Go to Post each year the chairmans award is given to the team the judges think deserve it the most, for that year. How can it be any other way? - KenWittlief [more]
Unread 02-01-2005, 13:24
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Split topic - How many channels can the current (2004) Oi's and Rc's Handle?
Originally Posted by Official 2005 Hint Thread
Originally Posted by Rickertsen2
The 2004 control sys setup is completely capable of 3v3. The only thing that they would have to change is the team color lights. That wouldn't be a major change at all.
So the current RC and OI can handle 12 channels?
One for each robot, and one for a field controller for each robot.
Unless I am mistaken. I am think along these lines. Where the IFI OI, RC, and radio pack is defined as:
24. A method for controlling a robot competition within an arena having a plurality of robots engaged in competition therein, said method comprising:installing at least one device for engagement by contestants of the robot competition; allocating, by the at least one device, a plurality of channels for communication of signals to the robots during the robot competition; assigning a unique channel to each contestant engaging the at least one device; and conducting the robot competition with the engaged contestants.
25. The method according to claim 24, wherein the at least one device is an arena controller
Or would it be 7, One for each robot, and one for 1 field controller for everyone.
Above quote source is provided by doing THIS.
Unread 02-01-2005, 13:29
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Re: Split topic - How many channels can the current (2004) Oi's and Rc's Handle?
The current control system has 40 channels.
The field controllers don't require any radio channels.
Unread 02-01-2005, 13:30
MikeDubreuil's Avatar
Carpe diem
FRC #0125 (Nu-Trons)
The current Innovation FIRST radios can support 40 channels. 5 channels are user selectable and 35 are set aside for competition use.
Taken from the Radio page at the IFI website.
Unread 02-01-2005, 13:31
Does that mean we could potentially have 40 robots on the field at the same time with no mixing of frequencies?
Unread 02-01-2005, 13:39
Carpe diem
Yes and No. At most regionals with only 1 field yes, you could have 40 robots at a time running with little to no data loss.
The channel issue becomes a problem when you go to nationals and many fields can be running at one time. The fields are also close enough in proximity that it would not be possible to re-use channels.
It's important to note that your robot will not respond to another teams Operator Interface. Your team number is entered at both the Operator Interface and Robot Controller and is used to filter bad radio data. However, if both teams were using the same channel it could result in some loss in data causing erratic problems with robot command and control.
Given the current radios, it is possible to have 5 fields at nationals with 6 robots on each field simultaneously.
Unread 02-01-2005, 13:43
Software Engineer
Rookie Year: 1995
In theory, yes. In practice, not really. Some experimentation that we've done with the radio modems shows that if two radios are on adjacent channels they will interfere with each other. Assigning consecutive channels to robots on the same field would likely lead to intermittent data links (and thus erratic robot behavior). Plus, I imagine that when IFI sets up a competition, they try to stay away from the 5 channels that are user-selectable in case someone happens to be using one of those channels in the pits.
Unread 02-01-2005, 14:02
It is important at this point to remind everyone that you may not use radio control in the pits at any competition. What interference you can cause may ultimately result in personal injury so use the tether everywhere except when on the field.
