Go to Post Theory is when you know everything but nothing works. Practice is when everything works but you don't know why. On our team, theory and practice comes together. Nothing works and nobody knows why. - CalTran [more]
Go Back   Chief Delphi > FIRST > Rumor Mill
Thread Tools Rating: Thread Rating: 7 votes, 3.86 average. Display Modes
  #286   Spotlight this post!
Unread 31-12-2004, 20:02
phrontist's Avatar
phrontist phrontist is offline
Proto-Engineer
AKA: Bjorn Westergard
FRC #1418 (Vae Victus)
phrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond repute
Send a message via AIM to phrontist
Re: Official 2005 Clue Thread
Originally Posted by Paradox1350
Except that filtering wouldn't matter; you would need some sort of camera to process the light and then output it onto a monitor. Our eyes cannot see IR light, or UV light. If you filter it, you are only filtering out the stuff that isn't it, but you aren't changing its wavelength, and thus it's not visible.
Now if FIRST wanted to hook up IR cameras and put monirtors in the driver's pit, that'd be swank. ^_^
By the way, anyone ever wonder if FIRST would make it so that we didn't decide where our bot started, but our opponents did? That wouldn't make the IR beacon in a random/changing spot, but it WOULD make the bot NEED to use some sort of poisitioning system (IR) to figure out where it is . . . although this has nothing to do with the clue . . .
As for Pi, what if the objects on the field were frisbees? I doubt it, since there's no easy way to throw it over the shielding (unless you are extremely good at hte hammer-toss) but FIRST has used all sorts of balls, boxes, doughnot-beanbag-thingies, and even a pleaying field with corn kernals as the turf. Frisbees would be fun, and not hte wierdest thing ever ^_^
Oh man. I they did that all of my hard work will have been for nothing. I just assumed that we could depend on a known starting position. How will I navigate! Ahhhhhh!
University of Kentucky - Radio Free Lexington
"I would rather have a really big success or a really spectacular crash and failure then live out the warm eventual death of mediocrity" - Dean Kamen
  #287   Spotlight this post!
Unread 31-12-2004, 21:30
Tim Delles's Avatar
Tim Delles Tim Delles is offline
Since 2001.
FRC #0078
Tim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond repute
In FIRST you can never assume anything to be, especially starting places. You can only assume things when FIRST directly tells you. (and sometimes you can't even think that to be fully true. jk )
Timothy Delles - Clarkson University
2011 - Present: FRC Team 78 - AIR Strike
2011 - Present: VEX Team 78 - AIR Strike
2010 - 2011: FRC Team 3280 - Rhode Rebels
2001 - 2009: FRC Team 229 - Division By Zero
  #288   Spotlight this post!
Unread 31-12-2004, 21:40
phrontist's Avatar
Proto-Engineer
Well, with a good navigation system, your robot only has to know for sure where it is for a moment based on sensor data or axiomatic declaration in the game spec, then it can figure it out from their. I doubt FIRST would position our robots randomly realative to scoring objects, as it would make it too challenging for the vast majority of teams.
  #289   Spotlight this post!
Unread 31-12-2004, 23:20
thoughtful's Avatar
thoughtful thoughtful is offline
FRC #1219 (Emery Iron Eagle)
thoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to behold
First of all some of this might already be posted so i apoligize if i am just repeating what you mgith have read. Here are my opinions
1. Amethyst is a hexagon shaped crystal, also optical filters of that kind are used to study UV rays. Seeing this i agree with the suggestions that the teams might be 3v3 or 2v2v2, and that IR guidance might play a greater role.
2. I dont know much about baseball, but given that the John Neun and george burns have 3 as a very common number i would say that the matches might be 3 minutes or alliances of 3.
3. I would like to mention that the value of Pi is 3.14 could this be hinting that the total time for a match will be 3 minutes and 15 seconds. Also Pi is 22/7 does that bring anything in mind, if it does please do post.
4. "Look closely and you will see something between Pi, You and Me". Pay close attention this might be refferring to the fact that "you and me" are between Pi. Which can mean that the robots are in a pyramid or triangle shaped area. Also the riddle mentions looking closely;hence there might be something which very hard to see or cant be seen through human eyes, Again this hints toward IR
My conclusion:
The alliances will be 3v3, the field will remain rectangular. Autonomous will have a greater role to play. There will be IR or other navigational guidance. Also i beleive there will be some items in the center that one has to gather most to make points. The multiplier will be back.
PS:- I would be laughing at myself once the game is unvieled
.:Bringling Brains to Life:.
03,04,05-Team 1219 Captain
2003 Rookie all Start @ GTR
2005 Galileo Semi-Finalist & Alliance captain
06-Team 1219 Mentor
2006 Radio Shack Innovation in control @ Waterloo
  #290   Spotlight this post!
Unread 01-01-2005, 00:12
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
Hmm this makes sense, 15 seconds for autonomous and 3 minute matches, with 3v3 more teams can play thus matches can be longer.
Matt Krass
  #291   Spotlight this post!
Unread 01-01-2005, 00:24
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Also Pi is 22/7
No it isn't.
  #292   Spotlight this post!
Unread 01-01-2005, 00:27
Michael Leicht's Avatar
Michael Leicht Michael Leicht is offline
Drive Coach
FRC #1403 (Cougar Robotics)
Michael Leicht has a reputation beyond reputeMichael Leicht has a reputation beyond reputeMichael Leicht has a reputation beyond reputeMichael Leicht has a reputation beyond reputeMichael Leicht has a reputation beyond reputeMichael Leicht has a reputation beyond reputeMichael Leicht has a reputation beyond reputeMichael Leicht has a reputation beyond reputeMichael Leicht has a reputation beyond reputeMichael Leicht has a reputation beyond reputeMichael Leicht has a reputation beyond repute
this year is 2005
5-2=3
3 O no another 3
Team 303 (2003-2007)-Student-Won FIRST Scholarship to Daniel Webster College
Team 42 (2007-2008)-College Mentor
Team 2342(2008-2011)-College Mentor
Team 1403 (2011- )- Mentor
  #293   Spotlight this post!
Unread 01-01-2005, 00:30
patTeam241 patTeam241 is offline
College Student
AKA: Pat Cleary
patTeam241 will become famous soon enoughpatTeam241 will become famous soon enough
Send a message via AIM to patTeam241
Just a couple of observations, and I'm sorry if I'm repeating someone.
-A field layout change is unlikely, the field still has to fit in approximately the same size area yet still provide ample play space.
-Someone commented on DOX (Delta Omnicron Xi) being the "FIRST Frat", the Omnicron and Xi are used by the hint (Somehow) leaving just Delta - or change.
Just some ideas that came to me after midnight. Don't know if they mean anything.
  #294   Spotlight this post!
Unread 01-01-2005, 10:31
meaubry meaubry is offline
volunteer helper
FRC #6099 (Knights)
meaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond repute
Pi is the ratio of the circumferance to the diameter of a circle.
There are many websites established and dedicated to Pi - but, what if Pi stood for the other Beatle Paul? That would account for everyone except the one between John, George, and Paul - it only leaves RingO!
I doubt that we would have another hanging game, although hanging from rings would be interesting. So, if RingO is the clue - what if we had to pass something through the Ring, like a ball maybe? Sort of like Quiddatch (sp?) (from Harry Potter), except without the broomsticks.
Now, if we could only find that darn Golden Snitch? Dave?
  #295   Spotlight this post!
Unread 01-01-2005, 11:45
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
I take it you are not a serious Ultimate Frisbee player. It would be easier to throw it upside down then to hammer it, depending on where it is going. And some venues have things hanging that would interfere with a hammer.
Don't discount something that you think can't be done.
Wetzel
  #296   Spotlight this post!
Unread 01-01-2005, 11:50
Pin Man Pin Man is offline
How you doin'?!
AKA: Dave Kingsley
FRC #0088 (TJ²)
Pin Man has a spectacular aura aboutPin Man has a spectacular aura aboutPin Man has a spectacular aura about
Send a message via AIM to Pin Man
hehehe frisbees would be intense... we have been wishing for them... but I doubt for our last year (as high school students) in FIRST that we will have them... But who knows... We could get lucky...
AIM SN: ThursdayCambria
Attending Bridgewater State College
Shirt collection- 25, 47, 69, 140, 173, 191, 213, 303, 365, 461, 836, (2)862, 885, 888, 1027, (2)1073, 1156.
Shirts in the works-
Shirt Wish List- 45, 48, 61, 67, 84, 86, 95, 103, 111, 126, 175, 190, 233, 236, 716, 870, 871, 1114, and any other team basically
  #297   Spotlight this post!
Unread 01-01-2005, 13:15
looneylin's Avatar
looneylin looneylin is offline
I'm rad. U're rad. Let's hug!
AKA: Alicia Lin
FRC #0433 (Firebirds)
Team Role: Webmaster
looneylin has a brilliant futurelooneylin has a brilliant futurelooneylin has a brilliant futurelooneylin has a brilliant futurelooneylin has a brilliant futurelooneylin has a brilliant futurelooneylin has a brilliant futurelooneylin has a brilliant futurelooneylin has a brilliant futurelooneylin has a brilliant futurelooneylin has a brilliant future
Send a message via AIM to looneylin Send a message via MSN to looneylin
Talking Re: Official 2005 Clue Thread
i'm sry if i'm repeating anybody, but
mebbe the "look closely" part refers to some obstacle in the center of the field which needs to be located by using a sensor of some sort, so it's more mandatory that u need to use those sensors. this seems likely, i think, considering what they said last yr that teams will have to become more accustomed to using those sensors since they will be used in future games
Tycho Brahe's the man. lol
  #298   Spotlight this post!
Unread 01-01-2005, 13:25
Billfred's Avatar
Billfred Billfred is offline
Well, I see a way.
Remember, the 2004 field hit its fifth year, so an overhaul seems likely. And you know how they had the ball chutes this year? Well, what's stopping FIRST from cutting a slit in the plexiglass such that a HP could send a frisbee through?
(Of course, there would be a stiff penalty for a robot breaking that plane.)
  #299   Spotlight this post!
Unread 01-01-2005, 14:08
anna~marie's Avatar
anna~marie anna~marie is offline
misses FIRST
AKA: HOT's first female operator
FRC #0067 (HOT- Heroes of Tomorrow)
anna~marie has a reputation beyond reputeanna~marie has a reputation beyond reputeanna~marie has a reputation beyond reputeanna~marie has a reputation beyond reputeanna~marie has a reputation beyond reputeanna~marie has a reputation beyond reputeanna~marie has a reputation beyond reputeanna~marie has a reputation beyond reputeanna~marie has a reputation beyond reputeanna~marie has a reputation beyond reputeanna~marie has a reputation beyond repute
Send a message via AIM to anna~marie
perhaps we need to look at the shape of Pi....π
my speculation would be either a pyramid like we've said, but has been done before and is therefore unlikely, or a pit/pool. not water, but perhaps of another item the robot has to fetch?
I'm proud to be a...
  #300   Spotlight this post!
Unread 01-01-2005, 14:14
Koko Ed's Avatar
Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
This thread would probably make it to a thousand replies if it wasn't for the fact that kickoff is next Saturday.
5th Annual Ramp Riot (Official Thread) OZ_341 Off-Season Events 56 18-11-2004 05:05
[Official 2005 Game Design] OK, so YOU design the 2005 game... dlavery FRC Game Design 37 26-10-2004 23:15
Official Kettering Kickoff Music Thread Swan217 Off-Season Events 4 15-08-2004 18:08
