Go to Post The fact that although many of us disagree on specifics of how FIRST should conduct events, design a game, and facilitate as much fairness between teams as possible, in the end we still greatly enjoy each other's passion for FIRST and provide genuine respect for each other - Andy Baker [more]
Unread 05-01-2005, 12:47
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
MPLAB on Windows XP
I have tried to install MPLAB on several windows XP computers, and have had no luck. One was XP Home SP2, the other XP Home SP1. Both installations hung while installing the IDE, but seemingly after the installation part was done. I terminated that process to get the installation to continue, and everything seemed to go smooth. But then when I have rebooted and try to run MPLAB IDE, the splash image comes up and the process terminates. No error or anything, just the splash image and then it goes away. The MPASMWIN and IFI_Loader both run fine, but that's kind of useless without the IDE.
It's my understanding that this was a common problem last year, but my searches didn't turn up any threads.
I tried running MPLAB IDE using windows XP's compatibility modes, but even when I tell it to run it in Windows 98 mode it doesn't work (in fact, now it produces a "this program has ended unexpectedly, do you want to tell Microsoft?" message.)
Anyone know what to do?
Unread 05-01-2005, 13:53
Electrical Engineer
Rookie Year: 1995
Re: MPLAB on Windows XP
Greg,
Try reinstalling MPLAB again on the computer and you should be OK. I'm not sure why but the second install seemed to work for me last time I did it.
Mike Betts
As easy as 355/113...
Unread 05-01-2005, 14:18
Bharat Nain's Avatar
That happen to me too, and I could not figure out what exactly happen. I ended up re-installing XP altogether. I suggest(at your own risk) removing any other unused system variables, because that solved my problem once. I also highly recommend NOT using XP Home. XP Pro works better and gives you more options.
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 05-01-2005, 15:39
Electrical Engineer
Rookie Year: 1995
I was advocating reinstalling MPLAB not XP. I am running XP Home SP2 and have had no problems with MPLAB.
Mike Betts
Unread 05-01-2005, 18:50
doyler doyler is offline
Rookie / Programmer
#0900 (Infinity)
doyler is an unknown quantity at this point
It should work regularly without changing anything
I have XP and I run it perfectly
Unread 05-01-2005, 19:20
Ian W. Ian W. is offline
College? What?
no team (Gompei and the Herd)
I installed it on my laptop, it hung for a good 5 minutes before getting anywhere, but it worked. You just have to let it sit for a while. It's a horrible program in so many ways, I absolutely hate it as an IDE, but it works, and I'm really too lazy to write my own (or figure out how to use Emacs to compile it all, even though I doubt it's too hard).
AIM --> Woloi
Email --> ian@woloschin.com
Unread 05-01-2005, 20:43
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Why Emacs? There's hundreds of free IDEs/editors. (I currently use ConTEXT).
Unread 05-01-2005, 21:20
College? What?
Why ConTEXT? I mentioned a program I know and that I've used for similar projects. Who cares what IDE you use or how you use it? It's a pointless argument, just drop it, unless you'd like to do an entirely objective review of everyone free IDE to find out which one is the absolute best, and I doubt you'll have time to do that before kickoff.
AIM --> Woloi
Unread 05-01-2005, 21:43
It's not hanging, it's gone. The process is terminated.
I'll try re-installing it.
Unread 07-01-2005, 11:48
BrianJennings BrianJennings is offline
Sleep is optional
None #1519 (Mechanical Mayhem)
BrianJennings is an unknown quantity at this point
Send a message via AIM to BrianJennings
I installed MPLAB 7 on WinXP Home Sp1 and it works fine... What Version are you trying to install?
"it's googleable " -- the_undefined
Unread 07-01-2005, 21:16
Back after 4 years off
FRC #5279
If you dont have it installed yet I had the same problem using XP SP2. Reboot the computer close everything that opens on startup then install, if it gets hung up after installing IDE then let it sit for like 5 minutes thats what i had to do at our lab and it ended up installing fine.
Unread 08-01-2005, 09:27
Sleep is optional
to one of the things i her heard was that sp2 is not compatible with many programs, and if you can avoid installing it, don't install it. at least until microsoft gets another update on it.
Unread 08-01-2005, 13:23
This is exactly what I did. It finally worked! I just didn't wait before when the installer did nothing (0% processor use) for three or four minutes, so I assumed it was not doing anything anymore.
Now I have a whole NEW MPLAB to install anway!
Also, SP2 is pretty nice on my laptop for its wireless features, making it a lot easier to use when traveling.
Program to copy list of files from Windows explorer as text into an application? Elgin Clock IT / Communications 6 30-12-2004 21:23
Malware, Adware and Spyware JohnBoucher Technical Discussion 41 16-05-2004 22:51
MPLAB Variable Simulator? Chris_Elston Programming 3 18-02-2004 12:08
using the MPLAB IDE MPLAB SIM simulator WizardOfAz Programming 1 03-11-2003 01:24
Windows ME robot180 Chit-Chat 11 07-07-2003 00:21
