ello all,
i've seen to have forgotten how to declare a boolean variable... any help would be greatly appriceated. thanks in advanced. (wow, my spelling is vile) |
Re: boolean
There is no boolean variable type in C. Most people declare it as char (or unsigned char) and use the value 0 for false and 1 (or any value != 0) for true.
Through the use of #defines and typedefs, you can emulate it, though. Code:
typedef unsigned char bool #define TRUE 1 #define FALSE 0 |
Re: boolean
Typically, you use "char" |
Re: boolean
do the boolean functions (and & not) work this way?
Re: boolean
I'm not 100% sure if this wouldn't work, but my original thought would be it wouldn't.
char boolVar = 1; if(boolVar) { //Do this } but for && and || and != they all work the same: char var1 = 1; char var2 = 0; if(var1 == 1 && var2 != 1) { //do this } |
Re: boolean
Re: boolean
In reply to previous concerns:
As long as you use the logical operators (&& || !) instead of the bitwise ones (& | ~ ^), you shold be ok. If you need to use == and !=, I would recomend using one of this macros around the operands (the values being compared). Code:
// CBOOL Converts to BOOLean #define CBOOL(val) ((val) ? TRUE : FALSE) // LOGically EQuivalent #define LOG_EQ(val1,val2) (CBOOL(val1) == CBOOL(val2)) // LOGically Not EQuivalent #define LOG_NEQ(val1,val2) (CBOOL(val1) != CBOOL(val2)) |
#8
Re: boolean
You can get rid of the #defines by using an enum:
typedef enum {TRUE=1, FALSE=0} bool;
Some compilers will be able to do some extra type-checking against the enum values, and warn you if you accidentily try to do something like "bool b_Var = 5". Quote:
#9
Re: boolean
Assuming you're using MPLAB/CBOT, I think the #define method would be best. The method to use though is completely based on what makes you happy.
There's honestly countless number of ways to accomplish though. Like I said though, I think the #define method is best *not to mention, very short on the lines side* |
| Boolean statement | blindguyinanorg | Programming | 2 | 15-02-2004 07:31 |
