#31
Re: Using Digi-Key Shaft Encoders
-Kevin |
#32
I'm having trouble with the links to digikey at the first of this post. Does anyone know the part numbers that the links refer to?
Or alternatively, any recommends for digi-key optical encoders? Thanks. |
#33
In MPLAB IDE, go to View->Disassembly
#37
-Kevin |
#38
-Kevin |
#40
mechanical or optical encoders? i know the mechanical encoders are alot cheaper and i was wondering how much that degraded quality
does anyone know the pro's con's between the two? we plan on using them to compensate for steering problems and atonomous and aren't sure which we want. |
#41
Mechanical encoders don't last nearly as long as optical ones do - check the specs on them for that measurement.
#42
Have you read the white paper titled "Quadrature Encoders"?
This should help you a lot. email me if you have any specific questions or comments. Daniel |
#43
After reading this forum, I still have a few questions.
What exactly is a encoder? And how can I use it to measure the speed of the robot? |
#44
To measure the speed, you just use the difference in position between two measurements at different times. |
#45
So to find the speed, one would have two encoders at different times and subtract them? |
| If set screws suck . . . | Madison | Technical Discussion | 17 | 22-12-2003 19:19 |
| Who used wheel encoders | CyberWolf_22 | Technical Discussion | 12 | 04-05-2003 15:37 |
| Where to get shaft encoders | D.Viddy | Programming | 12 | 17-01-2003 09:38 |
| Motor coupling | archiver | 2001 | 19 | 23-06-2002 23:35 |
| Need Help on Shaft Mounting... | archiver | 2001 | 3 | 23-06-2002 23:29 |
