Go to Post Stupid rules are not meant to be broken; they're meant to be changed. Unless and until they are changed, breaking them is wrong. - Alan Anderson [more]
Go Back   Chief Delphi > Technical > Robotics Education and Curriculum
Unread 29-12-2004, 01:24
Burg's Avatar
Burg Burg is offline
I'm my own idol
AKA: Nick Burgwin
#1620
Burg is an unknown quantity at this point
Running the robot using Infa Red?
An idea came to mind while I was sitting here just looking at my PPC, controlling the robovation bot using IR, but is this even possible? Maybe not for the actual competition *It can't...I'm pretty sure* but for an...extra outside kind of thing? Could it be done?
I would need the reciever on the bot, and the PPC can reach 30feet, if I need more I can build a larger sensor thingy *I'm not in the state for technical words, 8 hours of sleep in 2 days* But the software for the PPC would have to be programmed, and would it even connect to the robovation computer?
Just a...thought that might be cool to explore. Thanks for any help
Unread 29-12-2004, 01:38
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Re: Running the robot using Infa Red?
I know there are infrared modems with serial connections. Plug one in to the Robovation controller, and figure out how to communicate with it and you should be able to read data sent from any compatible IR device.
Team 1257
Unread 29-12-2004, 03:17
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Yes, this can be done. Have a look at the 2004 IR receiver code to see how the receiver side can be implemented, and the beacon code for the transmitter side. It wasn't just by chance that I named the two different beacon waveforms "0" and "1" <grin>. The code and documentation is kept here: http://kevin.org/frc/2004. Let me know if you need help.
-Kevin
Kevin Watson
http://kevin.org
Unread 29-12-2004, 11:37
Fold em oval!
Ah, that's even easier. No need to buy new parts. Mr. Watson, do you know if these two beacon waveforms are used in IR modems in laptops and PDAs to transmit data?
Team 1257
Unread 29-12-2004, 13:58
FRC #2429
Originally Posted by Max Lobovsky
...do you know if these two beacon waveforms are used in IR modems in laptops and PDAs to transmit data?
No, it's not likely, but the software can be tweaked to work with just about any protocol if the data rate isn't too high. What protocol do you want it to work with?
-Kevin
Kevin Watson
http://kevin.org
Unread 30-12-2004, 00:52
Burg's Avatar
I'm my own idol
AKA: Nick Burgwin
#1620
-Kevin
Wow, didn't think I'd get that kind of reply...thanks I have a lot to look into, but before I do, I want to double check on something...I can't use IR for the competition to control my robot...correct?
Even if I can't, I could just build the desired circuit from you're links on you're site, but I didn't get any of those parts in the Kit...so what happens now?
It all looks interesting, I have some reading to do
Unread 30-12-2004, 01:01
FRC #2429
The parts are pretty inexpensive. Sources are listed in the FAQ.
-Kevin
Kevin Watson
http://kevin.org
Unread 30-12-2004, 12:31
phrontist's Avatar
phrontist phrontist is offline
Proto-Engineer
AKA: Bjorn Westergard
FRC #1418 (Vae Victus)
phrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond repute
Send a message via AIM to phrontist
-Kevin
Yeah, the parts are cheap, go for it! We found out the hard way because the ones that came in the kit were FUBARed.
University of Kentucky - Radio Free Lexington
"I would rather have a really big success or a really spectacular crash and failure then live out the warm eventual death of mediocrity" - Dean Kamen
How much planning goes into your robot? Jnadke General Forum 41 29-01-2006 21:29
what kind of robot will win? Bcahn836 Championship Event 44 12-04-2004 00:02
YMTC: Bluabot sits on Redabot Natchez You Make The Call 19 08-04-2004 16:43
Beatty's 2004 Robot mzitz2k General Forum 81 26-03-2004 15:18
about how Drive Train push the robot... shouldn't the force accelerate the robot? Ken Leung Technical Discussion 12 26-11-2001 09:39
