Go to Post All I want for Christmas is a better game hint, a better game hint, a better game hint... - Schnabel [more]
Unread 30-12-2004, 19:03
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Overloaded functions
In my header file, I have the following function prototypes:
int abs(int);
float abs(float);
In my source file, I have the following functions:
int abs(int x)
  if(x>=0)
    return x;
  else
    return -x;
float abs(float x)
  if(x>=0)
    return x;
  else
    return -x;
I also have a whole bunch of other overloaded functions. (I know this isn't the best example, but it's short.) However, when I compile it, I get a lot of "type mismatch in redeclaration of 'abs'" and "redefinition of 'abs'" errors. Does the C18 compiler not support overloading, or am I doing something wrong that I'm overlooking?
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 30-12-2004, 19:05
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Re: Overloaded functions
If I'm not mistaken, overloadable functions was added in C++ and is not possible in C.
Team 1257
Unread 30-12-2004, 19:08
jgannon's Avatar
I ᐸ3 Robots
AKA: Joey Gannon
Hm... that's unfortunate. Is there any way to get the equivalent of overloading, without making two separately named functions? I guess this is what happens when a TI-BASIC/C++/Java programmer tries to do C.
_
Unread 30-12-2004, 19:18
Fold em oval!
Well for this example, you could easily just cast to int and use the same function. (You could cast to int in all cases, even when it already is an int, to maintain uniformity). I can't really think of any other way.
Team 1257
Unread 30-12-2004, 22:51
Electrical Engineer
Rookie Year: 1995
IMHO, no one would ever want to work with floating point at all in an embedded system like this. It makes no sense.
JMHO...
Mike Betts
As easy as 355/113...
Unread 31-12-2004, 11:04
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
The only thing I can think of is to use a macro
#define ABS(num) ( ((num) >= 0) ? (num) : (0 - (num)) )
which will work for any numeric type you give it.
But I still wouldn't use floating point.
New Serial Port Driver Kevin Watson Programming 16 09-01-2005 01:56
Trigometric Functions cibressus53 Programming 4 25-10-2004 21:49
Do you write functions for your code? Max Lobovsky Programming 26 11-03-2004 07:04
Important functions of a first robot? Ianworld General Forum 5 15-04-2003 13:29
Primary Functions Poll Ben Mitchell Rules/Strategy 1 16-02-2003 02:10
