Go to Post We figured it out. - benjiengi [more]
Go Back   Chief Delphi > Technical > IT / Communications > Computer Graphics
Unread 30-12-2004, 21:04
stevek's Avatar
stevek stevek is offline
AKA: Master of the Sweatshop
FRC #0230 (GaelHawks)
stevek has a spectacular aura aboutstevek has a spectacular aura aboutstevek has a spectacular aura about
Re: How do you upload an analog video onto a computer?
Another solution that may not cost you a dime. I assume if you have edit software you have a capture card, so if your asking this question, you're card is DV. If you have that you may have or can barrow a Digital Camera (Digital-8, Mini-DV or what ever has DV I/O on it) YOu can typically connect the output from one camera to the input of the other (assuming you have the cables for both Cameras, you can use barrels (Female-Female coupler adapter or patch it through a VCR) This is taking Analog out of Cam 1 to Analog In on DV Camera. Then you will have a Tape that you can feed into your computer via Firewire. NOTE: Some DV Cameras don't allow Analog In for Recording, so you have to try it and see. If it doesn't work borrow another!
If this works for you, great. I've used this to tranfer from VHS Tapes to get into an edit- prior to buying an Analog-DV Convertor. Now I use a AVID Mojo that has both Analog and DV I/O. But both of these methods cost money, while the above method is Free of Charge if you can get your hands on the Equipment.
Unread 30-12-2004, 21:42
Jeff K.'s Avatar
Jeff K. Jeff K. is offline
Hmm..now what?
FRC #1138 (Eagle Engineering)
Jeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond repute
Send a message via AIM to Jeff K. Send a message via MSN to Jeff K.
Pinnacle
I prefer Pinnacle because the editing software is really easy to work with and also I got the Studio AV/DV http://www.pinnaclesys.com/ProductPa...50&Langue_ID=7
It's really easy to install the card into your computer and if I'm correct, also has a 4-6 pin firewire cable - 30 bucks, the software - 80 bucks, and the card is also analog video imput, the yellow one, and firewire, has 2 ports of each -30 bucks, and I got that at Costco for only 80 bucks, I think good deal, but you still need to find a way to import the sound, but it also includes the RCA adapter - Dont know how much, to change the red and white wire into the stereo plug ins for connecting it into a microphone port in your computer. I see it as a good deal because getting everything seperate can run you up to about...150 bucks including tax or somewhere around there.
And good luck with your project
GizMOE Revealed - NEW VIDEO from team 365!! SuperJake Robot Showcase 14 25-03-2004 22:35
Projection TV's and Video Inputs (Xbox, Computer) MattK Chit-Chat 9 31-01-2003 00:53
List of UTC Hartford Teams archiver 2001 3 24-06-2002 01:09
Good video footage miketwalker General Forum 0 28-03-2002 17:14
A&E Special Amadkow Chit-Chat 4 11-08-2001 00:40
