Go to Post Common sense goes a long way. - Akash Rastogi [more]
Unread 04-01-2005, 23:19
Electrical Engineer
Rookie Year: 1995
Re: Program error after controller reset
Originally Posted by Astronouth7303
You'd think FIRST would have a variable so that it won't printf before it's initialized.
Jamie,
Hold on a second...
1. The default code that IFI provides us works. If we modify it and break it, it can not be their fault. We must assume responsibility for our actions.
2. Just what is the value of an uninitialized variable? Answer: It is undefined. If you are lucky, it will be 0x0000 or 0xFFFF. If you are unlucky, it can be anything.
My point here is that it is impossible to do what you suggest in an embedded controller.
It is possible in a program running under an operating system (the operating system guarantees the starting state of RAM).
Mike Betts
As easy as 355/113...
Loading Program to Controller.....problems Wbrown0389 Programming 5 27-02-2004 17:14
Dangerous.....Code problem?!? Argoth Programming 24 20-02-2004 14:57
Help On Coding 2K1 Controller GregTheGreat Programming 9 05-12-2003 18:35
Fried program slots? Jeff Waegelin Programming 18 19-03-2003 18:08
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
