Go to Post For some strange reason, people always seem to spell my last name incorrectly. I'm not really sure why. - Karthik [more]
Go Back   Chief Delphi > Technical > IT / Communications
Unread 30-12-2004, 17:37
Denman's Avatar
Denman Denman is offline
Tie Wrap-Not Cable Tie or Zip tie
AKA: Stephen Denman
FRC #0759 (Systemetric)
Denman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud of
Send a message via ICQ to Denman Send a message via AIM to Denman Send a message via MSN to Denman Send a message via Yahoo to Denman
creating new boot disk
Right, i want to upgrade my 80gb harddrive to 160 gb. i have both drives and can run them simultaneously.
Is there any working software for copying the whole partition on one drive to the other?
i tried maxtor something or other but it got about 20% then said to try again after defragging and scandisking, which i have done.
any help is appreciated in advance
I am an ex-member of team 759.
759: regional winners with 522 and 233 NYC (2004)
FIRSTWiki.org - Contribute, learn, inspire.
"Teach the way of the GP and the way of the GP shall teach you" - Me
Unread 30-12-2004, 17:44
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: creating new boot disk
so you need to copy the partition table, partitions, and MBR without breaking the addressing byte size? I'm not sure you can.
There's a difference in how sectors are addressed in an 80GB drive and a 160GB one. So a straight copy may mean that you can only access the first 127GB (?) of disk space.
Unread 30-12-2004, 18:22
Venkatesh Venkatesh is offline
FRC #0030
Venkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to behold
For the purposes of this answer, I am going to assume that your 80GB (current boot and main) drive is an IDE disk, on the first channel, and connected as master. And I am going to assume that the new 160GB disk (the master-to-be) is an IDE disk on the first channel, connected as slave. I am also going to assume each disk is set up with one large partition, the whole size of the disk.
First, backup anything that is important. You can never have too many backups.
Second, download a Knoppix linux CD and burn that image. Knoppix is a LiveCD, a disc that contains a version of Linux which does not need to be installed. If you are familiar with linux, good. It will really help while doing this.
You will need to boot into Knoppix and mount your hard drives. To do that, boot from the CD, open a terminal window once KDE has loaded, and type:
su (switches to root user)
mkdir /1 (makes a directory called 1 in the root area)
mkdir /2 (makes a directory called 2 in the root area)
mount /dev/hda1 /1 (mounts your existing hard disk in /1)
mount /dev/hdb1 /2 (mounts your new hard disk in /2)
cd /2 (move to /2 directory)
tar -cvzf 1.tgz /1 (archive /1 into a .tar.gz file)
mv 1.tgz 1.tar.gz (rename 1.tgz to 1.tar.gz)
gunzip 1.tar.gz (ungzip 1.tar.gz)
tar -xvf 1.tar (unpack that tar file)
The reason I recommend you to use tar rather than a direct copy is simple. You can store that 1.tar.gz file on another computer or a reliable medium, and have a record of your computer which you can restore from in case of disaster. After you are done with the above steps, you are free to swap the positions of your IDE devices. You will need to boot using a Windows 2000/XP install CD into the recovery console and run "FIXMBR", but then the swap will be done.
This is not an exercise to be taken lightly. If you did not understand any step above, do not try it.
Edit: I forgot about Norton Ghost. It should be able to do the whole process automagically. I have never used it and cannot comment on its use(ful/less).
-- vs, me@acm.jhu.edu
Mentor, Team 1719, 2007
Team 30, 2002-2005
Unread 30-12-2004, 19:28
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
I highly recommend the Ultimate Boot CD
It's a compendium of useful utilities on one bootable CD. I think in this case, you can use HD Clone, as it says it supports copying one drive to a larger drive.
EDIT: after copying, use one of the partition resizing tools to claim all the extra space on the HD.
Unread 30-12-2004, 20:25
REVving up for a new season
FRC #2848 (All-sparks)
very very easy
format the new HD into 2 partitions both NTFS (80 gb each)
go get a copy of norton ghost and you can do 1 of two things
you can ghost the hard drive straight to each other or you can create a ghost image of your drive then burn that image to the new drive very simple.
you might also want to get a copy of partition magic it is also a good tool if you need to modify your partition sizes
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 30-12-2004, 21:03
Stephen,
When I upgraded the drive in my notebook I used a kit from Drive Solutions and this software came with it. EZ GIG II
http://www.apricorn.com/product_details.php?ID=381
I loaded the cd and ran it, followed the instructions and walked away and went to dinner. It will make copies of partitions as well. When complete you just install the drive as the first bootable and turn the system on. I followed this with Partition Magic to divide the drive into useable sections. First related stuff lives on E:
Unread 30-12-2004, 21:18
I'll note here that the Ultimate Boot CD is free, while norton ghost and partition magic will cost you various amounts to try. So I think all you stand to lose from trying it is however long it takes.
Unread 31-12-2004, 01:12
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
Out of curiosity, why not just keep both harddrives installed and use both? You can never have too much storage!
Unread 31-12-2004, 11:07
Michael Hill's Avatar
Ghost IS very awesome for 2 normal hard drives hard drives. For some reason, ghost does not like USB external hard drives. I know it should handle them seemlessly, but when I tried to install a version of the (still beta) Windows XP 64-bit edition, I found all my drivers were messed up (like I expected). But...when I tried to go back to normal XP, I found the ghost didn't save onto the external USB drive. Therefore, I lost everything. Luckily it is a fairly new laptop and I didn't have a lot of irreplacable things, but it was still a monkey-butt to install my CAD software again.
Unread 31-12-2004, 13:38
Denman's Avatar
AKA: Stephen Denman
Hi
Thanks Kevin Sevcik. It worked ! (well sort of. i still need to find my copy of partition magic ... i know i have it around here somewhere..... (even if its like a year or so old))
Thanks everyone
Stephen
(oh and i'm giving the old hard drive to my brother , as i'm too skint to buy another one for his pc i'm building.)
Thread can be locked if needed to be now
Unread 31-12-2004, 16:44
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
Hi
You need the latest version of Partition Magic to use it in XP. I know my version of 6 fubared my computer when I tried to use it anyways.
Wetzel
OCCRA Disk 2004 JoeFryman OCCRA 2 23-10-2004 17:07
Creating Videos Raven_Writer IT / Communications 13 20-06-2004 23:48
Creating no pressure with double solenoid? Combat Chuck Pneumatics 7 29-02-2004 22:45
Operator Interface Problems - Won't Boot Jamie_Richard Control System 1 14-02-2004 17:20
Need help in creating program to use servo's to shift drive archiver 2001 19 24-06-2002 00:35
