Go to Post Take care of home and family first- then we play robots - Wayne C. [more]
Go Back   Chief Delphi > Technical > IT / Communications
Unread 30-12-2004, 17:44
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: creating new boot disk
Originally Posted by Denman
Right, i want to upgrade my 80gb harddrive to 160 gb. i have both drives and can run them simultaneously.
Is there any working software for copying the whole partition on one drive to the other?
i tried maxtor something or other but it got about 20% then said to try again after defragging and scandisking, which i have done.
any help is appreciated in advance
so you need to copy the partition table, partitions, and MBR without breaking the addressing byte size? I'm not sure you can.
There's a difference in how sectors are addressed in an 80GB drive and a 160GB one. So a straight copy may mean that you can only access the first 127GB (?) of disk space.
OCCRA Disk 2004 JoeFryman OCCRA 2 23-10-2004 17:07
Creating Videos Raven_Writer IT / Communications 13 20-06-2004 23:48
Creating no pressure with double solenoid? Combat Chuck Pneumatics 7 29-02-2004 22:45
Operator Interface Problems - Won't Boot Jamie_Richard Control System 1 14-02-2004 17:20
Need help in creating program to use servo's to shift drive archiver 2001 19 24-06-2002 00:35
