Go to Post Did our Jaguar swallow a chipmunk, or is something else going on? - Tom Line [more]
Unread 01-01-2005, 13:50
Adam Shapiro's Avatar
Adam Shapiro Adam Shapiro is offline
FRC #0555 (Montclair Robotics)
Adam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud of
Send a message via AIM to Adam Shapiro
Drive Train design roadblocks
I've been working for quite a while to finalize plans for a gearbox for this year's bot. I've done much research, and gone through many calculations, but now I seem to be stuck on one factor on the JVN calc sheets. It seems that no matter how much I search for the solution I can't seem to find what "Fractional Weight on A/B Driven Wheels" means. That and the Drivetrain Efficiency (for which I've been assuming 0.65 will work, though I may be wrong) seem to be the only things keeping me from designing a transmission that won't draw too much current.
I was hoping someone could explain these factors to me. I'd really like to get these plans done soon! If I've missed a previous thread applying to this in my search, please tell me.
Mentor to Teams 555, 1929, and 2070!
Currently working in hardware design at Cisco.
Cornell University DARPA Urban Challenge - http://www.cornellracing.com
Co-Captain Team 555 - 2003,2004,2005
Trust, Love, and Magic
Unread 01-01-2005, 15:21
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Re: Drive Train design roadblocks
It means the percentage of weight over the driven wheels. If you are running a two wheel drive then there is never 100% weight over the drive wheels. This affects pushing ability of the vehicle which is why a rear wheel car handles differntly from a front wheel drive car in the snow. The best bet is to take four scales and place them on each wheel. The fractional weight should be the weight of the two driven wheels divided by total weight.
Unread 01-01-2005, 15:35
That makes sense, but I'm still a bit confused. We are considering using a 6 wheeled design this year but, as it's not built yet, I can't check the weight on each wheel yet. I was wondering if you knew any common or average values for either 6 or 4 wheels?
Also, I was unsure if the calculation should be the sum of the weights on one side divided by the total robot weight, or something else. Thanks in advance.
Unread 01-01-2005, 17:56
Adam Y.'s Avatar
Adam Y.
no team (?????)
If all four/six wheels are being driven then it would be 100%. If not then you would have to calculate it using the scale method.
Unread 01-01-2005, 18:18
That makes sense. I guess I'll just use 1 in my calculation.
My next question is: what is the difference between "[High/Low] Gear Load Current Draw" and "Drive [High/Low] Gear Current Draw"? Why is it the second is calculated as 2x the first?
I have created a combiner for the Chiaphua and Drills, similar to many other teams, and have designed the gearing with 6in diameter wheels, but no matter what I do I can't seem to get the current draw to an acceptable number at a max speed of 11ft/s. This seems strange to me as I know that there have been teams with faster bots than that. Any suggestions?
Unread 01-01-2005, 19:18
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Don't trust all the top speeds you read about here on Chiefdelphi. Many of the numbers (if not most) are derived from calculations. I know several of the numbers were even calculated from the free speed of the motor which is entirely incorrect because there will always be a load when driving a robot.
Also, what do you consider an acceptable current draw? most of the breakers can sustain loads a bit over there rated value for extended periods of time (many seconds).
Team 1257
Unread 01-01-2005, 19:24
I figured no more than 60A per side as the main breaker can only handle 120. Still, I can't even seem to get the high gear amperage down below 80A, which would be the limit on the secondary breakers. In low gear I'm getting a draw around 40A total, so I'm not too worried about that one.
I'm still rather confused on why there are two listed current draws, one being calculated as 2x the first. Just seems odd to me. (By the way, I've been reading the lower one, of course)
Unread 02-01-2005, 01:12
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Let's go off on a slight tangent while I throw a cautionary note in here.
Everyone is all in favor of team that use the summer and fall to develop prototype robot system, and design assemblies for their team (as training exercises, demonstration units, design practice, etc.). However, your messages seem to indicate that you are well into the final designs of your competition robot for the 2005 season, and you are seeking to tweak out the last few percentage points of efficiency and power for your designs. This is a rather risky practice at this point in time. Remember, you don't even know what the game is yet! As you "finalize plans for this year's bot" you are running a chance of spending a lot of time designing a system that could be completely inappropriate for the 2005 game.
If that happens, most teams historically fall into one of the classic engineering traps. Having invested a lot of time and effort in a specific design, most engineers are loathe to throw it away and start over with a clean sheet of paper - even when that is the most appropriate thing to do. Instead, they will try to modify their existing design and try to make it do something that it was never intended to do. Sometimes this works, but it is almost always at a cost in terms of lost efficiency, kludged design compromises, or brittle performance characteristics.
During this last week before the kick-off, you might be better served by either letting your designs be a little "loose" and leave the determination of the fifth digit of precision for later on, or - better yet - just kicking back and relaxing while you can (because you won't be able to for the six weeks that follow!).
-dave
Unread 02-01-2005, 02:56
I agree completely. I didn't mean to insinuate that this design was close to finished, nor am I even positive it will be used on this year's bot. I'm just trying to get a head start on understanding all that's involved in designing a gearbox. If possible I'd like to build the box I'll have designed, and test it to see if it works close to the way I believed it would, but I am nowhere near deciding that this will be the final calculation.
I only intended to get a little more insight into the JVN calculation sheets, as well as the theory that went into them. There are certain variables (such as those mentioned above) that I have wondered about for a long time, and I'd like to learn what they are and how to make use of them.
Unread 02-01-2005, 05:59
Jeffrafa's Avatar
Jeffrafa Jeffrafa is offline
Robotics Addict
AKA: Jeff Lewis
FRC #1425 (Error Code)
Jeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant future
The Drivetrain Efficiency is kinda just what it sounds like it would be, the efficiency of your entire drivetrain, both gearbox and drive system combined (chains, belts, gears, etc that connect the motors to the wheels). Personally i would think .65 is a little on the low side, but i must admit i havn't done too much with gearbox design and building, its never bad to stick on the safe side though. As far as coming up with an overall value for your drivetrain efficiency you need to multiply together the efficiencies of each stage of your drivetrain, for example if your gearbox consisted of two sets of spur gears that were each 95% efficient and you then had a chain with an efficiency of roughly 95% also then you would multiply .95 x .95 x .95 = .857, or roughly 86% efficiency. It mostly depends on the types of gears you use in your drive system and how much your drive system consists of.
Some rough efficiencies for different types of components are as follows:
Chain & Belt ~ 95% - 98%
Spur Gears ~ 95% - 98%
Bevel Gears ~ 90% - 95%
Worm Gears ~ 40% - 70%
Planetary Gears ~ 80% - 90%
Hope this helps
Also, please correct me if i may be wrong on something - its rather late to be posting :-)
Team 1425 Alumnus and Mentor
I am KF7JDK - What's your callsign?
Unread 02-01-2005, 11:19
Electrical Engineer
Rookie Year: 1995
...Everyone is all in favor of team that use the summer and fall to develop prototype robot system, and design assemblies for their team (as training exercises, demonstration units, design practice, etc.). However, your messages seem to indicate that you are well into the final designs of your competition robot for the 2005 season, and you are seeking to tweak out the last few percentage points of efficiency and power for your designs. This is a rather risky practice at this point in time. Remember, you don't even know what the game is yet! As you "finalize plans for this year's bot" you are running a chance of spending a lot of time designing a system that could be completely inappropriate for the 2005 game....
Dave,
This is why I have and continue to advocate that FIRST mix things up more in terms of size, weight and components allowed.
Mike
Mike Betts
As easy as 355/113...
Unread 02-01-2005, 12:08
henryBsick's Avatar
henryBsick henryBsick is offline
Why wait for the last 20?
AKA: Henry B. Sick
FRC #0125 (NUTRONS)
henryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond repute
Send a message via AIM to henryBsick
Dave and Mike did bring up 2 good points but for the sake of JVN calculation experimentation...
The 2 values for current draw relating to the two different speeds (gears) directly reflect the force it takes to rotate in each gear.
low gear-more rotations (from motor)-faster rotations (from motor)-less power req. to rotate-less amperage
high gear-less rations (from motor)-slower rotations (from motor)- more power req. to rotate-more amperage
I am not specifically familiar with the JVN calcs. but through my own calculations and driving in matches (while tripping the 40 amp breakers in high high gear) I believe that to be your answer.
-Henry
Mechanical Engineer
Digital Lumens
NU ME: 2011
Unread 02-01-2005, 12:31
This much I was aware of. I was referring to the JVN sheet's two current values for each gear. Both high gear and low gear have a number listed for "[High/Low] Gear Load Current Draw" and "Drive [High/Low] Gear Current Draw". The second (Drive...) is calculated as 2x the first. I was wondering what the reasoning was for this, and how to properly read it.
Unread 02-01-2005, 12:56
Liz Smith's Avatar
Liz Smith Liz Smith is offline
believes in robots
AKA: Pika1579
FRC #3940
Liz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond repute
Send a message via AIM to Liz Smith
I pretty much laughed when I saw this. We are nowhere even close to having designs for a finished competition bot. We're just counting down the days until kickoff when we can start designing around the game. Right now we're trying to figure out how to make a gearbox that might be helpful this year.
Unread 02-01-2005, 13:00
-dave
Amen to that.
Help with drive train superbeano2004 Motors 23 01-02-2005 19:30
Coolest Drive Train team222badbrad General Forum 15 01-09-2004 19:06
what's your most important drive train advice? Ken Leung Technical Discussion 42 07-01-2003 09:58
Another chapter in the drive train story AdamT Technical Discussion 19 29-09-2002 13:52
Blowing fuses/tuning drive train DougHogg Motors 10 23-06-2002 00:24
