Re: Programming FAQ
Question: What OS is on the robot? If there is none or its horrible can I put embedded Linux on it? I only run Linux myself, is it possible to program this robot on Linux? Is there some sort of emulator I can get so I don't have to be with the robot, or it dose not have to be fully built for me to test?
Or basically I am a rookie, where do I start, I want to learn about the robot controller. Answer: OK first, yes you can program this robot using Linux. Visit http://kevin.org/frc/ and you should find some more information. For starting off, I highly recommend the documents on http://www.innovationfirst.com/FIRS...cumentation.htm And then if you are advanced enough you can look at this page, but only if you are a really core programmer. Otherwise innovation FIRST is the best place to start. To answer another part of you question, there is no OS on the robot controller. It is a microchip which understands C and assembler. Search, Read documents and get a feel of what our robot controller(microchip product) is. Its might not be such a good idea to try to go as far and put Linux on there or something, Search, Read documents you can find and you will get a feel. -Bharat |
Re: Programming FAQ
Question: Does everyone use the C18 compiler? Or do some of you use the Visual Studio C compiler?
If you use the Visual Studio C complier, how would you download the code to the RC? |
Re: Programming FAQ
Matt |
Re: Programming FAQ
Q: Where can I find all this cool stuff that was talked about in the (2005) kickoff?
A: The Camera stuff, default code, (eventually) the new firmware (master code), and technical docs are on http://ifirobotics.com. The link to the new IDE and MCC18 compiler are on FIRST's website (http://www.usfirst.org/). Q: I CAN'T FIND THE COMPILER!!! THE LINK IS MESSED UP!!! HELP!!! A: Yes, we know you can't download the compiler right now. Asking again won't help. Just try again later (like tomarrow) and hope it works. We can't do anything about it no matter how much you pester us. |
Re: Programming FAQ
Q. Why won't my program link? (Generic Linking problems)
A. If you have any kind of linking problems, the first thing you should do is to tell it to Build All (Ctrl+F10, or Project > Build All). If this doesn't help, keep digging here. |
Re: Programming FAQ
Re: Programming FAQ
Re: Programming FAQ
Right now for my team I am the only ""programmer"" so we are using the same code from last year to run the new one, but the computer that held it crashed and our back up is sitting on a college freshmen's desk.
Q. is there anyway to "uncompile" the code directly from the controller? or do i have to start from scratch? |
#9
Re: Programming FAQ
Re: Programming FAQ
Once the code is compiled (which is the state the downloaded code is in), it's stuck that way. There are few ways to decompile it back to the original C code it was compiled from. I'm afraid you're stuck. |
#11
Re: Programming FAQ
Re: Programming FAQ
I just have a quick question. How do you load a program into an old robot controller that does not have the "prog"ram button?
#13
Re: Programming FAQ
Those were programmed in PBasic from Parallax not C and used an entirely different editor/compiler/downloader. It worked without the need for a "program" download button. Let me find some references for you... Most of what you need can be found here: http://www.ifirobotics.com/first-legacy.shtml under Documentation for 2001 - 2003 The default code with drive capability and the Editor that also downloads the code is available there, as well as documentation that describes what you need to know to get started. Another useful site is: http://www.parallax.com In particular: http://www.parallax.com/html_pages/...basic_stamp.asp for the latest Editor and http://www.parallax.com/html_pages/...basic_stamp.asp for in-depth PBasic user guides. __________________ Last edited by Mark McLeod : 25-12-2005 at 14:53. |
#14
Re: Programming FAQ
Thank you very much. I will try those links and see what I can get.
#15
hi
i need help on getting started on the drive code, i was on the team last but wasn't in charge of drive code and im a little lost on how to design it.Our main programmer and mentors have been busy recently and unable to help me. if some one could give me some help on at least some sort of outline of the code i should be able to figure it out from there i dont need anything crazy just so the robot can move and turn thanks confused programmer |
| Programming - Getting Started | Mark McLeod | Programming | 80 | 16-04-2008 23:37 |
| C Programming Guide | cbolin | Programming | 7 | 15-01-2005 13:22 |
| Book on C programming - suggestions? | wun | Programming | 18 | 14-01-2005 00:12 |
| Robot Programming Education | phrontist | Programming | 11 | 03-05-2004 07:32 |
| A few questions on programming the Control System | Avarik | Control System | 21 | 08-02-2004 11:42 |
