Go to Post If everyone could just worry about how much fun they are having rather than how much they disagree with other teams, the program would be much better off. - Tom Bottiglieri [more]
Unread 02-01-2005, 17:38
CyberWolf_22's Avatar
CyberWolf_22 CyberWolf_22 is offline
Programming and Electrical Mentor
AKA: Allen Gregory
FRC #2587 (Afrobots)
CyberWolf_22 is just really niceCyberWolf_22 is just really niceCyberWolf_22 is just really niceCyberWolf_22 is just really nice
I2C Digital Compass Programming
I was looking around Newark InOne and found a digital compass.
I read the data sheet and it looks like it will interface nicely with are Robot Controller.
My only problem is going to be figuring out how to program the I2C interface. I have read the PIC datasheet on using the I2C interface but I have not been able to get a good grasp on how I would go about programming it. Does anyone have any examples of programming this sensor or setting up an I2C interface in general?
Unread 02-01-2005, 18:12
Umm Errr...
Re: I2C Digital Compass Programming
Well you are in luck. There is a prewritten library of I2C functions that comes with the compiler. They are documented in the following link:
http://ww1.microchip.com/downloads/e...ies_51297d.pdf
Also, source code for all of these functions can be found in the C18 install directory assuming you selected it when you installed C18.
1139 Alumni
Unread 02-01-2005, 18:58
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Compass you say?
http://www.chiefdelphi.com/forums/sh...94&postcount=5
We tried that a few years back. Look for mention of the I.D.A.N. system.
Unread 02-01-2005, 20:52
Gdeaver Gdeaver is offline
FRC #1640
Note the accuracy in the data sheet. Don't confuse resolution and accuracy. I've been playing with a PNI compass board. I I've got it working to with in 1deg accuracy. However to get this accuracy the are only 2 readings per second. They're slow devices. Enable the set reset register. The board has to be at least 1.5 away from any motors or solenoids. The more the better.
1 degree of error over the length of a playing field is allot. It may have it's uses.
Unread 02-01-2005, 21:21
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
1.5 what?
Unread 02-01-2005, 21:28
FRC #1640
Feet. More if the motors are under high load. The drill motors really put out magnetic distortions. Cims aren't nearly as bad. Fortunately the magnetic field from the motors is not uniform.
Unread 03-01-2005, 00:14
Kevin Watson's Avatar
La Cañada High School
FRC #2429
Originally Posted by CyberWolf_22
...My only problem is going to be figuring out how to program the I2C interface. I have read the PIC datasheet on using the I2C interface but I have not been able to get a good grasp on how I would go about programming it. Does anyone have any examples of programming this sensor or setting up an I2C interface in general?
The hardware I2C interface is unavailable because the Master Synchronous Serial Port Module is being used for the intraprocessor SPI link.
-Kevin
Kevin Watson
http://kevin.org
Unread 03-01-2005, 00:20
Umm Errr...
-Kevin
Hrmm... True... This will make things harder but not impossible. You will not be able to take advantage of the built in hardware and will have to "bitbang" the I2C interface. The good new is that I2C is synchronous and so timing isn't critical. If you look in the document i listed earlier, you will see that they have some basic I2C bitbanging functions described in section 3.5.
1139 Alumni
Programming - Getting Started Mark McLeod Programming 80 16-04-2008 23:37
Digital Caliper as a Digital Readout on Small Mill sanddrag Technical Discussion 9 13-10-2005 22:51
Dynamic Input/Output Changing Paolo Control System 6 23-09-2004 19:09
Robot Programming Education phrontist Programming 11 03-05-2004 07:32
