Go to Post Antimatter.. It will help us in the never ending quest to build the bot under the weight limit. - Elgin Clock [more]
Unread 31-12-2004, 11:50
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: A Simple Improvement to Driving
I just went through the thread and spotted a minor error. Sorry to bring it up.
Originally Posted by generalbrando
Well if you work through the math, it should be 0 and 256 averaged=128. Then average between that and the originals...64 and 194. Technically 127 is center (right?) so that's a tiny bit off, but the results is a slower spin. I thought there might be a quirk where I would need to handle an exception for such a thing like this, but in testing, I found it works fine all around.
Not quite. The maximum you should ever set the PWMs (motors) to is 254. 0 and 254 averaged is 127 (which is center).
Now here's an interesting tidbit: If you were to assign (for testing purposes) 256 to p1_y and 0 to p2_y, and proceeded to try it, the robot would go straight back. Why? Because 256 (Hex 100) is too big for a byte! It wraps to zero! So you end up averaging zero and zero, taking half the difference, etc., etc.
Unread 01-01-2005, 15:32
generalbrando's Avatar
generalbrando generalbrando is offline
Build, Break, Repeat
AKA: Brandon Mensing
FRC #0246 (Overclocked)
generalbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to behold
Send a message via AIM to generalbrando
YES! Honestly, as I mentioned, I'm not knowledgable about the programming for the robot (yet). But I could never get an explanation for that odd quirk of 127 being the middle. Thanks and thanks again to everyone for taking a look and giving more advice and input.
Lead Mentor of Team #246, Boston University Academy and Boston University, Overclocked
www.burobotics.org
A Simple note about life dddriveman Chit-Chat 14 13-05-2004 20:33
Simple things you can do to make your bot/team perform better KenWittlief General Forum 21 01-04-2004 15:11
Simple Autonomous Mode Example deltacoder1020 Programming 5 08-03-2004 20:22
In reference to the driving of Team 25 Goober65 General Forum 24 14-04-2003 23:09
Who's robots are driving already? Anton Abaya General Forum 67 16-02-2002 00:07
