Go to Post Team 71: So good at Strategy they already have figured out next years game before the GDC has even met. - IKE [more]
Unread 29-12-2004, 11:20
gnormhurst's Avatar
gnormhurst gnormhurst is offline
Norm Hurst
AKA: gnorm
#0381 (The Tornadoes)
gnormhurst will become famous soon enoughgnormhurst will become famous soon enough
External Lens for optical mouse
I've seen various suggestions on the web to use an optical mouse as a position sensor. What a great idea: it's non-contact, so it won't wear out from use. And it's pretty accurate(?). And it uses a serial (but synchronous) interface that outputs delta x and y values as 7 or 8 bit values.
And they're relatively cheap.
One big problem is that optical mice are not designed for the speeds at which FIRST robots move. They work by correlating subsequent snapshots from a very low-res imager (18x18). If the mouse moves so fast that two snapshots are of completely different (non-overlapping) areas, then correlation won't work.
Yesterday I did an experiment with my computer's opitcal mouse. I took an old 35mm camera lens and held the mouse behind it so that the lens focused an image on the bottom of the mouse. It was tricky to find the right spot, but when I did, I could point it at a lamp across the room and, as I tilted and panned the lens, the mouse cursor moved very nicely, just like using a mouse pad. Except that the effective mouse position was moving feet, not inches! I had optically reduced the sensitivity of the mouse.
This is very intriguing. One obvious application would be to aim it down at the carpet and track x/y robot motion. Perhaps it could even be used aimed horizontally (at the stands or whatever, focused at infinity?) to measure yaw.
Potential snags: mice work well when there is some "acceleration" or other non-linearity applied. If this is applied by the driver after the mouse sends linear delta x/y values, then no problem. But if this happens inside the mouse, it could be a problem. I think some mice are different than others; I think some can be configured over their bidirectional serial line.
Another snag is that PS/2 mice use a synchronous interface, not async like standard "serial" ports. I've heard that the TTL port on the PIC can be used for sync operation, but who knows how??
Here's the claim that the PIC TTL port can support sync interface:
http://www.chiefdelphi.com/forums/sh...29&postcount=6
Comments?
Trenton Tornadoes 381
2004 Philadelphia Regional Winners
2006 Xerox Creativity Award
My corner of the USPTO.
My favorite error message from gcc: main is usually a function
My favorite error message from Windows: There is not enough disk space available to delete this file.
Unread 29-12-2004, 11:32
Aignam's Avatar
Aignam Aignam is offline
This Space For Sale
AKA: Anthony Mangia
#1257 (Parallel Universe)
Team Role: Scout
Aignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant future
Send a message via AIM to Aignam Send a message via Yahoo to Aignam
Re: External Lens for optical mouse
I have no idea if this is useful or relevant, but Laser Technology is beginning to dominate over Optical Mice.
Some Thoughts to Ponder
How does a sign turn into a lady friend? Don't optional stop signs ruin the purpose? What are pneumatics? Am I really banned from 229 for life? Can walls get bigger?
Aignam. Pronounced A-Num. Mangia backwards.
NJFIRST.org | Best Thread. Ever.
AIM: Aignam | ICQ: 265237569 | E-mail: AnthonyMangia@aol.com | HTTP: www.aignam.com
Unread 30-12-2004, 21:18
m&mengineering m&mengineering is offline
AKA: Marv Kraska
#0440 (Ford First)
m&mengineering is an unknown quantity at this point
Comments?
That's exactly why our teams have been looking into this technology for the past 2 years. Great minds do indeed think alike! :-)
Maximum speed of the correlator is about 14 inches per second, if memory serves. Now if that were feet per second, we could just drag the mouse behind the robot to get x-y info.
Very interesting light experiment. We always tried to lens both the light and imager, never tried just pointing it at a lamp. Didn't have much success with our tests - the image on the correlator must have to be pretty bright for it to work.
Note the mouse could be used as a linear (or 2-d) position feedback sensor.
The PS2 mouse protocol specifies commands to reduce effective resolution, and disable acceleration (scale) functions. Every mouse is different, but some basic commands must be the same for compatibility reasons.
Well, the TTL serial port can do sync serial, but the mouse protocol is more of a master/slave protocol, so our teams found it necessary to use another PIC processor to handle the communcations. See the attached image with a stand-alone board that accumulates and displays the mouse counts on a LCD display. I can post more info if there is some interest in developing the mouse as a robot sensor.
m&mEngineering
Last edited by m&mengineering : 30-12-2004 at 21:31. Reason: forgot to add attachment
Unread 30-12-2004, 22:20
gnormhurst's Avatar
Norm Hurst
AKA: gnorm
Apparently there are more great minds. Check out this thread, which was recently started as a place for people to share ideas on the subject:
http://www.chiefdelphi.com/forums/sh...ad.php?t=31999
Unread 07-01-2005, 19:07
bigqueue bigqueue is offline
#0811 (A.R.C.)
bigqueue will become famous soon enough
Send a message via AIM to bigqueue Send a message via Yahoo to bigqueue
Hmmm....what a great idea. What a great "re-use" of existing proven technology. This is a great example of how good engineering is done. (generally, always on the backs of people who came before them....not always "reinventing the wheel")
Live free or die....
Looking for Mouse part Mr. Lim Electrical 3 27-12-2004 19:56
Optical Mouse / Ball Mouse Clark Gilbert Chit-Chat 26 22-07-2004 13:17
IS THIS RIGHT?!?!? RebAl General Forum 22 31-03-2002 00:07
All these mouse bots gives me an evil idea- CAT BOTS! Patrick Wang General Forum 2 09-03-2002 22:43
