Go to Post A true form of GP would be to send out a congratulations to all the teams that made it, regardless of whether or not you think they should have. - Molten [more]
Unread 04-01-2005, 08:17
Jim Schaddelee's Avatar
Jim Schaddelee Jim Schaddelee is offline
Team 107 Holland Christian / Metal
None #0107 (Team Robotics)
Jim Schaddelee has much to be proud ofJim Schaddelee has much to be proud ofJim Schaddelee has much to be proud ofJim Schaddelee has much to be proud ofJim Schaddelee has much to be proud ofJim Schaddelee has much to be proud ofJim Schaddelee has much to be proud ofJim Schaddelee has much to be proud of
Re: Worm Gear Gearbox
Team 107 also used a worm drive transmission a few year ago,it work ok but there are things to be aware of. The main issue is your reduction should not exceed 50 to 1 on the worm ,for the reason that it will not back drive or coast. You can compensate for this by adding a ramp down in your code, but in humble opionion worm tranmisson is better suited for arms or lifting or any application where there are not sudden loads ,like stopping a moving robot.
I may still have one of the transmission we used if you would like me to sent it to you to look at I would be happy to help. I will try to post some pictures of a new worm tranny I designed over this summer If anyone would like to see it.
thank jim schaddelee
team 107 Holland Christian / Metal Flow
Unread 04-01-2005, 10:40
dddriveman's Avatar
dddriveman dddriveman is offline
Former Driver 1038, 979
AKA: Driveman
FRC #1038 (Thunderhawks)
dddriveman has a spectacular aura aboutdddriveman has a spectacular aura about
Send a message via AIM to dddriveman
Talking Re: Worm Gear Gearbox
I would love to take a look at that worm tranny. If you do not mind sending it to me. You can find my email in my profile.
"I'm sorry, after all he is just a wookie!"
Unread 04-01-2005, 11:53
Matt Adams's Avatar
Matt Adams Matt Adams is offline
b(o_o)d
FRC #1525 (Warbots)
Matt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond repute
Send a message via AIM to Matt Adams
Post Re: Worm Gear Gearbox
I don't want to jump in and be a nay-sayer... but I think one of the things you need to really weigh in before considering a design using a worm gear is the immense efficiency loss you're going to have simple due to the nature of the gear set.
We're talking in the range of efficiencies as low at 30% !
The advantage you mentioned, about not being able to back-drive the gear set, is not always true. There is some critical pressure angle and coefficient of friction that leads to the point were you actually can back-drive this gear set. Jim said that it's above a reduction of 50-1. I can't verify this either way.
[edit: But Paul definitely can. Rock on!]
However, simply because of the efficiency issue, I would steer clear of them in a drive-train gearbox unless there's a really good engineering justification. For a large reduction in a small amount of space, an off-the-shelf planetary gear set would probably hold better efficiencies.
That's my two cents. Good luck
Matt
Matt Adams - Engineer at Danaher Motion
Team 1525 - Warbots - Deerfield High School
Unread 04-01-2005, 13:27
President, VEX Robotics, Inc.
Back Drive-ability is a function of surface finish, lubricity, and worm lead angle. Using a bronze worm gear and a hardened steel worm (the small screw looking one), the max lead angle is 5 degrees to insure self locking. This is not a guarantee! What is a guarantee is that above 5 degrees, the worm gear set will not lock. The lead angle is the reason the window motor locks and the van door motor does not lock. It really has nothing to do with the gear ratio. A gear ratio of 50:1 with a lead angle of 15 degrees will not lock.
However, the more thread starts on the worm, the higher the lead angle and the lower the gear ratio is. Remember, gear ratio for a worm gear is # of teeth on the gear divided by number of thread starts on the worm.
-Paul
Unread 04-01-2005, 15:25
occra 23.
AKA: ryo
None #1481
a little off, but for lego, wormgear 24:1 reductions work very well, for lego robots i mean. not too slow, yet (well since lego isnt efficient whatsoever,) efficient (make sure you wupport both axles from both directions, and since lego axles are plastic, support them as close to the gears as possible.
well, yea. worm gear gear boxes (wormgearboxes?) as an idea are very applicable ithink. except as with designing any kind of gearbox, will have difficult parts but if it works well, great!
...and yea, im understanding why my english teachers rarely give me any good grades on my essays.
Unread 04-01-2005, 15:47
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Actually efficiency might not be an issue if you properly design the gearbox. A little bit of engineering and you should be able to get the efficiency fairly high. Of course a little research shows that the efficiency can reach 60%.
Article
Ps. Please someone build a drivetrain using these gears. These are the funniest sounding words ever. Hypoid and globoid.
Unread 04-01-2005, 16:25
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Article
60% efficiency is still downright terrible for a drivetrain when you consider spur gears are 98% efficient and chain is 95% efficient
2001-2004: Team 100
2006-Present: Team 254
Unread 04-01-2005, 16:27
Adam Y.'s Avatar
Adam Y.
no team (?????)
Read the article. It's actually possible to reach that degree of efficiency using regular worm gears.
Unread 04-01-2005, 16:35
Hypoid
Here is a picture of a hypoid gear. It is used on an automotive painting robot that my company manufactures.
Unread 04-01-2005, 16:26
Here are some facts about worm gear efficiency:
Efficiency = Tan(Lead)*(1-f*Tan(Lead))/(f + Tan(Lead))
Lead = Worm Lead Angle
f = Coefficient of Friction (Mu)
For a bronze gear and a steel worm f = 0.05
Easy to purchase worm gears have lead angles ranging from 4.5 degrees to 22 degrees. Here is the bounding range on efficiencies
Lead angle of 4.5 degrees has an efficiency of about 61%
Lead angle of 22 degrees has an efficiency of about 87%
This assumes everything is lined up!! Tolerances are very critical for a worm gear set-up.
The lead angle of 22 degrees corresponds to worms with 4 thread starts and the lead angle of 4.5 corresponds to worms with 1 thread start. The worm with one thread start has 4 times the gear ratio for the same package size than the worm with 4 starts. A worm gear box has several advantages for FIRST robots. The main two are package size and weight. We have used worm gears on our robots for three years, but only once on our drive transmission (see white papers under CCT).
Unread 04-01-2005, 16:36
Matt Adams's Avatar
b(o_o)d
FRC #1525 (Warbots)
I'm going to have to strongly disagree about efficiency not being an issue.
Even with your research, which I won't refute, 40% losses in a single stage of a gear set is still quite large compared to the 10%-15% losses over an entire drive train with spur gears and chain.
It should be noted that Adam's article did cite a 97% efficiency for a multiple stage gear train using worm gears, which I found to be quite impressive. (Costs? Yikes! )
Worm gears have their place, but I would strongly discourage their use on a drive train if you're just looking to reduce your gear ratio. I'd definitely like to see justification addresing the losses, which we can all admit are several times larger than spur gears.
(See Paul's link for an appropriate application.)
Matt
Unread 04-01-2005, 16:38
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
The worms we used last year were 35:1 on the back of another transmission. I don't recall the ratio for the Bosch tranny we used however. We wanted an extremely high torque setup for our application though.
Pete
Unread 04-01-2005, 18:02
Here is a design for positioning worm transmission from team 107 , the nice thing about our design is that there is 50 to 1 reduction on the worm which should make it not back drive. yet you can quickly change speeds and motor combination. It also can have either a pot or encoder mounted simply.
Thanks Jim schaddelee team 107
Unread 04-01-2005, 18:35
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
We used two FP's last year to build a winch for climbing the bar. Be very careful about efficiency loss - we had ~ 30% loss. But it did lock up nicely and keep us hanging
Here's an mpeg of it running
ID:	2723  Click image for larger version
Unread 04-01-2005, 19:38
Doug
That looks great ,what was your reduction and did you lubricate the worm with anything?
Jim Schaddelee team 107
gears Michael Leicht Inventor 12 16-09-2004 10:52
Reverse Gear FizMan Technical Discussion 12 26-04-2004 01:29
Van Door Worm Gear Jim Giacchi Motors 4 16-12-2003 09:35
what's your most important drive train advice? Ken Leung Technical Discussion 42 07-01-2003 09:58
