Go to Post Isn't that sort of like asking "is that an African or European swallow?" - dlavery [more]
Unread 02-01-2005, 16:10
Adam Shapiro's Avatar
Adam Shapiro Adam Shapiro is offline
FRC #0555 (Montclair Robotics)
Adam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud of
Send a message via AIM to Adam Shapiro
Re: Drive Train design roadblocks
As Henry pointed out to me just a few minutes ago (which I'm very surprised never occurred to me), it seems the second current reading is for the total draw from both gearboxes. A simple, well put answer, it would seem.
Now I am faced with figuring out what factor is causing my calculations to produce such high currents at (theoretical) max speeds much lower than those of other teams. For instance, with the gearing I'm now working with I have a current draw of 97A (194A total) at a max speed of 10.5 ft/s. Any suggestions?
Mentor to Teams 555, 1929, and 2070!
Currently working in hardware design at Cisco.
Cornell University DARPA Urban Challenge - http://www.cornellracing.com
Co-Captain Team 555 - 2003,2004,2005
Trust, Love, and Magic
Unread 04-01-2005, 12:51
Woodie Flowers Award
Ken Patton Ken Patton is offline
purple
FRC #0051 (Wings of Fire)
Ken Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond repute
Adam-
You are right to be doing some detailed calculations like the JVN calcs as a way to figure out the potential performance of your drive system. Even if you don't end up using the design, the calculation exercise is still educational. So don't give up on that approach - just keep refining the input assumptions as you get more info or data.
My first inclination is to suggest that your assumed efficiencies (you quoted 60% overall, I think) are too low. This definitely will drive your top speed to a lower value and your currents (at a given speed) to a higher value. The efficiencies posted earlier in this thread are pretty accurate, and if you do a good design job (rolling elements, get rid of sliding contact wherever possible, minimize misalignment under load) you can hit the high end of those values.
One other source of efficiency loss is the tire-to-carpet interface. This is maybe a 93-95% type of number. Soft sticky tires are lower (90-93% maybe).
I think a good system with a simple spur gear drivetrain (no planetaries, no belts, just gears and chains and wheelchair wheels) should be able to be in the mid-80's efficiency-wise.
Advanced topic:
For people who are doing more than a closed-form calculation (i.e., they are using calculus to derive a simple equation that they can numerically integrate - the type of stuff you would do in 1st year of engineering school) I would suggest adding a loss term that is a constant with respect to speed. For a *very* efficient gearbox I use a 0.2 Nm spin loss applied to the output of the gearbox, and a 12 N drag loss applied to the robot mass.
Hope this helps,
Ken
Unread 04-01-2005, 14:01
Matt Adams's Avatar
Matt Adams Matt Adams is offline
b(o_o)d
FRC #1525 (Warbots)
Matt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond repute
Send a message via AIM to Matt Adams
Post Re: Drive Train design roadblocks
Originally Posted by Adam Shapiro
I figured no more than 60A per side as the main breaker can only handle 120.
Ah... this is a great time to throw some information out there. This is a Matt Adams story about engineering, tears and tragedy. I hope you have Kleenex.
461 was running 4 motors all designed around keeping them around the 40A mark and we had no problems... we were drawing around 150A pretty regularly without problems... until we ran over a dozen back to back matches in the finals at nationals. Despite the fact of this untimeliness, they held up very well above listed capacity for said reasons. (Hint: Keep circuit breaker cool.)
Overall, don't worry about the 120A breaker. Check out the spec sheet. It has no problem going 30% beyond that for 20 seconds or so. You typically won't be tripping that in a match, or even back to back matches if you make an effort to keep them cool.
The 40A breakers, however, I think are much less forgiving. I would be much more concerned about keeping these guys in check. My advice is to design your motors and loads evenly around the 40A breakers.
Good luck!
Matt
Matt Adams - Engineer at Danaher Motion
Team 1525 - Warbots - Deerfield High School
Unread 05-01-2005, 16:49
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
...but now I seem to be stuck on one factor on the JVN calc sheets..
Adam,
The things already posted in this thread should be sufficient to answer your questions. It's all good stuff!
I appologize for the lateness of this reply, but I've been on vacation for the past week+ (a little calm, before the storm).
I intended to get around to revising the spreadsheet, and polishing some of the less intuitive sections before kickoff this year. Unfortunately, it probably won't happen in the near future. Ya never know, we'll see how much free time I have.
Hope you solved your design problems.
Good luck,
John
Help with drive train superbeano2004 Motors 23 01-02-2005 19:30
Coolest Drive Train team222badbrad General Forum 15 01-09-2004 19:06
what's your most important drive train advice? Ken Leung Technical Discussion 42 07-01-2003 09:58
Another chapter in the drive train story AdamT Technical Discussion 19 29-09-2002 13:52
Blowing fuses/tuning drive train DougHogg Motors 10 23-06-2002 00:24
