Re: 4wd vs 6wd?
ok, thanks for the help
Re: 4wd vs 6wd?
also 6 wheel drive has more traction and is less likely to be pushed since it naturally has more friction than a 4 wheel design, but current draw is a big problem with 6 wheels.
Re: 4wd vs 6wd?
how can there be better traction if only 4 wheels are on the ground at a time?
Re: 4wd vs 6wd?
cdr is probably referring to designs without the middle wheel dropped down (though he is still partly wrong). It does not inherently have more traction, and it should actually have less current draw because it has a higher ratio of wheel width to wheel length.
Re: 4wd vs 6wd?
Re: 4wd vs 6wd?
ever since 2001 we have had 6 wheels. our beloved Evil Machine from 2003 had no drop for the middle wheel, but it turned perfectly. 6 wheels is a great benifit, and the wise choice for nearly any design
#7
Re: 4wd vs 6wd?
to clear some stuff up from earlier, i was talking about if all 6 wheels are making contact on the ground at once. But i raise this new question, with a dropped wheel is it pushed around easily?
#8
Re: 4wd vs 6wd?
Re: 4wd vs 6wd?
Team 42 (P.A.R.T.S.) has used a 6-wheel drive system for several years now. The center wheel is dropped (as I recall) 1/4" and we drive all 3 wheels on each side.
If you don't drop the center wheel enough, then the extra friction from the outer 4 wheels can make the current draw really spike up when turning. We have found that your choice of wheels also can make a big difference. A robot that would barely turn at all on carpet without browning out a couple years ago turned just fine after we changed the corner wheels back to solid core instead of the pneumatics we had mounted for extra traction. There can be too much of a good thing... For the last 2 years we have used slightly deflated pneumatics as the center wheels and solid cores on the corners. That gives us a nice balance between traction and turning ability. |
#10
Re: 4wd vs 6wd?
Few questions. How many teams that have done 6 wheel design only dove 4 wheels. which ones did they drive and why. Also a nice 6 wheel design from last year is 233S roccobot very nice. I am only saying this because I got a up close and personal look at there components and transmission. o second question how much weight does an average 6 wheel design run? Any teams that have done 6 wheels for a while.
#11
Re: 4wd vs 6wd?
The other benefits that people seem to associate with 6WD systems, such an increased traction, seem to be related only anecdotally. For once, though, I'm going to leave the beating of that poor horse to some other people. This Whitepaper by Chris Hibner is a great resource when trying to figure out if you're robot will turn. Last edited by Madison : 04-01-2005 at 21:09. |
#12
Re: 4wd vs 6wd?
Here are some pics: 1 2 |
#13
Re: 4wd vs 6wd?
2 years ago, we had a woefully underpowered 4wd bot that just didn't want to turn (as the breakers kept popping). The wheels were essentially in the corners of the base, with long chains connecting the 2 wheels on each side. Our problem was that we had such a long wheel base that the drill motor we were using on each side just wasn't powerful enough to get the job done. To turn, we finally took the wheels off the bot and took them to the router, giving a rounded face to the edges of the wheel.
Last year, we went with a 6wd, drill/CIM drive. We got lawn-mower wheels (the hefty black rubber ones with the white steel hubs) and used those. We trimmed the corner wheels with the router as we had the previous year, but we left the middle wheel alone, and we never dropped it. We never really had issues with being pushed around, or any turning problems. What I really want to know is: what were the heaviest things in a 6 wheel drive train that caused the most weight headaches, because they were essential? |
#14
Re: 4wd vs 6wd?
because many heavy components would be necessary for any kind of drive system. ex) batteries. well if you're comparing, lets start a list extra wheels (compared to 2 or 4 or 3 or 5?? wd) more sprockets or w/e you use to power the exra wheels chain or belt or w/e you use to tranfer power to all the wheels bearings/bearingblocks axles bolts nuts of course please add on |
#15
Re: 4wd vs 6wd?
Team 492 http://www.titanrobotics.net has been using 6wd with lowered center wheels since 2000 and team 360 (the first team I was associated with ) used it in 1999. AFAIK we were the first as I didn't see any 6wd robots at either San Jose or Epcot, that year. Since then, they have become pretty popular.
Benefits: 100% traction no matter what the contact is (hills, valleys, flats, going over barriers), fluid, low power turns. In 2004 we were able to run 6 finals on one battery. The motors only got "warm", never hot. Disadvantage: more complex, somewhat heavier, *harder* to drive straight and easily knocked about: the reason? Because the robot is pivoting on two wheels, there is very little restraining force. That is why 4wd robots drive so straight: they resist mightily any turn! They also burn up the motors... In 2004 team #492 solved the disadvantages by using active servo to control wheel velocity. We used very grippy tires (3" beadlock) and used torque estimation to limit current draw when in a shoving match (no need to smoke motors!). Finally, for autonomous mode, we used a gyro chip for heading reference (the encoder feedback from the servo for distance) and never failed to hit the target ball - even after being hit by another robot one time! Typically we aim for a 15-18 fps top speed, but use the servo to limit speed to something less (say 10 fps). We use the servo for control rather than gearboxes. It hurts our ability to push, but, fortunately, 2004 wasn't totally about pushing. A maneuverable robot that was fast & controllable could still dominate. Last edited by Larry Barello : 06-01-2005 at 00:10. Reason: http://www.titanrobotics.net |
| 2-wheel versus 4-wheel drive | Ben Mitchell | Technical Discussion | 23 | 07-11-2003 00:50 |
| 4wd | Lisa | Kit & Additional Hardware | 2 | 03-02-2003 13:15 |
| confirmed... 6WD recommendation of Joe J.. | archiver | 2001 | 0 | 23-06-2002 23:20 |
| 4WD with 4 motors | archiver | 2001 | 8 | 23-06-2002 22:58 |
| tank or go-cart style steering? | archiver | 2001 | 17 | 23-06-2002 22:42 |
