoy : 08-01-2005 at 21:08. |
| need standard kit gearbox | Korbin | Kit & Additional Hardware | 0 | 15-11-2004 21:18 |
| [Official 2005 Game Design] OK, so YOU design the 2005 game... | dlavery | FRC Game Design | 37 | 26-10-2004 23:15 |
| Your Thoughts on the 2005 Championship Eligibility Criteria! | dez250 | Championship Event | 57 | 10-09-2004 14:59 |
| Q&A Discuss: How many Van door motor(s) come with the kit? | CD47-Bot | Extra Discussion | 1 | 08-01-2003 11:07 |
