Go to Post It would be wise to consider the reasoning behind the statement rather than the statement itself. Sometimes they are right... other times their statement is incomplete... and other times they really do have no clue what they are talking about. - dtengineering [more]
Unread 02-01-2005, 16:32
phrontist's Avatar
phrontist phrontist is offline
Proto-Engineer
AKA: Bjorn Westergard
FRC #1418 (Vae Victus)
phrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond repute
Send a message via AIM to phrontist
Re: Optical Mouse Navigation
Originally Posted by Jizvonius
If you guys don’t mind a little mechanical system involved in your navigation, you can control the surface quality that your optical system sees and the distance to that surface.
The system requires an interface between the carpet and your optical sensors. Say, a ball with a textured surface (ball size and material must take into account carpet properties). The sensors and ball are a fixed distance from each other by attaching the sensors to the ball cradle. Now to minimize slippage on the ground, have the entire apparatus slide up and down on a track with downward force provided by a constant tension spring.
This isn’t a completely thought through design yet, and yes, it is just a higher resolution encoder. But it is free spinning (deals with pushing and drive train slippage), much higher resolution, and with a little math you may be able to calculate yaw (depending on the placement of the ball and sensors).
It seems that we will either have to deal with mechanical or optical slop either way, so instead of having your sensors losing focus, you can just have the minimized slippage of a free spinning ball (and yell at your mechanical team if it’s not working). Anyway let me know what you guys think.
Bah! If I get that desperate I'd just make a really low friction housing for the assembly and put it in direct contact with the ground, with the ability to retract up into the robot's body. I'm no where near that desperate yet.
University of Kentucky - Radio Free Lexington
"I would rather have a really big success or a really spectacular crash and failure then live out the warm eventual death of mediocrity" - Dean Kamen
External Lens for optical mouse gnormhurst Electrical 4 07-01-2005 19:07
Looking for Mouse part Mr. Lim Electrical 3 27-12-2004 19:56
Optical Mouse / Ball Mouse Clark Gilbert Chit-Chat 26 22-07-2004 13:17
Optical Sensors Used as Encoders? uvabrad825 Technical Discussion 22 03-05-2004 13:22
IS THIS RIGHT?!?!? RebAl General Forum 22 31-03-2002 00:07
