Go to Post But don't forget about the little details, that can (and will) come back to haunt you. - Ben Piecuch [more]
Unread 05-01-2005, 18:18
SkiRacer SkiRacer is offline
Measure once, cut twice
AKA: Andrew
FRC #1676 (Pi-Oneers)
SkiRacer is an unknown quantity at this point
Send a message via AIM to SkiRacer
Rookie Team: Electrical / Wiring advice
I am the leader of the electrical sub-team on my school's FIRST team. We are a Rookie team, and I am looking for any information regarding the planinng and building of the electrical drive system, and wiring of the robot. If anyone knows what I should be doing before the kick-off to reduce the amount of work needed during the 6 week time frame, please let me know.
Thanks
Unread 05-01-2005, 18:39
Jaine Perotti Jaine Perotti is offline
...misses her old team.
AKA: BurningQuestion
FRC #0716 (The Who'sCTEKS)
Jaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond repute
Send a message via AIM to Jaine Perotti Send a message via MSN to Jaine Perotti Send a message via Yahoo to Jaine Perotti
Re: Rookie Team
Welcome to Chief Delphi SkiRacer!
My first suggestion to you would be to read as much as you can within Chief Delphi’s Electrical Forum
One helpful thread that comes to my mind is this:
Neat & Organised Electric Wiring
Also check out the Whitepaper section of Chief Delphi, where you can download a lot of useful information about many different topics.
These are some whitepapers which may be helpful to you:
Electrical Tips Handout
Robot Battery and Electrical System Guide
Good luck!
-- Jaine
Florida Institute of Technology
Ocean Engineering, '12
Unread 05-01-2005, 18:41
Pierson's Avatar
Pierson Pierson is offline
Pierson is a glorious beacon of lightPierson is a glorious beacon of lightPierson is a glorious beacon of lightPierson is a glorious beacon of lightPierson is a glorious beacon of lightPierson is a glorious beacon of light
Send a message via AIM to Pierson
Re: Rookie Team
I don't have the info in front of me right now... But when the PDF's are released, there will be one called electrical blueprint. It shows you how everything should be wired.
Pierson
Former Captain & Fundraiser of Team 360
Join in on these fun threads:
Three Worded Story
Word Association
Unread 05-01-2005, 19:04
Ted Boucher Ted Boucher is offline
Its been awhile.....
FRC #0237 (Black Magic Robotics)
Ted Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond repute
Re: Rookie Team
You should probably study the electrical parts from last season to familiarize yourself with the basic components that we use. Teach/learn how to solder well and share this skill with other members on the team (this will cut down on the problem of being the only person that can do it). Label everything, this is so important for work on your robot and for fixing potential problems that occur at competitions. Always carry a multimeter with you, for checking wire connections on the robot and for checking the battery power of your batteries. If you build a dual motor transmission, proof out the motors one by one in the transmission while the robot is off the ground. Make sure that they will all run in the same direction and you will be good to go. If not... you will just end up frying them and you will be out some valuable motors for the rest of the season.
Good luck and have a effective build season!
FRC Team 237 Alumni (04-07)
Western New England College Class of 2011
FRC Team 237 Mentor (11-?)
Unread 08-01-2005, 00:25
Wayne C.'s Avatar Unsung FIRST Hero
Wayne C. Wayne C. is offline
hey- I think we did pretty good?
FRC #0025 (Raider Robotix)
Wayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond repute
Re: Rookie Team: Electrical / Wiring advice
The competition manual spells out most of the wiring you will need to know. Be especially attentive to the gauges of the wiring you use for each of the motors or components as this will be checked closely in the inspection before competition.
Try to keep lengths of wiring to a minimum and fasten everything down with connectors in an orderly fashion. A rats nest of wires becomes a nightmare when a wire is crimped or disconnected.
Applying label tags to the various lines will be invaluable when you need to find the inevitable loose wire.
We solder all junctions and use shrink tubing to seal all connections.
In laying out your bot. be sure the control system, spike relays and speed controllers are visible and accessible by the workers but protected from an errant robot arm or crash.
Fasten your battery down securely- they fall out of somebody every year. We use a belt with a connector to hold the battery into a small box in the chassis.
Generally, most FIRST teams use the large 8 gauge connectors to wire the battery and the control system so you can easily swap out batteries between rounds. Make the battery easy to get to that way. Reinforce the connector with a zip tie so it cannot be knocked loose if the bot is jarred. Insulate all the battery terminals.
Don't worry. If you follow the guidelines FIRST gives you all this is rather easy.
WC
you want that robot to do what?
Raider Robotix- www.raiderrobotix.org
Unread 08-01-2005, 10:18
Deltafrog Deltafrog is offline
AKA: Andreas Stump
#0469 (Las Guerrillias)
Deltafrog is an unknown quantity at this point
Make your wiring as easy as possible, or it will give you hell later on!
Unread 08-01-2005, 18:58
You have some great advice so far. The electrical rules look a little more complex than last year. I would spend the next week reading and rereading the robot manual and become dead certain that your electrical meets the robot required wiring. Please ask specific questions and anyone will give you an answer. I am always available and will check the board daily, you can PM me if you feel unsure of posting in public.
The Death of FIRST Anton Abaya General Forum 23 03-05-2006 17:18
YMTC: Can teams start cutting metal for 2005? Natchez You Make The Call 67 07-02-2006 21:55
How do you organize your team? NoodleKnight Team Organization 18 03-11-2005 22:57
Real names, please Andy Baker General Forum 131 21-07-2004 22:07
Robot Collaboration Karthik General Forum 153 18-02-2004 03:40
