Go to Post I guess we're going amish this year. - Jon Anderson [more]
Unread 02-01-2005, 20:12
Steve W Steve W is offline
Grow Up? Why?
Steve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond repute
Re: Assuming a 3 vs 3
Originally Posted by cdr1122334455
Well some of the competitions last year such as Eruption v3 at North Brunswick (#25) had 2 or 3 announcers rotating every 10 matches or so. what about that or having 2 announcers in one match, kind of like in the movie angels in the outfield where they had a switch that controlled either mic
Being an announcer at at least 2 regionals in 2005 I know that there are no plans to have additional announcers at the regionals. Announcing is not an easy job. I have done 1 off season event and it was a cakewalk compared to a regional or Championship. I believe that I did an average of 125 - 130 matches per regional.
I forgot to post this on my last post (I'm so bad). The robot size might be changed as per a post by dlavery. I quote :
"Have we considered the possibility that the teams that run up against weight problems each year just aren't taking 130 as a serious limitation until much too late in the process. They tend to do this because they are unconsciously thinking "130 pounds - that's a lot. We don't have anything to worry about - if we run into problems, then we will just cut a bunch of holes at the end." As a result, they don't plan their robot weight budget properly, and have to resort to hacking off entire subsystems or drilling 1482 lightening holes at the last minute.
I think we need to be going the other way. Rather than promote the belief that 130 pounds is a rather generous number, why not reduce the weight restriction to 120 pounds (or less)? I theorize that at 120 pounds, including the battery, nearly all teams will recognize that the weight restriction is a hard problem right up front and will begin to plan accordingly. As a result of the earlier (and arguably better) planning, I would predict that teams will have more weight-conscious designs and the number of last minute "slash-and-hack" weight reduction efforts will be reduced.
So, rather than increasing the weight restriction, we need to decrease it by 10 pounds or so (or just increase the mass of the battery or other non-negotiable parts by 10 pounds while keeping the restriction where it is, which would have the same effect). And then have FIRST throw a copy of the Atkins diet book in with each kit...
-dave"
We'll have to see.
We do not stop playing because we grow old;
we grow old because we stop playing.
Unread 02-01-2005, 20:30
Bill Gold Bill Gold is offline
Retired -- 2006
Bill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond repute
Originally Posted by Mike Rush
Why 3 vs 3? What about 2 vs 2 vs 2? This would be reminiscient of Ladder Logic but with the team format.
2v2v2 allows for the same "ganging up" that occured when it was 1v1v1. Two alliances teaming up to take out the third is lame, imho. I, personally, much prefer the Alliance A vs. Alliance B at a time format.
Originally Posted by Cory
As I think Bill Gold pointed out in another thread, it would take relatively little work on FIRST's part to keep the same rectangular field, but extend the player stations to make the field wider.
Thanks for reading my posts, Cory
I was thinking "oh well, wouldn't be the first time no one read my post..." just before I came across your response in this thread.
Unread 02-01-2005, 20:55
Swampdude's Avatar
Swampdude Swampdude is offline
AKA: Dan Quiggle
FRC #0179 (Children of the Swamp)
Swampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond repute
I'm just starting to envision the Autonomous pile-ups, and un-intentional pinning, tangling. Heh, 6 robots roaming about the field on their own. So with that thought in your mind, now you see the need for a few very good autonomous modes. Not just 1 that goes back and forth etc., since the field variables just increased exponentially - not to mention 6 possible starting points.
A 3vs3 on 1 field just seems like too much. I'm still going with the 2 hex fields competing against each other against the clock. It just seems so much more do-able. Especially considering the thread Steve quoted there, that Dave suggested smaller bots/
Although I just noticed that the Great Lakes regional had 1 field last year and 60 teams. This year they capped registration at 60 teams again... so that puts a hole in my other theory.
After looking at this thread and considering all the possibilities, I'm hoping for a 2vs2. Not like the past hasn't been challenging enough....
www.179swampthing.org
Unread 02-01-2005, 23:20
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Let's take a look at some history. Back in the day, when we had the 1 vs 1 vs 1 game format, it was noticed that a regular pattern of the game was to have two teams work together and gang up on the strongest team, take them out, and then leave the two weaker teams to fight for the finish. After two years of this, Woodie Flowers stood up at the kick off and announced "We know that you are unofficially working together to play the game, but without carefully thinking how to make the best of your partnerships. So we figured that if you were going to work together, then we would make it a requirement!" Thus, "alliances" were born and they have been a part of every game since then. In other words, they took a weakness of the game structure and made it into a strength.
So now let's consider the 2 vs 2 vs 2 possibility. Bill and others are probably correct when they posit that with such an alliance structure we would see a repeat of the earlier behavior. The weaker two alliances would probaly gang up on the stronger alliance, take them out, and reduce the game to a 2 vs 2 format through to the finish. But is there a way to make this weakness in the structure into a strength? Actually, it is simple - if you just broaden your imagination and consider what might happen if the alliance structures are not symetrical.
If we know that the two weaker alliances will gang up and create an unfair 4 (2 + 2) robots vs 2 robots situation, then there is one very easy way to restore balance. Imagine what it might be like if the match were designed to have two (weaker) alliances of two robots each, and a third alliance of 3 stronger robots. A 2 vs 2 vs 3 structure could make things very interesting! The team scouts and strategists would have a field day with this one.
But, nah, that is way too complicated. FIRST would never do that to us...
-dave
Unread 02-01-2005, 23:26
Arefin Bari's Avatar
AKA: Ari
FRC #0108 (SigmaC@T)
-dave
He didnt say anything about 3 Vs. 3... thats it... its 3 vs. 3...
::smacks himself over the head and says "stop jumping arefin, just wait till the 8th"::
Unread 02-01-2005, 23:35
Swampdude's Avatar
AKA: Dan Quiggle
7 teams? Dave... come on.... Look there's still time to fix this, you've got 5 days to come up with something else! STOP THE PRESS!!!!
Unread 02-01-2005, 23:37
Joshua May's Avatar
Joshua May Joshua May is offline
Go Bears!
FRC #1110 (Binary Bulldogs)
Joshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond repute
Send a message via AIM to Joshua May
The mighty Dave has spoken, but he's up past his bedtime and I think he's just rambling now. And I know enough now not to trust anything he says.
Really, though, I think that a 3 on 3 structure would be very interesting, it would create a much more dynamic competition environment where all 3 strategies work together, not just a simple "you do this one aspect, we'll do the other." Additionally, the challenge of the field team keeping up with 3 opposing robots in addition to your own 3 would be nice, in my opinion, simply because of the challenge itself. I look forward to a challenge. After all, to use the cliched JFK quote: We choose to do things not because they are easy, but because they are hard. (paraphrased) Afterall, that's why I'm in FIRST, because I enjoy the challenge. Also, it seems FIRST has been weening us towards this, from the 3-team finals alliances that we've seen the past couple of years.
The FIRST Wiki - openFIRST - Ultimate Robot Challenge - URC Wiki
I currently have 50 GMail invites, PM or email me for one.
UC Berkeley Class of 2009
2005 Las Vegas Regional Autodesk Visualization Award
2005 Las Vegas Regional #8 Seeded Alliance with 988 and 1505
2006 Southern California Regional #15 seed
Unread 03-01-2005, 23:01
Mike Schroeder's Avatar
Mike Schroeder Mike Schroeder is offline
Gone the way of the dinosaur
AKA: "Big Mike"
Mike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond repute
Send a message via AIM to Mike Schroeder Send a message via Yahoo to Mike Schroeder
-dave
Way to freak people out dave, here is the problem, what is a strong team?
who/how do we decide it, from the past, well looking at some teams the past does not show the future, and what about rookies, its amazing to see what they can/ have never done before
(of course even though its less than a week until kickoff, dave can still change the rules to make bearhugging me in automode a bonus)
GOT SEARCH?
"We choose to go to the moon. We choose to go to the moon in this decade and do the other things, not because they are easy, but because they are hard"-JFK
Unread 04-01-2005, 03:03
George1902's Avatar
George1902 George1902 is offline
It's a SPAM thing...
AKA: George1083; George180
FRC #0180 (SPAM)
George1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond repute
This all depends on how the game is designed. Imagine:
Three two-team alliances: purple, green, and orange. Three goals to score in: red, blue, and yellow.
The purple alliance's score is the total of the red and blue goals. The green alliance's score is the total of the blue and yellow goals. The orange alliance's score is the total of the red and yellow goals.
Yes, two alliances could team up on the third, but they would need to score all of their points into just one goal to do so. Also, they would have to defend two goals. The third alliance would be able to score in two goals and only have to defend one. They would be at a two to one disadvantage in terms of robots, but would be at a two to one advantage in terms of offensive and defensive objectives.
George
"Darkness cannot drive out darkness; only light can do that. Hate cannot drive out hate; only love can do that."
-- Martin Luther King, Jr.
Unread 04-01-2005, 10:03
Denman's Avatar
Denman Denman is offline
Tie Wrap-Not Cable Tie or Zip tie
AKA: Stephen Denman
FRC #0759 (Systemetric)
Denman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud of
Send a message via ICQ to Denman Send a message via AIM to Denman Send a message via MSN to Denman Send a message via Yahoo to Denman
genius!
And that could be referring to the "between pi you and me"
I am an ex-member of team 759.
759: regional winners with 522 and 233 NYC (2004)
FIRSTWiki.org - Contribute, learn, inspire.
"Teach the way of the GP and the way of the GP shall teach you" - Me
2003 IRI David Kelly Off-Season Events 266 24-07-2003 22:09
Y=ax^2+bx+c Fact or Fiction? Bduggan04 General Forum 35 10-01-2003 03:10
Regionals -- where are teams going? patrickrd Regional Competitions 24 07-11-2001 15:48
