Go to Post Dear Mr. Lavery, Congratulations. For the fourth year running, you have successfully ruined my Christmas holiday with your untimely release of a most obfuscating, but no less tantalizing, hint. - dubious elise [more]
Unread 18-12-2004, 18:49
Michael Auchter Michael Auchter is offline
#0068 (Truck Town Thunder)
Michael Auchter is on a distinguished road
Perl FRC builder in Linux
I developed a program for building the robot code in Perl. I know that there is already an actual makefile which makes use of "make," but on my laptop, I have several directories full of code, and thought it would be nice to have one centralized utility to build them.
When you execute the program, it will compile all .c files in the current directory.
Installation Instructions:
cp ./frcbuild /usr/bin
chmod 755 /usr/bin/frcbuild
Type "frcbuild" in your code directory to build.
Comments/criticism would be greatly appreciated.
#!/usr/bin/perl -w
# Builder for MCC18
# FIRST Team 68, Truck Town Thunder
# Coded by: Michael Auchter (auchter.phire.org)
# Questions? Comments? michael.auchter@gmail.com
use strict;
# Variable Declaration.  Pretty self explanatory...
my $MCC   = "/opt/mcc18";
my $MCC18 = "$MCC/bin/mcc18.exe -p=18F8520";
my $LINK  = "$MCC/bin/mplink.exe";
my $WINE  = "/usr/bin/wine";
my $OPT   = "\"$MCC/h\" -D_FRC_BOARD -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-";
my $DRIVE = "Z";
my $LIB = "$DRIVE:$MCC/lib/";
# Compilation
while (<*.c>) {                 # Case sensitive, change if .C
 print "Compiling: $_\n";
 my $o = $_;
 $o =~ s|\.c$|\.o|i;
 system("$WINE $MCC18 \"$_\" -fo=\"$o\" /i$OPT") unless (/print_f/);
 system("$WINE $MCC18 \"$_\" -fo=\"$o\" /i\"$MCC/h\"") if (/print_f/);
# Build
print "Building FrcCode.hex\n";
my $files = "";
$files = "$files $_ " while (<*.o>);
system("$WINE $LINK /l\"$DRIVE:$MCC/lib/\" \"18f8520user.lkr\" $files \"FRC_library.lib\" /m\"FrcCode.map\" /o\"FrcCode.cof\"");
print "Removing *.o\n";
system("rm $_") while (<*.o>);
Unread 05-01-2005, 00:54
BrianJennings BrianJennings is offline
Sleep is optional
None #1519 (Mechanical Mayhem)
BrianJennings is an unknown quantity at this point
Send a message via AIM to BrianJennings
Re: Perl FRC builder in Linux
Does this code work on Windows and Linux?
It sounds very cool to me.
Have you thought about using PAR to compile it to an executable that is non relient on haveing Perl on the system? or adding a GUI with perl TK? If you haven't I could probably help you out, becuae I have done a bit of stuff with both...
Unread 05-01-2005, 02:07
phrontist's Avatar
phrontist phrontist is offline
Proto-Engineer
AKA: Bjorn Westergard
FRC #1418 (Vae Victus)
phrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond repute
Send a message via AIM to phrontist
You'd need only modify the file paths by the looks of it. Perl is farily inutive, except when it looks like line noise.
University of Kentucky - Radio Free Lexington
"I would rather have a really big success or a really spectacular crash and failure then live out the warm eventual death of mediocrity" - Dean Kamen
Unread 05-01-2005, 16:40
Yes, the file paths are all that need to be modified for it to work under Windows. As far as using PAR or a GUI, I had not thought of that, but if you'd like, feel free to modify the code and post it here.
Unread 05-01-2005, 18:52
doyler doyler is offline
Rookie / Programmer
#0900 (Infinity)
doyler is an unknown quantity at this point
Now this compiles it with using C18?
Unread 07-01-2005, 11:46
Sleep is optional
sounds cool... I might give it a go...
"it's googleable " -- the_undefined
Using an FRC with the RCX? Astronouth7303 Programming 21 15-04-2004 14:14
Linux SteveC116 3D Animation and Competition 22 25-03-2004 15:07
FRC Program State Frozen at Power-up WillyC Control System 4 14-02-2004 18:05
Linux And Windows XP Raven_Writer Chit-Chat 4 06-08-2003 18:53
