Go to Post I got something totally different from my FIRST experience. to me the spirit of FIRST is all about sharing. during the 6 week build period, you share yourself with the other people on your team. at the competition, you share your creation with everyone who watches your 'bot play the game. - George1902 [more]
Unread 04-01-2005, 03:29
Yov's Avatar
Yov Yov is offline
Masterofsquirrelz
#1657
Yov is a jewel in the roughYov is a jewel in the roughYov is a jewel in the roughYov is a jewel in the rough
Send a message via ICQ to Yov Send a message via AIM to Yov Send a message via MSN to Yov
4wd vs 6wd?
Hello, I have a question that I haven't been able to find the answer to anywhere...
Why would a team use 6 wheels on their robot? What are the advantages and disadvantages?
Also, if using a 6wd, what wheels are controlled and how?
Thanks!
<Patrician|Away> what does your robot do, sam
<bovril> it collects data about the surrounding environment, then discards it and drives into walls
2005 Israel regional Winner
2005 Radioshack Innovation in Control Winner
Unread 04-01-2005, 03:53
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: 4wd vs 6wd?
A big reason teams have been using 6 wheel drive lately is because they can drop the center wheel a very small amount, which will allow them to turn easily on the carpet, yet afford similar traction to a 4WD robot. This is because when the robot goes to turn it is essentially pivoting on two wheels, rather than trying to drag 4 wheels across the carpet. Turning issues and current draw are two big problems with 4WD and 6WD helps with that. One disadvantage is that it's heavier than a 4WD bot due to two extra wheels.
In all the 6WD bot's I've seen, all the wheels are driven, each side by one or more motors, and driven like a tank, in the same manner as a 4WD robot.
There are many teams who built similar drive systems last year, and some over the summer. Im sure they'd be more than willing to give you detailed information
2001-2004: Team 100
2006-Present: Team 254
Unread 04-01-2005, 06:05
Camerzn Camerzn is offline
Unregistered Non-user
AKA: Chris A
#1139 (Geargrinders)
Team Role: Human Player
Camerzn has a spectacular aura aboutCamerzn has a spectacular aura about
Send a message via AIM to Camerzn
Re: 4wd vs 6wd?
The best example of 6wd I've ever seen did have the dropped center wheel (about 2 cm). The center wheels on each side were powered directly from the gearboxes, and belts drove the other two wheels on each side; even if all four belts broke, the robot would have still been powered. The robot wasn't terribly fast, but it had excellent power and traction on the low pile carpet. It was definitely a snazzy 'bot, and if you want to try it, go ahead. Like Cory says, however, remember that six wheels weigh 1.5 times as much as four.
Never trust a computer you can't throw out a window. -Steve Wozinak
Unread 04-01-2005, 06:48
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Re: 4wd vs 6wd?
This has been covered in many many other threads.
I have not been on the forum for most of the year, but if you search "Joe Johnson six wheel" you will find 2 pages of threads.
In my opinion, six wheel drive should be the standard drive system by which I mean that if you don't have a good reason to use something else, that is what you use.
Bottom line: good balance between weight, traction, and turnability.
Read the old threads to learn other view.
Joe J.
P.S. I promised myself that I'd put in a shameless plug for the "NBD: Nothing But Dewalts" whitepaper whenever I posted in the 2005 Season, so here it is: I believe this instant classic will take its place as one of the most important How To's FIRSTers have access to. JJ
Unread 04-01-2005, 10:03
Yov's Avatar
Yov Yov is offline
Masterofsquirrelz
#1657
Re: 4wd vs 6wd?
dropped down?
meaning the two middle wheels are lower than the others?
Unread 04-01-2005, 10:19
Cory's Avatar
AKA: Cory McBride
Re: 4wd vs 6wd?
Originally Posted by Yov
dropped down?
Yes, like I said in my first post, if you have the center wheels lower, when you turn, the robot will pivot on them, which allows you to have to overcome less friction, which means turning is easier.
by lowering them just a slight amount, you still at any given time have the robot's mass over 4 powered wheels that are on the floor which means no significant (assumption, haven't done a study ) loss in traction
2001-2004: Team 100
Unread 04-01-2005, 10:24
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Re: 4wd vs 6wd?
dropped down?
Yes, in most cases. For many FIRST robots that have used 6 wheel drive bases or tank tread drive bases, the middle wheel (or tread roller) is about 2-3mm (1/8") lower than the other wheels.
This has been the case if the robot has it's wheels positioned along the long dimension (36 inches~914mm) of the robot. On the other hand, if the robot is wider than its length and the wheels are positioned along the short dimension (30 inches~762mm), then that middle wheel may not need to be lowered at all.
Lowering the middle wheel allows the robot to turn easily. The front and rear wheels skid sideways easier when there is a lower middle wheel (some folks call this middle wheel a "bogey wheel").
Andy B.
<edit: wow... 4 posts, all written at the same time, all giving Yov the answer he needed>
Unread 04-01-2005, 10:25
Bill Gold Bill Gold is offline
Retired -- 2006
Bill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond repute
Re: 4wd vs 6wd?
<edit>
Darn. Andy and Cory beat me...
</edit>
Unread 04-01-2005, 12:45
Yov's Avatar
Yov Yov is offline
Masterofsquirrelz
#1657
Re: 4wd vs 6wd?
ok, thanks for the help
Unread 04-01-2005, 14:25
Conor Ryan Conor Ryan is offline
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
Re: 4wd vs 6wd?
also 6 wheel drive has more traction and is less likely to be pushed since it naturally has more friction than a 4 wheel design, but current draw is a big problem with 6 wheels.
Unread 04-01-2005, 14:36
Yov's Avatar
Yov Yov is offline
Masterofsquirrelz
#1657
Re: 4wd vs 6wd?
how can there be better traction if only 4 wheels are on the ground at a time?
Unread 04-01-2005, 14:42
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Re: 4wd vs 6wd?
cdr is probably referring to designs without the middle wheel dropped down (though he is still partly wrong). It does not inherently have more traction, and it should actually have less current draw because it has a higher ratio of wheel width to wheel length.
Team 1257
Unread 04-01-2005, 15:15
occra 23.
AKA: ryo
None #1481
Re: 4wd vs 6wd?
this has been discussed in a couple threads already, so if you want more arguement about if 4wd or 6wd or treads have more traction, please refer to the search thing.
Unread 04-01-2005, 15:44
Mike Ciance Mike Ciance is offline
FRC #0025 (Raider Robotix)
Mike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant future
Send a message via AIM to Mike Ciance
Re: 4wd vs 6wd?
ever since 2001 we have had 6 wheels. our beloved Evil Machine from 2003 had no drop for the middle wheel, but it turned perfectly. 6 wheels is a great benifit, and the wise choice for nearly any design
Unread 04-01-2005, 15:48
Re: 4wd vs 6wd?
to clear some stuff up from earlier, i was talking about if all 6 wheels are making contact on the ground at once. But i raise this new question, with a dropped wheel is it pushed around easily?
2-wheel versus 4-wheel drive Ben Mitchell Technical Discussion 23 07-11-2003 00:50
4wd Lisa Kit & Additional Hardware 2 03-02-2003 13:15
confirmed... 6WD recommendation of Joe J.. archiver 2001 0 23-06-2002 23:20
4WD with 4 motors archiver 2001 8 23-06-2002 22:58
tank or go-cart style steering? archiver 2001 17 23-06-2002 22:42
