Go to Post However, in the end, the renderer is only as good as the artist. - MiNT [more]
Unread 01-01-2005, 15:55
Guest
Posts: n/a
[frCoder] New Code Repository
http://frcoder.sourceforge.net/
The site is finally up! The repository itself uses MediaWiki content-management software, but is NOT A WIKI! Some of the basic principles of wikis (like open structure, anyone edits, etc.) are not going to be used. The most important difference is the structure (see frCoder:Structure). Look around. In the future, the base MediaWiki PHP source will be heavily modified to be tailored for code repository features.
Things that need to be done:
* Find/write C highlighter for source/header articles
* Create a fairly uniform style guide for writing code
* Start adding code!
Sourceforge for Code Repository and other stuff SilverStar Programming 9 15-01-2005 21:16
A Centralized Code Dump? colt527 Programming 29 01-01-2005 16:07
Shut down Code Repository? SilverStar Programming 12 25-05-2004 20:32
